XM not working "antenna" flashing - 2011 Limited
Discussion in '5th Gen 4Runners (2010+)' started by CoSprings4Runner, Jan 13, 2020 at 6:50 AM.
  1. Jan 13, 2020 at 6:50 AM
    CoSprings4Runner
    CoSprings4Runner [OP] New Member
    David
    2011 4Runner Limited
    3rd row removed, added sliding deck
    The XM Radio on my 2011 Limited 4Runner isn't working. I have the JBL system with navigation. The word "antenna" is flashing and there is no sound at all. Research confirmed the flashing "antenna" meant the radio wasn't connecting with the antenna.
    I pulled the head unit and checked the XM antenna connection which seemed to be fine. The connection was clean and not loose.
    I then purchased a separate XM antenna and adapter, plugged it in, shut down the power to the head unit and restarted. The XM radio still doesn't work and "antenna" is still flashing. Everything else on the head unit seems to be working fine.
    Has anyone else had this problem and found the solution. Thank you in advance.
