AC drain relocation
Discussion in '5th Gen 4Runners (2010-2024)' started by morfdq, Jun 9, 2025.
  1. Jun 12, 2025 at 8:49 AM
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    Just snip the daggling part :)
  2. Jun 12, 2025 at 10:27 AM
    Now you have to buy a daggle for the end??:confused:
    LuLu[QUOTED] likes this.
  3. Jun 25, 2025 at 9:12 PM
    MAXIM
    MAXIM New Member
    For years I thought water dripping on the frame directly under OEM A/C wasn't an issue because it is in perfect condition, paint intact and no rust. I was wrong because I checked in wrong place. Follow same frame rail all the way under front passenger area, run your hand on the top of that frame portion and be amazed how much damage your A/C drain done already. Spray some rust convertor and/or fluid film there and reroute that drain hose as described by many in this post. Don't worry about blockage potential or narrowing via connector; remember this mod is easily reversible or disconnect-able for obstruction repair.
  4. Jun 26, 2025 at 6:08 AM
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    Out of Curiosity. Bought the black connector and reinforced 1FT Fuel hose from O'Reilly. About $8 total
    The staff was so rude and lazy. Not eager to make money for the company.
    I had to search for part number myself online and force them to look inside the storage.
    It wasn't on any shelf display.
  5. Jun 26, 2025 at 6:27 AM
    OdyRunner
    OdyRunner New Member
    I was thinking the same thing about mold as I was reading this thread, it can build up quickly in a vehicles AC system. Instead of using a barb to connect the the two hoses together you can can get a larger diameter hose and use it as a coupling to make the connection instead.
    jgalt likes this.
  6. Jun 26, 2025 at 6:43 AM
    Why not just use the larger diameter hose as the drain extension?
    jgalt likes this.
  7. Jun 26, 2025 at 6:44 AM
    OdyRunner
    That’s an even better idea.
  8. Jun 26, 2025 at 7:44 AM
    I did that on my taco. you have to kinda find a spot and route where a clamp isn't needed. cuz when you clamp it like that the inner tube gets crumpled.
  9. Jun 26, 2025 at 7:51 AM
    salvojimmy
    salvojimmy New Member
    Glen Allen VA
    2022 SR5P
    No Mods Yet
    That makes sense to eliminate the connector between the 2 hoses.
  10. Jun 26, 2025 at 7:58 AM
    FancyLimited
    FancyLimited New Member
    2024 Silver Limited
    ualfltdispatch and kolter45 like this.
  11. Jun 26, 2025 at 4:12 PM
    if youre using a 3/8” ID and 1/2” OD coupler, its the same size inside, so no restriction
  12. Jun 26, 2025 at 4:15 PM
    Amazon has the 3/8” plastic connectors. 5 for $6
  13. Jun 26, 2025 at 4:17 PM
    Rocko9999 likes this.
  14. Jun 27, 2025 at 8:16 AM
    morfdq [OP] New Member
    I am the OP, Oreillys has the brass connector for $3. I went with the brass connector. O'Reillys also just cut the tubing to length for me. You have to buy a foot but I just had them cut it to 10"
