Smittybuilt 2781 or VIAIR 400P?
Discussion in '5th Gen 4Runners (2010-2024)' started by T4Rrunning, Apr 28, 2022.
  1. Apr 28, 2022 at 5:06 PM
    T4Rrunning
    T4Rrunning [OP] New Member
    I have narrowed it down to these two portable air compressors. For those of you that own them or purchased one recently… Which one would you recommend?
    Smittybuilt
    Smittybilt 2781 5.65 CFM Universal Air Compressor
    VLAIR
    VIAIR - 40045 400P-Automatic Function Portable Compressor , Silver
    smittybuilt is almost half the price is the VIAIR worth the extra $150?
    I plan on eventually getting a morrflate 4 way tire inflator system for the compressor as well.
    Thanks!
  2. Apr 28, 2022 at 5:42 PM
    I have no personal experience with either if these exact inflators. But, I've had a Viar 300p for a few years and I'm happy with it. I hang out with a few guys who use the 88p as well, and they seem nice as well.
  3. Apr 28, 2022 at 5:43 PM
    jasonmcelroy
    Jason
    San Jose, CA
    2021 Grey Trail
    Only have experience with the Viar side . . .
    Have had it packed on trips the last year and used it four times.
    Observations:
    • filled fast enough for me (maybe 20min for whole job unpack to pack up going from 25psi to 40psi fully loaded down)
    • valve connector fitting easy to use and does not leak or slip off
    • vibration isolation mount really cuts down on noise
    • having to go to the pump body to turn on/off is a minor inconvenience (i'm a geek and might wire a remote switch into the hose. nylon harness tape is my friend here)
    • packs to a reasonable size for storage with my gear
    Jason
  4. Apr 28, 2022 at 5:50 PM
    T4Rrunning
    The 300p looks like a good option. Looks like the main difference is the trigger and automatic shut off. Hmmm I’ll look into it.
    How long does it take to fill your tires?
  5. Apr 28, 2022 at 6:02 PM
    KYFHO
    KYFHO Generic Scumbag
    UT
    2017 SR5P with some stuff
    I have the 300p. The first time I used it I filled my tires (stock size Falkens) and my friend’s tires (33s) from 20 psi to 32 psi in about 15 minutes.
    T4Rrunning[OP] and Thatbassguy like this.
  6. Apr 28, 2022 at 6:19 PM
    Got the 88P, hardly use it maybe a couple of times. Small compact gets the job done.
    Might get the 1000P, bigger is better right?
  7. Apr 28, 2022 at 6:43 PM
    I know I've timed it, but can't recall exactly. It's around 10 minutes to fill (4) 295/70/17's from 20 to 35.
    I also made my own hose so I could read the gauge at the unit. This way I don't have to run back and forth. If you're interested:
    https://www.4runners.com/threads/th...ll-of-my-money-went.12919/page-15#post-258802
  8. Apr 28, 2022 at 6:51 PM
    T4Rrunning
    Can you send me the link to the parts you used? Looks like a good affordable mod!
  9. Apr 28, 2022 at 7:21 PM
    Here's the gauge:
    MEASUREMAN 2-1/2inch Dial Size, Liquid Filled Pressure Gauge, 0-60psi/kpa, 304 Stainless Steel Case, 1/4inNPT Lower Mount https://www.amazon.com/dp/B07T43LMM6?_encoding=UTF8
    Unfortunately, I have no links for anything else. I just grabbed a bunch of stuff off the shelf at Menards and put it together. :D
    I think everything else I got was thread tape, a hose, T-fitting for the gauge end, 1/4" outlet for the compressor, and the connector for the tire valve. I think the gauge was the most expensive part. I'd probably use a Flexzilla hose if I did it again.
  10. Apr 29, 2022 at 5:10 AM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    No experience with the Smitty.
    I have owned the VAIR siince at least 2018, and use it frequently; it seems well made, reliable, fills acceptably fast. Wiring and air hose are long enough to reach everything easily. I am happy with it and would buy it again.
    How it compares to the Smitty I cannot say...
  11. Apr 29, 2022 at 7:17 AM
    Zeet959
    Zeet959 New Member
    Tony
    Nebraska
  12. Apr 29, 2022 at 7:18 AM
    T4Rrunning
  13. Apr 29, 2022 at 9:01 AM
    Which model VIAIR do you have?
  14. Apr 29, 2022 at 9:25 AM
    2019 TRDP w/Kangs brah!
    I went with a Viair 450P. I've had it for 6 years without issues and it works fairly quickly on one tire at a time but I haven't tried it with my Moreflate kit. When it dies, I'm going with a ARB twin piston.
  15. Apr 29, 2022 at 4:14 PM
    MeefZah
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    400p
    T4Rrunning[OP] likes this.
  16. Apr 29, 2022 at 4:56 PM
    T4Rrunning
    do you think getting the automatic version is worth the price difference?
  17. Apr 30, 2022 at 12:52 AM
    MeefZah
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    I'm not familiar with that version. I guess I missed that part of your original post. Sorry.
  18. Apr 30, 2022 at 10:02 AM
    Liv2Ride
    Liv2Ride New Member
    ’19 MGM Limited
    Eibach Stage 2, JBA UCA’s, K02 - 265/70, Ark guards, Sony XAV9500ES
    Yes! If you are moving around the vehicle you don't want to run back and forth to the inflator to turn it on/off.
    I have the 400P auto, have had it for about three years now and it was well worth the money. So far I've primarily used it for maintaining tire pressure on my stock limited tires and only with road use. My research prior to buying, with the thought I'd get larger tires and start some mild off-roading, led me to the purchase. All items are built as you would expect (robust) for this price point IMO.
