Any 2023 TRD Pro owners running Eibach lift springs?
Discussion in '5th Gen 4Runners (2010-2024)' started by UATahoe, Jan 2, 2024.
  1. Apr 15, 2025 at 12:48 PM
    #361
    hossler1788
    hossler1788 DADWAGON
    Joshua
    Central Pa
    2020 4runner
    I just got 2019/2020 trd eibach front coils. I couldn't find anywhere the actual spring rate, so I emailed eibach.... 600 lbs/in.
    boostedka likes this.
  2. Apr 17, 2025 at 9:53 AM
    #362
    brodeyo
    brodeyo New Member
    I've had the Wescott for about a year on a new '24 trd pro. I'm now experiencing rubbing at reverse and full lock. Assuming springs are starting to settle in ... and I'm not a fan. I just purchased the 1.4 and 1.0 springs...again... Should have listened to RussPro!
    michow87, RusPro17 and hossler1788 like this.
  3. Apr 17, 2025 at 1:45 PM
    #363
    RusPro17
    RusPro17 Back home again!!
    Don
    Pa.
    2023 TRD Pro Solar Octane
    SCS wheels and Westcott lift
    Going on about 8 months since my Eibach install with the 1.4 and 1.0. So far been very happy with it.
    michow87 likes this.
  4. Jul 6, 2025 at 9:49 AM
    #364
    michow87
    michow87 New Member
    2024 TRD Pro Underground
    mind if I ask what offset your wheels are?
    finally bought the eibach springs after too much research. Decided on Toyo Open Country AT3 in 285/70r17. Now deciding on the wheel.
    RusPro17[QUOTED] likes this.
  5. Jul 6, 2025 at 10:43 AM
    #365
    RusPro17
    Don
    Pa.
    Mine are the -10. I have been running SCS wheels for years. Love the offset and gives just enough poke without over doing it.
    michow87[QUOTED] likes this.
  6. Jul 6, 2025 at 11:15 AM
    #366
    bobby4runner
    bobby4runner New Member
    Los Angeles
    2022 TRD Pro MBM
    Anyone know what the difference between the OE 21-22 Fox Pro shocks vs 23-24? Dealer recently warrantied my front OE 22 Pro shocks with OE 24 Pro shocks. Just curious what changes warranted new part number resulting in different Eibach springs.
  7. Jul 7, 2025 at 4:12 AM
    #367
    michow87
    michow87 New Member
    They’re the exact same. The change I believe occurred with the 2021 years
  8. Jul 7, 2025 at 4:14 AM
    #368
    michow87
    michow87 New Member
    awesome. The shop I’m using recommended not going beyond -12 without a high clearance cut (Viper or high clearance bumper). I initially wanted the SSW Dakars, but they’re in -25 and 0 and I wanted something a little more aggressive than 0. Thanks!
  9. Jul 24, 2025 at 4:43 PM
    #369
    michow87
    michow87 New Member
    @RusPro17 Looking at adding the Rokblokz mud flaps as well. The website says "This kit does not currently work with the side-exit exhaust starting in 2019 or 2020 on the TRD Pro, TRD Off-Road, and TRD Off-Road Premium."
    Any issue with the passenger rear mud flap and your exhaust tip?
  10. Jul 24, 2025 at 7:25 PM
    #370
    RusPro17
    Don
    Pa.
    I only did the front because I was not worried about the rear oem cutting into the paint on my vehicle because the rear panel has PPF under the flaps. Yes I have read about the rear ones. But when I had my 20 AG Pro I did the rears also and it had the Pro exhaust and had no issues melting the flap. But I also only had a couple of thousands miles on them before I traded my 4runner in for a tundra Pro. Not sure how long the rear will hold up before melting.
  11. Aug 21, 2025 at 11:17 AM
    #371
    mackb1
    mackb1 New Member
    Mack
    23 4R TRD Pro
    Hello all. New here. I have a 2023 TRD Pro. Looking at the Eibach 1.4/1 springs. Has anyone considered a progressive rate spring? Or are the Eibach’s the best bet for a OEM+ setup.
  12. Dec 28, 2025 at 8:25 PM
    #372
    brodeyo
    brodeyo New Member
    Finally removed the Wescott and installed the Eibach 1.4s. Can't really tell a difference yet.
    RusPro17 likes this.
  13. Jan 5, 2026 at 6:47 PM
    #373
    brodeyo
    brodeyo New Member
    Those of you that have the 1.4s. What are you doing for bumpstops?
  14. Feb 25, 2026 at 7:25 AM
    #374
    brodeyo
    brodeyo New Member
    It seems this thread is now dead, but I thought I'd try to revive. I've had the Eibachs on for about 3 months and while I initially loved the ride, I've found after settling it's quite bouncy. Perhaps this is due to the rear spring rate being 50lbs heavier? Not sure if that really makes a difference. Anyone else noticing this?
    Thanks in advance.
  15. Feb 25, 2026 at 9:47 AM
    #375
    astralzombie
    astralzombie New Member
    2021 TRD-Offroad 4Runner
    2 inch lift, Fox 2.0 coilovers/shocks, Eibach springs, Timbren bumpstops, Method 316 wheels, 275/70/r17 Falken Wildpeak AT4W tires
    In case no one has mentioned this, 2” front and 1” rear will still have rake, if you want it “level” 2.5” front springs are the way.
    Also, pretty sure all Fox shocks have Eibach springs, at least they used to.
  16. Feb 25, 2026 at 12:57 PM
    #376
    brodeyo
    brodeyo New Member
    The rake isn’t notable. The Fox suspension already sits up 1 inch. Adding 1.4 upfront gives enough for no rake at 2.4
    yes, the original springs are Eibach. These are the Eibachs Trd springs that bring it up and additional 1.4
  17. Feb 27, 2026 at 9:36 AM
    #377
    RusPro17
    Don
    Pa.
    That was the issue I was feeling John. That’s why I put my stock springs back on. And now I think and the wife thinks it rides better.
  18. Feb 27, 2026 at 2:36 PM
    #378
    brodeyo
    brodeyo New Member
    Yea, I think stock was better, except for nose dive and for turns at speed. I need to get it off-road and get some weight in it.
    I’ll go back to stock and maybe 275s when it’s time for new tires… if I still have it by then
  19. Mar 6, 2026 at 9:25 AM
    #379
    Abrisebois
    Abrisebois New Member
    André
    2024 4Runner TRD Pro
    Are the TRD Pro Fox shops rebuildable? What I am thinking would be to revalve them to compensate for a higher rate spring.
