5k oil change
Discussion in '5th Gen 4Runners (2010-2024)' started by SWxSW, Mar 24, 2021.
  1. Mar 27, 2021 at 9:08 PM
    4Runner170V
    4Runner170V New Member
    Tony
    Los Angeles
    2014 4Runner Trail
    I have to switch to 103N. It just came in today after taking photo. My apology for misleading.
    Toy4X4 likes this.
  2. Mar 27, 2021 at 11:13 PM
    Tuco S.
    Tuco S. New Member
    Gotcha. You might check with Fumoto. I think they recently came out with a new model with a larger orifice that drains faster. F-133N is the newer style.
    Toy4X4, SlvrSlug and taco_runner like this.
  3. Mar 28, 2021 at 7:58 AM
    Bgdv1
    Bgdv1 New Member
    Dave
    Butler
    2014 SR5P
    I use Amsoil in 4Runner & Tundra with Toyota TRD filters. Could I do it cheaper....Yep. But peace of mind for me and I change at 5000 miles. I can't let myself wait for 7500 or 10,000 miles.
    Toy4X4 and taco_runner like this.
  4. Mar 28, 2021 at 8:13 AM
    Opteron
    Opteron New Member
    2018 4Runner SR5 premium
    None
    We made the mistake of actually having the first oil change at 10K, the dealer recommended and free. before the second oil change, I noticed the oil very dark, actually black in color. after the second free oil change. We had to pay for the extra oil change at 5k after the second oil change. After our last oil change I have been changing the oil myself, takes less than 30 minutes biggest pain is removing the front lower armor and stupid plastic piece. Also, the fumoto valve makes everything so easy.
    The dealer also uses the cheapest 0-20w oil they can get their hands on, my particular toyo dealer used Pennzoil.
    Note: as someone posted here, I use Toyota branded oil. From what I hear they use their own additive pack. I don't think anyone should go with the 10k oil change on what they recommend. I tried arguing with the service manager according to the manual my truck is in the severe environment and would require a shorter interval. They didn't care, toyota only pays for 10k oil change interval.
  5. Mar 28, 2021 at 11:49 AM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    Good for you, doing your own oil changes. If gives you a sense of accomplishment and the opportunity to crawl under and check things out. I actually let the dealer do each 5000 mile “service” and they goofed something up each time. Now I do everything myself.
    Don’t forget to lube the drive shaft zerks, the dealers don’t regularly do that.
  6. Mar 28, 2021 at 1:40 PM
    2016Pro
    10k and cheapest brand I can find. I sleep perfectly fine at night
  7. Mar 28, 2021 at 2:43 PM
    Tuco S.
    Tuco S. New Member
    Now you've done it!
    Toy4X4, Slopemaster and nimby like this.
  8. Mar 28, 2021 at 7:38 PM
    :eek:
    The horror!
    2016Pro[QUOTED] and Toy4X4 like this.
  9. Sep 13, 2022 at 10:50 AM
    Potsie
    Potsie New Member
    2022 Army Green 4Runner ORP
    Any clue if the fumoto needs to be torqued or just hand tighten?
  10. Sep 13, 2022 at 10:52 AM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    I believe it has a torque spec on it. I’ve had mine too long to remember
  11. Sep 13, 2022 at 10:56 AM
    Potsie
    Potsie New Member
    Thanks, just found the info. Hand tighten and a 1/4 turn with a 3/4 wrench
    Tama1968 likes this.
  12. Sep 13, 2022 at 11:03 AM
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    I was gonna say I don’t think you can get a torque wrench on it :D
  13. Sep 13, 2022 at 11:26 AM
    Potsie
    Potsie New Member
    they make something called a crow foot wrench for a torque wrench. 15 lbs for the fumoto. Hand tighten will do for me. I'm not buying more tools
  14. Sep 13, 2022 at 7:02 PM
    wolfman
    wolfman New Member
    Don't kill me! But whats a zerk, where is it, and what do I lube it with? Thanks and sorry.
  15. Sep 14, 2022 at 9:35 AM
    A zerk fitting is a metal fitting that is attached to a part that requires periodic lubrication - typically with grease. On one end it is threaded with a hex portion that accepts a wrench. The other end is ball shaped, and has a hole with a ball bearing and spring pressed in. A grease gun is a specialty tool used to inject grease into the zerk fitting. The ball bearing/spring arrangement allows grease to flow into the fitting but not out.
    Jere39, GJ4R, wolfman and 2 others like this.
  16. Sep 15, 2022 at 7:51 PM
    wolfman
    wolfman New Member
    Amazing info. Thank you. I will add it to the list of "dealer never did it, now I have to figure it out myself". I appreciate it.
  17. Sep 16, 2022 at 3:28 AM
    Ramrod88
    Ramrod88 4Runner on Corolla budget
    New Orleans
    22 TRD OFF ROAD
    M1 0w40
