3" Dobinsons lift
Discussion in '5th Gen 4Runners (2010-2024)' started by Gyoaz, Feb 2, 2020.
  1. Feb 6, 2020 at 7:33 AM
    Gyoaz
    Gyoaz [OP] Garyo
    AZ
    5th gen 4runner TE
    Diff breather, Camburg UCAs, dobinsons 3" lift, front n’ rear steel, RTT, scuba exuiped, OBA, and some lights
    Yes, that's the plan. I have a C4 rear bumper on the way, a winch that needs a bumper and plan on skids.
    WallyT4R likes this.
  2. Feb 6, 2020 at 3:55 PM
    jack bauer1
    jack bauer1 New Member
    23 front is typically accepted as the limit for decent CV heath, as a general rule. Rigs are different though, mine at 23 and the CV boot were angry. Some rigs boots look fine as 23. Bottom line is once you have your front end stuff installed, then evaluate.
  3. Feb 6, 2020 at 4:26 PM
    Gyoaz
    Gyoaz [OP] Garyo
    AZ
    5th gen 4runner TE
    Any chance the CV could not be seated properly? I tuck its highly unlikely but my buddy mentioned it.
  4. Feb 6, 2020 at 4:27 PM
    Gyoaz
    Gyoaz [OP] Garyo
    AZ
    5th gen 4runner TE
    Thanks, I think 300lbs of winch and armor should probly drop me an inch.
  5. Feb 6, 2020 at 7:17 PM
    jack bauer1
    Does 4WD work fine?
    I doubt they are not seated properly.
  6. Feb 6, 2020 at 8:01 PM
    Gyoaz
    Gyoaz [OP] Garyo
    AZ
    5th gen 4runner TE
    I haven't used the 4wd since lifting. But I jacked both front tires off the ground, put it in 4hi -N and turned one tire. The other side rolled the opposite direction.
  7. Mar 4, 2020 at 6:58 AM
    The 2.75" of lift on the Pro Truck lift is from the coil springs, with the spring perch on the lowest, not highest setting.
  8. Mar 4, 2020 at 7:05 AM
    jack bauer1
    I said it wrong.
    You are correct.
  9. Mar 13, 2020 at 9:07 AM
    Mtbpsych
    Mtbpsych New Member
    Have any of you done a diff drop on 2”-2.5” of lift? Debating whether or not I should.
  10. Mar 18, 2020 at 2:39 PM
    Gyoaz
    Gyoaz [OP] Garyo
    AZ
    5th gen 4runner TE
    I did the diff drop. It did help my cv angles a bit. Also the lift has settled a little.
  11. Jul 21, 2020 at 7:12 PM
    FamRunner
    FamRunner New Member
    Michael
    2020 Silver Venture Edition
    Pro Grille, TOYO Open Country AT3, 2.5” Bilstein lift
    Any update on measurements or ride quality? Just installed the 1“ rear springs and shocks and got about 2” out of them and waiting to install front 2.5”. Hoping not to get a hair over the 2.5”. Currently have 5100’s installed at top perch and am measuring 23”, was hoping to add dobinsons 2.5” at lowest 5100 setting for a max of 2.5”
  12. Jul 24, 2020 at 3:03 PM
    Gyoaz
    Gyoaz [OP] Garyo
    AZ
    5th gen 4runner TE
    My rear is still sitting at 25ish but the getting has dropped to just over 23. I havent added the weight of bumpers yet. The ride has gotten a bit softer on the road but It's still a bit stiff on the trails.
  13. Jul 27, 2020 at 8:43 PM
    PlantMan
    PlantMan New Member
    Chance
    2014 Limited
    I’ve got a similar problem. I’ve got a bone stock 2014 Limited that I just installed C59-314 springs and C59-574 shocks up front with C59-505 and C59-705 in the rear.
    I ordered from Dobinsons Direct. They told me that this was the setup I wanted with no aftermarket bumpers to get 3.5” in the front and 1.5” in the rear. What I ended up with is just over 4.5” of lift in the front and 2” in the rear.
    Currently running stock UCAs.
    I’m starting to think that this is a common problem with Dobinsons systems. Anybody have any experience with getting parts returned or replaced with Dobinsons direct?
    (BTW, 4.5-5” of lift without doing an alignment yet and on stock arms is terrifying to drive .)
  14. Jul 28, 2020 at 9:46 AM
    Gyoaz
    Gyoaz [OP] Garyo
    AZ
    5th gen 4runner TE
    If you really want 3.5 up front you"ll need UCAs. Do you have the weight up front yet? I'm still sitting so high because I haven't installed my bumpers yet.
  15. Jul 28, 2020 at 10:51 AM
    PlantMan
    PlantMan New Member
    Chance
    2014 Limited
    I want new UCAs but my budget doesn’t and I know people that have gotten 3* of caster at that height with stock arms so took the gamble. May have lost on that one.
    I’ve got stock bumpers and I plan on it staying that way for years. It didn’t make sense to me to order the medium weight springs but I decided to listen to the salesman. :/
  16. Jul 28, 2020 at 11:13 AM
    FamRunner
    Michael
    I had the 2.5” coils installed with bilsteins at lowest setting in the front last Friday. I probably ended up with 2-2.25” lift out of them. With the bilsteins at the highest setting and stock coils I was about .5” taller. The back I installed the 1” coils and shocks and have gotten about 1.5” out of them. Have right about an inch of rake, which is fine, but had hoped to be a little closer to level as this was what was recommended for level. My alignment seems to be worse now with only 2.7 degrees of caster on the front right side and only about 2” lift. A little disappointed to lose height and caster, but may take it to the Toyota dealer to see if they can do better on alignment. 3.5” lift with 3 degrees caster and stock UCA’s seems like a reach. I may go with some different UCA’s to see if I can get better caster numbers.
  17. Jul 28, 2020 at 11:52 AM
    Gyoaz
    Gyoaz [OP] Garyo
    AZ
    5th gen 4runner TE
    I still haven't had an alignment done yet. I'm waiting till I add some wheel spacers and replace a tie rod end. I am usually not a fan of spacers but after the lift my track is a little narrow for my liking.
  18. Jul 28, 2020 at 12:44 PM
    Check you lower front spring perches. Sometimes those get flipped upside down accidentally on installation, which results in more lift height than anticipated. If you don't know the proper orientation of those in the first place, post a picture of your lower spring perch as it is right now and we can help out. Hopefully that's the issue since it's a (relatively) easy fix.
    Gyoaz[OP] likes this.
  19. Jul 30, 2020 at 9:03 PM
    #49
    I4CUTigers
    I4CUTigers New Member
    the reason you And the OPie have too much lift was your choice of Strut. Dobinsons 574 Long Travel Strut adds about an inch of lift because of the spring seat as compared to their standard 700 series strut.
    You need a 302 coil with a 574 front strut to net out 2.75-3 inches on the front, stock weight.
    with the 314, you’ve got a 3inch coil at stock weight and then an additional inch due to the strut spring seat, so 4inches of lift after it settles.
    CrikeyMike used to work for Dobinson direct and now runs Exit Offroad selling Dobinson. Very helpful. On another forum.
    ready6delta likes this.
  20. Aug 2, 2020 at 7:00 AM
    #50
    Gyoaz
    Gyoaz [OP] Garyo
    AZ
    5th gen 4runner TE
    Thanks, I did get in touch with Mike on Tacomaworld when I first did my install. He confirmed that once I settled and added my additional weight up front I'd be good. I'm about to pull the trigger on my front bumper, then I'll just be missing the skids to put me almost 300# up front.
  21. May 7, 2024 at 11:10 AM
    #51
    coryanderson
    coryanderson New Member
    Cory
    2018 SR5 4x4 - black and tan
    I'm looking to redo my front suspension and looking at Dobinsons for the shocks/springs/UCAs. Has the lift height settled at all for you?
    I have a LFD Hybrid front bumper with a winch, second battery, and steel skids.
    Thanks!
  22. May 7, 2024 at 7:53 PM
    #52
    With dobinson coils, you have to do an honest assessment of actual additional weight. And even after selecting coils for the new weight, you’ll run a smidge on the high side. It might settle down a little after 10-15k.
    Don’t get coils that are meant for more weight than you actually have as a “just in case”.
    coryanderson[QUOTED] likes this.
  23. May 8, 2024 at 10:55 AM
    #53
    TimGinCentralNJ
    TimGinCentralNJ New Member
    Tim
    '24 Limited in Classic Silver
    TRD Pro rims w/265/70-17 Toyo OC AT3s
    Very cool setup.
    And tell me more about these IPA shocks you're running?
    TimG
