2020 4R Limited, have I got this right?
Discussion in '5th Gen 4Runners (2010-2024)' started by Valtor, Apr 19, 2024.
  1. Apr 19, 2024 at 4:28 PM
    Valtor
    Valtor [OP] Crazy canuck
    UPDATE: Latest build shown here.
    • 4x 32" MotoMaster Eliminator X-Trail A/T - P265/70R17 115T
    • 4x Wheels Replika R213 Satin Black 17x8.0 Offset +5
    • Full skid plates Aluminum
    • Cut front bumper (mostly for looks)
    • Compressor (without a tank)
    • Tire repair kit
    • Air down tooling
    • Switch panel
    • Lights
    • Recovery kit Factor55
    • Recovery Traction Mats
    • GMRS Radio
    • Satellite phone
    • Shovel
    • Fire extinguisher
    • First aid kit
    • Chair
    ------- previous post -------
    Just bought a 2020 4R Limited with 70k KMs.
    First, I'll play around with this thing on super light trails. If I like that experience, then I'll start modding it.
    I'm thinking that the very first thing I should do before doing anything other than super light trails is this:
    1. Buy 17" wheels.
    2. Buy 265/70 R17 AT Tires.
    3. Cut the ugly Limited bumper so that these tires works well without having to lift and to give me more front clearance (and that also exposes the recovery hooks).
    Have I got this right?
    Harringbr99 likes this.
  2. Apr 19, 2024 at 4:29 PM
    Valtor
    Idea for the Limited bumper cut.
  3. Apr 20, 2024 at 4:23 AM
    Valtor
    Since I'm buying new wheels, I should probably go with this instead.
    16x8 wheels
    285/75 R16 Tires
    Because 33" seems a better match.
  4. Apr 20, 2024 at 5:13 AM
    Kezin
    Kezin New Member
    ‘21 and ‘17 Limiteds
    16” wheels will not fit over the calipers. 17” is the smallest you can go. Be prepared to trim and BMC if you go 33s on no lift. It can be done (did it on my 2021), and doesn’t require a front bumper chop
    Harringbr99 and Valtor[OP] like this.
  5. Apr 20, 2024 at 6:02 AM
    Check out what this guy did to his Limited. I think it'll help you with ideas for mods:
    https://www.4runners.com/threads/wh...-gen-4runner-today.2261/page-1044#post-580880
    Valtor[QUOTED][OP] likes this.
  6. Apr 20, 2024 at 8:39 AM
    Sin4R
    Sin4R New Member
    2024 Grey Limited
    If they salt roads where you live, I would start by power washing frame (inside and out) then applying Fluid Film.
  7. Apr 20, 2024 at 9:10 AM
    Valtor
    Thanks for all the advice and it never crossed my mind that 16" wheels would not fit.
  8. Apr 20, 2024 at 12:47 PM
    Valtor
    I was thinking of keeping the tires not too wide.
    So I would opt for 265/75 R17.
    Trimming is no problem, but do you think a need for BMC is at all affected by tire width? (The bumper cut is mostly for aesthetics and to get more clearance)
    That being said, I plan to eventually put a type of suspension that would enable me to raise around 2" (no leveling kit or spacers). Because I am being told I will learn to dislike the Limited's XREAS and might not wish to wait for it to fail.
  9. Apr 20, 2024 at 6:47 PM
    Kezin
    Kezin New Member
    That size doesn’t exist. BMC might not be needed with 255/80/17 but you’ll also be getting E load. Again, offset on wheels will play a huge factor into whether a BMC is needed
  10. Apr 21, 2024 at 5:30 AM
    Valtor
    I was reading about the vehicle modification rules we have here in Quebec and BMC would not be street legal.
    So I might as well do this right the first time and install proper suspension and wheels with the right offset to make having 33" a non issue.
    If I understand correctly, a typical setup would be:
    • Front: Bilstein 6112 (47-310025)
    • Rear: Bilstein 5100 (33-313146)
    This would eventually have to handle the extra weight of armures and steel bumpers.
  11. Apr 24, 2024 at 8:19 AM
    Valtor
    Decided to go with this for my first build.
    • FO-T702FU-BT - Freedom Offroad Billet Front Upper Control Arms
    • RCS767 - Rough Country 2" Lift Kit X-REAS Toyota 4Runner (2" front, 1" rear)
    • Bumpstop Wheeler's Front & Rear SuperBump
    • Tires 285/70 R17 (Yokohama GEOLANDAR X-AT G016)
    • Wheels 17x8.5" backspacing 4.75" offset 0
    • Rock sliders Steel
    • Cut front bumper
    • Tire repair kit
    • Air down tooling
    • Switch panel
    • Lights
    • GMRS Radio
    • Satellite phone
    • Shovel
    • Fire extinguisher
    • First aid kit
    • Chair
  12. Apr 24, 2024 at 8:22 AM
    2021venture
    2021venture New Member
    Todd
    2021 Venture
    Elka 2.5, SPC UCA, durobumps, RCI full skids, RSG sliders, 10 lb Powertank, Maxtrax, Hi lift jack, Westscott Designs modular roof rack and ladder, ARB rear diff breather relocate, ECGS bushing upgrade
    Consider some other UCA besides SPC. They used to be solid but have had quality control issues. I have them now and am replacing.
    Valtor[OP] likes this.
  13. Apr 24, 2024 at 8:25 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    No need to cut bumper. 265/70/17 Wildpeaks or similar fit.
  14. Apr 24, 2024 at 8:28 AM
    Valtor
    It's mostly for looks. The Limited bumper is just too "business men" for me. ;)
    Rocko9999[QUOTED] likes this.
  15. Apr 24, 2024 at 9:23 AM
    Valtor
    Gonna go with these then:
  16. Apr 24, 2024 at 12:51 PM
    Valtor
    According to this video, I am making a mistake.
    Any Limited owners out there that could chime in?
  17. Apr 24, 2024 at 12:54 PM
    joshdub
    joshdub New Member
    2020 TRD ORP
    Replace the limited bumpers with regular bumpers and run 285/70/17 at a minimum
  18. Apr 24, 2024 at 12:55 PM
    2021venture
    Todd
    2021 Venture
  19. Apr 26, 2024 at 4:52 AM
    Valtor
    Based on what I am planning to do, I'm going to go with slimer/higher tires. No need for UCAs.
    • 5x 33" Slim Tires 255/80 R17 (Yokohama Geolandar X-AT LT255/80R17 121/118Q)
    • 4x Wheels 17x7-7.5" offset 14
    • 1x Steel Rim 17x7-7.5" offset 14
    • Tire repair kit
    • Air down tooling
    • Switch panel
    • Lights
    • GMRS Radio
    • Satellite phone
    • Shovel
    • Fire extinguisher
    • First aid kit
    • Chair
    • ??? Geometry fix - Panhard rod kit?
    • ??? Bumpstop - Wheeler's Front & Rear SuperBump
