RCI - Quality stuff or meh?
Discussion in '5th Gen 4Runners (2010-2024)' started by LT Smash, May 4, 2024.
  1. May 8, 2024 at 5:29 PM
    #61
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
    Why not just grind it in targeted rust spots? Apply paint over.. so it’s not perfectly even looking, but who cares for a part that will be frequently banged on by rocks?
    I have a quart of rustoleum that I brush on, when I have targeted nicks. No need to spray paint and deal with shielding the car from overspray
    Stoney Ranger likes this.
  2. May 8, 2024 at 7:44 PM
    #62
    I ‘ve been doing spot treatments since last year, by scraping and brushing on rustoleum.
    The scratches off road aren’t the really the problem. Those are easy to manage. The problem is the rust that has traveled underneath the powder coat pretty evenly across all of it.
    Thacrow likes this.
  3. May 8, 2024 at 7:51 PM
    #63
    Yobruhitsme
    Denver
    Ineos Grenadier
    God damn!! Powder coat permits rust underneath like that?!
    is that an rci slider? Those vertical tabs seem pretty useless? More surface area to maintain
  4. May 8, 2024 at 8:09 PM
    #64
    These are from Caliraised led. I think any paint or any powdercoat will stick only as good as the steel was prepped. Most of the bubbles started at chips caused be gravel. With the salt used on the roads, if the powdercoat adhesion isn’t perfect, then rust will start growing behind it and peels it off, a lot of it by hand or with a scraper. The rust goes deep in these areas, to where I’m removing a significant amount of material before getting to bright shiny steel.
    However, there are areas of good adhesion where it’s even difficult to remove the powder coat with a grinder/flap wheel
    It’s an all around pain in the ass lol. I’m hoping to prep it well enough for it to last 3 or 4 years. Then, maybe it’s easier to get new ones lol.
    edit: the tabs are for reinforcement brackets. These were probably bolt-on purely for shipping/packaging purposes.
  5. May 8, 2024 at 9:10 PM
    #65
    Yobruhitsme
    Denver
    Ineos Grenadier
    damn!? Those older cali raised sliders look pretty poorly designed. Round tubes and use less brackets + hardware.
    where are you? Rust belt? Your 4R frame doesn’t fare too well either I assume ?
  6. May 8, 2024 at 9:57 PM
    #66
    My frame is still spotless, because it’s covered in thick crusty dirty layers of woolwax. It’s only a few years old though…
    The slider design isn’t so bad on these to be honest. Plenty of bolts to the frame, and the rear plates wrap around the bottom. That way it’s not just the bolts taking sheer loads. They’ve been put to moderate use off road with no problems. Plenty strong for rock pivots and mild/short drops onto them with the weight of the vehicle. I prefer not to subject my frame to what the sliders might be able to take lol.
  7. May 20, 2024 at 11:32 AM
    #67
    SkippyRunner
    SkippyRunner New Member
    2020 4Runner TRD
    I have a full set of RCI skid plates plus the RCI gas tank cover. Did some superficial damage to them this weekend on a serious trail - RCI makes great stuff. I’m getting their Rock sliders next.
  8. May 20, 2024 at 11:35 AM
    #68
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Has anyone modified their RCI transmission skid for easier front diff and transfer case fluid flushes?
    I contacted RCI about why they didn't have cutouts in these locations. Something about compatibility across a couple different vehicles? I don't remember exactly what they told me.
    As of now I have to drop all the skids to gain access to these drain plugs and not make a giant mess.
    I was considering taking my acetylene torch to them...
  9. May 20, 2024 at 11:41 AM
    #69
    2021venture
    2021venture New Member
    Todd
    2021 Venture
    Xfer and front diff access for fluid change doesn't bug me as much as dropping for greasing driveshafts. Hoping someone has a mod for this. Every 30k for fluid changes is not as much of a pain every 5k to lube.
  10. May 20, 2024 at 11:45 AM
    #70
    1SilverRunner
    Tejas
    Easy to say with those lightweight aluminum skids :p
  11. May 20, 2024 at 11:46 AM
    #71
    2021venture
    Todd
    2021 Venture
    Every time I have to pull the skids I think the aluminum is plenty heavy duty and don't need steel.
    The tricks we all come up with contorting ourselves under truck balancing skids trying to get a couple bolts started.
    roooo and 1SilverRunner like this.
  12. May 20, 2024 at 11:48 AM
    #72
    1SilverRunner
    Tejas
    Cutting torch for me next time they come down then lol
  13. May 22, 2024 at 9:59 AM
    #73
    michow87
    michow87 New Member
    2024 TRD Pro Underground
    I was wondering if you guys think the removable top plate (now attached with screws vs. being welded on) creates more opportunity for micromotion and ultimately salt to find its way into the crevices and lead to rusting issues.
  14. May 22, 2024 at 10:37 AM
    #74
    2021venture
    Todd
    2021 Venture
    This might be a concern. On other brand sliders there have been feedback top plate has caused rusting. This was welded on. Maybe removing and cleaning will help.
  15. May 22, 2024 at 10:55 AM
    #75
    Yobruhitsme
    Denver
    Ineos Grenadier
    On my rsg slider with welded top plate, dirt collects in every crevice. I imagine if that’s salt, it can be the start of a rust situation
    5thToy likes this.
  16. May 22, 2024 at 5:55 PM
    #76
    michow87
    michow87 New Member
    Or maybe the removal plate is better for salt to not get stuck and decreases risk of rust.
  17. May 22, 2024 at 7:43 PM
    #77
    Yobruhitsme
    Denver
    Ineos Grenadier
    But those holes will attract moisture inside and salt brine.
    lol can’t win
    michow87[QUOTED] likes this.
  18. May 23, 2024 at 1:49 PM
    #78
    michow87
    michow87 New Member
    Personally going back and forth between RCI and RSG sliders for the past few months. Haven't been able to commit to one yet and so I keep reading the same threads over and over. Regardless, I'll be going flat + kick out for the kiddos.
    Pros: RCI - they look better; RSG - welded top plate
    Cons: RCI - concern about the screwed on top plate; RSG - stick out a lot and personally think they look goofy
    My thought is that I can fluid-film the screw holes on the RCI top plate. I could also be diligent with making sure I hose them off in the winter every few weeks.
    As for RSG, I have read complaints of rust on the underside of the slider where the plate is welded.
  19. May 23, 2024 at 5:46 PM
    #79
    Cajunchuck
    Cajunchuck New Member
    Arkansas, USA
    2023 TRD ORP
    BFG KO2, stock size RCI 20 degree sliders RCI engine/trans skids
    Man it’s been almost six weeks since I placed my order with them for my sliders. They must be busy. Can hardly wait to put them on. Got some trails I’m excited to check out now that I’ll have a little protection.
  20. May 23, 2024 at 6:54 PM
    #80
    Joejoe
    Joejoe New Member
    Joe
    RCI skids Eibach stage 2 leveling kit
    I have RCI skids with no issues
  21. May 23, 2024 at 8:26 PM
    #81
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    I originally had RSGs with the welded top plate. Sold them for that reason and installed their bare tube version. Lesson learned. Happy now.
  22. May 23, 2024 at 8:31 PM
    #82
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    I have a full set of RCI skids and have the same complaint with accessing front drive shaft zerks. This was and is my solution for easing removal and replacement of plates. I removed the T-Handle and drive the jack via socket with my Makita.
    Plates roll in and out balanced on the stand (15" x 9") with no effort. Extends to almost 18" which is perfect.
    To the OP's question, I have RCI's aluminum skids front to back and have been very happy with them knowing from the start they would not be as rugged as steel but are adequate for my use and saved weight. No issues with fitment.
    https://www.amazon.com/gp/product/B08GCF78NN?ie=UTF8&th=1
    2021venture[QUOTED] likes this.
  23. May 24, 2024 at 6:00 PM
    #83
    TRDSD
    2019 TRD Off Road Premium
    My new rear diff skid is showing up tomorrow (ordered a month ago). Their site said something like a 4-6 week delay on items that were not in stock. They've also had sales running, so I'm sure that's draining stock and adding to delays. I'd bet you get them soon. Estimated times seem to be pretty accurate.
