Window visor recommendation?
Discussion in '5th Gen 4Runners (2010-2024)' started by kaitlyn2004, Jun 15, 2020.
  1. Jun 15, 2020 at 7:09 PM
    kaitlyn2004
    kaitlyn2004 [OP] New Member
    Looking to get a pair of window visors/deflectors/rain guards for my 4runner (all 4 windows) and wondering if there's a consensus on the best option?
    I naturally went to weathertech, and they've got the set for $160 CDN.
    Initially I very much like/prefer the in-window visors as I didn't really want to use stick-on visors... but I've also never used them before so not sure which is better? I've heard the in-window can cause issues for the window up power function is that an outdated problem or still present?
  2. Jun 15, 2020 at 7:30 PM
    Tama1968
    Tama1968 New Member
    Florida
    I've been using AVS in-channel vent visors on all our SUV's since 1997, never any problems with rolling windows up or anything else for that matter, including the visors on my 2019 4Runner.
    DrewMan likes this.
  3. Jun 15, 2020 at 7:32 PM
    kbp810
    kbp810 rebmem wen
    I used AVS in channel on my taco, no issues with them at all. Just ordered AVS in channel for my 4Runner (arrives Wednesday).
  4. Jun 15, 2020 at 7:47 PM
    kaitlyn2004
    Looks like AVS gets recommended a bunch, then!
    I just looked it up and it seems they have in-channel, stick on, and low profile (which I think are also stick on?)
    Stick on vs in-channel...?
  5. Jun 16, 2020 at 5:46 AM
    Blue 4ever Runner
    Blue 4ever Runner New Member
    2019 Blue 4Runner
    I have the Weathertech in channel on mine and I have no complaints. There is an increase in wind noise though. It's not terrible but be aware that it is there.
  6. Jun 16, 2020 at 8:41 AM
    LA260
    LA260 New Member
    I got the regular AVS. Came in damaged. Returned and got the in-channel version. Again came in scratched. Sent it back for another in-channel and yup, came with nice scratches all over one of the second visor. I'm done with AVS. The way they do the packaging is dumb. When you get it inspect it carefully to insure there are no scratches/scuff marks, specially on the second visor from the top.
  7. Jun 16, 2020 at 12:26 PM
  8. Jun 16, 2020 at 1:43 PM
    peter2772000
    peter2772000 New Member
    Peter
    Montreal/Cape Coral
    2019 TRD Pro
    I have AVS equivalents, Wades, on my FJ. Been on there for 10 years with no issues.
    I have Weathertechs on my new 4Runner. Not crazy about the noise the windows make squeezing into the channel up top. .
    Wind noise all depends on the day. One day I find the damn things noisy at 60mph, the next days I'm wizzing down the road at 85 with nary a sound.
  9. Jun 16, 2020 at 2:29 PM
    08TXRunner
    08TXRunner New Member
    '20 SR5P
    I've got the Weathertechs on my '20. Just like the ones on my '08, you should consider using "industrial strength" 3M double sided tape on the rear ones because that's all that holds them in. The fronts are a combination of tape and tension. I find the super thin 2 sided tape for the rears quickly degrades and they drop out of the channel, particularly at highway speeds.
    MakiOne likes this.
  10. Jun 16, 2020 at 2:33 PM
    Mowerman
    Mowerman New Member
    David
    2020 limited 4Runner
    Have weather tech in channels on my taco. Enjoying them other than the fact that sometimes in hear the glass and wind guards chatter a slight bit because they are “sharing the channel”
  11. Jun 16, 2020 at 3:52 PM
    Cis915
    Cis915 New Member
    Donovan
    Las Vegas
    '18 Nautical Blue TRDOR
    Eibach Pro Lift; 255/80 Open Country R/T Trails; Motegi Trailite; LFD 7/8; BMC/Pinch Welds; All-Pro Sliders; Custom Drawers; T10 v3; DD SS18 Light Bar; Baja Squadron Pro Ditch Lights; Auxbeam Switch; Alpharex Headlights; Spyder Taillights
    Had AVS on my 4th gen with no issues. Have the AVS Low Profile on my 5th, again with no complaints. Something to note with the low profiles though, you can't put the window down as far when it's raining.
  12. Jan 19, 2023 at 1:18 PM
    caz
    caz New Member
    2019 4Runner Limited
    I just bought a WeatherTech 4-piece set for my 2019 4Runner Limited. I had them, second hand, on a 2019 Tundra; I liked them and had them in and out and back in without issue. I would like for them to work on this vehicle.
    But, luckily, I didn't peel the tape off of the back two because I am thinking of sending them back. On the fronts, I have a driver's side window that won't go all the way up - not stuck open too far but far enough to be a problem - no matter how much and how many times I adjusted it. On the passenger's side, my auto window won't go up and comes back down - still the same after 10+ up-and-down cycles.
    Can anyone help, please?
  13. Jan 19, 2023 at 2:01 PM
    Jacket time
    Jacket time New Member
    ^^^ I had that happen on my Forester and Buick. Go Slowwwww.
    Unless the visor is a defect it will work...be sure to keep them up for a day after rolled up.
    Take it out and try over
  14. Jan 19, 2023 at 2:37 PM
    steelevo
    Utah
    I have always used AVS. Just make sure to prep the tape locations before putting them on. Scuff with the supplied pad, clean with the supplied alcohol prep pad, then use an adhesion promoter pad which you'll have to buy elsewhere.
  15. Jan 19, 2023 at 3:08 PM
    caz
    caz New Member
    My thought/alternative was to go to a brand like AVS and do the adhesion. But these are really nice, even if only the front are non-adhesive - of course only if they work!
  16. Jan 19, 2023 at 5:46 PM
    Old goat
    Old goat Trout chaser
    Hudson Valley NY
    5th gen
    Also have much luck with AVS on several vehicles.. add a little wind noise but benefits outweigh this,E5CE2725-FF5D-4E17-9081-A4A15BFC2327.jpg
