Will it STILL rub?
Discussion in '5th Gen 4Runners (2010-2024)' started by TXKK626, Mar 15, 2023.
  1. Mar 15, 2023 at 11:43 AM
    TXKK626
    TXKK626 [OP] New Member
    Fort Wayne, IN
    2021 Venture Edition
    Here's the situation: 2021 Venture with stock suspension. Put on SpiderTrax wheel spacers when I upgraded OEM Duelers to stock size 265/70/17 Falken Wildpeaks at 30k miles. Rubbed. Removed mud flaps, pushed fender liners forward, trimmed lower part of fenders to eliminate rub. Fenders clear, but there's a slight body mount rub on passenger side at full-lock reverse. Occasional in forward going over driveway curb at a tight turn. really like the stance with the spacers on, so I want to keep them. I'm thinking Cornfed leveling might provide just enough space to prevent rub? A little more than level (keeping in mind stock tire size)? I
    Best guesses?
    Anyone set up like this with luck?
    Pictures don't really show it well.
  2. Mar 15, 2023 at 12:56 PM
    ^The spacers are the culprit, causing your tire to swing on a 1.25" wider arc when you steer. Either delete the spacers or keep cutting and do a cab mount chop. 30k miles and 2 year old truck, not a virgin
  3. Mar 15, 2023 at 1:22 PM
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    I myself would remove the spacers. The TRD wheels are already at a +4 offset.
  4. Mar 15, 2023 at 2:13 PM
    tblt44
    tblt44 New Member
    Todd
    Tampa
    2021 4 runner
    N/A
    Ya we fighting a rub with new wheels 8.5 wide with zero offset. No spacers
    Haven't pin pointed where yet. Haven't really tried to hard
  5. Mar 15, 2023 at 3:42 PM
    What's your caster set at?
  6. Mar 16, 2023 at 10:08 AM
    CalcityRenegade
    Matt
    2023 T4R ORP KDSS
    Also, how big is the spacer?
  7. Mar 16, 2023 at 11:08 AM
    Connor MacLeod
    Connor MacLeod New Member
    Connor
    2023 TRD Off Road
    I have those same wheels, spacers, and 265/70 tires (my tires are Cooper Rugged Trek) on my 2023 OR with front Bilstein 5100's set at 1.75" and achieving around 2" actual lift.
    I do not have any rubbing now, although I did have a lot at first. I did not need a body mount chop, although I did a fair amount of front fender trimming with a utility knife after pushing the wheel well liners forward. I also kept the mud flaps and did a mod that I think I invented where I used zip ties and one black washer per mud flap to pull the mud flap snug against the body mount.
    I think adding lift would help you, although some might say it doesn't. Also, after the lift, try to get more positive caster on your alignment specs to move the wheels forward away from the body mounts.
    TXKK626[OP] likes this.
  8. Mar 16, 2023 at 5:18 PM
    rmiked
    rmiked New Member
    Fort Mill, SC
    Has anyone with a stock ORP installed 275/70/17 tires and got NO rubbing? I will have NO spacers and using stock ORP wheels. This size is 10mm wider and at a 70 (stock) aspect ratio, the tire is 0.55” taller (32.16” vs 32.61”). I’m gonna be replacing the Dueler HTs with Goodyear Duratracs. Thanks
  9. Mar 16, 2023 at 5:48 PM
    R1200Jedi
    R1200Jedi New Member
    2022 4Runner ORP
    That's heresy calling it a "cab mount chop"! :p It's only called that on a Taco. On a 4Runner it's a "BMC". :D
    glwood54, Dir4219, djwantke and 2 others like this.
  10. Mar 17, 2023 at 7:13 PM
    HazOpRed
    HazOpRed 22' TRDOR
    lol. Remove the spacers or get trd off road wheels and that will solve your issue
  11. Mar 17, 2023 at 8:45 PM
    Stoney Ranger
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
    275's on the stock snowflake wheels. I had to do the fender tuck. According to Trail4runner.com, the offset is +15.
    Toy4X4 likes this.
  12. Mar 17, 2023 at 8:52 PM
    5six
    5six New Member
    55_4Runner
    GTA, Ontario, Canada
    2022 Black TRD ORP
    I have a local friend with a Limited on TRD Pro rims with 275/70s and fits no issues even with the flexing his truck can do. Although he hates his street ride as his tires only came in E load, so less enjoyable due to firmness.
  13. Mar 18, 2023 at 7:00 AM
    TXKK626
    Fort Wayne, IN
    1.25. I would have gone a bit less, but that’s the only option for SpiderTrax.
  14. Mar 18, 2023 at 7:03 AM
    TXKK626
    Fort Wayne, IN
    The Venture comes with the TRD OR wheels. I think they’re the exact ones the ORP comes with.
  15. Mar 18, 2023 at 7:07 AM
    TXKK626
    Fort Wayne, IN
    Thanks for all the advice. I’ll explore bit more of a lift, but don’t want it to look bad with the stock size tires I just put on it. Might just remove the spacers if I end up getting it off road much. Not a lot of OR options in the area.
  16. Mar 20, 2023 at 8:31 AM
    CalcityRenegade
    Matt
    2023 T4R ORP KDSS
    Those wheels you have are the Pro wheels. Offset is +4 where the OR wheels are +15. They stick out 0.43" further than the OR wheels on their own. With that spacer, 1.68" further. Thus being the cause of the rub as long as there is no issues with other components.
    djwantke and TXKK626[QUOTED][OP] like this.
  17. Mar 20, 2023 at 8:34 AM
    TXKK626
    Fort Wayne, IN
    Thanks for the info on the specs — and the math!
  18. Mar 20, 2023 at 10:57 AM
    Connor MacLeod
    Connor
    2023 TRD Off Road
    That's right, and to my eyes, that extra 1.68" of poke out the sides looks absolutely awesome. :yes: Well worth it in my opinion in exchange for some minor work trimming the fenders, pushing the liners, and nudging back the mud flaps.
  19. Mar 20, 2023 at 11:16 AM
    TXKK626
    Fort Wayne, IN
    Agree, but I draw the line at the body mount chop. Thus my hope that a leveling kit would fix the issue. When I get around to doing that, I'll report back!
  20. Mar 20, 2023 at 12:29 PM
    Connor MacLeod
    Connor
    2023 TRD Off Road
    My '23 OR didn't need the BMC...hoping your rig will not need it either. Good luck!!
  21. Mar 20, 2023 at 12:56 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    I have the same spacers, but 285's and suspension lift nearly 3". I said the same thing when I bought new, I draw the line at BMC... Then I got the BMC done last month $300 CAD cash cut, weld, paint. It's nothing to be intimidated about if you find a decent welder. Leave the spacers on that's why you bought them, especially if you locktited them like me!
  22. Mar 20, 2023 at 1:00 PM
    Hey question for you, I read on Bilstein website you "must" set the 5100's ring at the same position as stock sits, which it the first/lowest position. Is that not true? Then there's 3 settings up, which I'm weary to lift up to cuz it's says it's actually harmful to other components and ride quality
    I have OME 2884 springs. Thanks
  23. Mar 20, 2023 at 2:08 PM
    Connor MacLeod
    Connor
    2023 TRD Off Road
    First, I'll note that I do not know anything about those OME 2884 springs that you mentioned, and they might add lift regardless of which shocks you are running if your rig is not loaded down with a heavy aftermarket bumper or other extra weight.
    Maybe Bilstein's attorneys added that as a CYA statement on the website; I don't remember seeing it on the instructions that came with my Bilstein 5100's.
    With added lift from the 5100's, the suspension will no longer ride at its original factory geometry, and it will cost you some amount of suspension articulation; however, I'm not sure how it would actually harm the other suspension components or noticeably affect ride quality (I didn't notice ride quality effects). You'll want to get an alignment after adding lift, and if you can't get the desired amount of positive caster, you could install aftermarket control arms to address that.
    Adding lift with Bilstein 5100's is a really common upgrade for 4Runner owners, and as a rule, I have not seen this cause problems for people. Also, take what I'm saying with a medium-size grain of salt since I'm not a professional mechanic or suspension expert; I'm just a dude on the internet who spent half a day in my garage about 3 months ago installing Bilstein 5100's at the 1.75" lift setting, and I have been happy with the results so far.
    Gnu_2_4runners likes this.
  24. Mar 20, 2023 at 3:27 PM
    @Connor MacLeod thank you very much for the details. Yes I also have upgraded SPC UCA's. I'm pretty similar to you, taught myself a lot on YouTube. So I found the instructions that detail not adjusting spring seat up. See below. General 5100 description also specifies the ring settings are for OE springs only, but instructions say don't change from stock position, period. I believe my ARB OME springs provide most of the lift themselves. I have minimal added front end weight at the moment, just ARB skids.
    Upon reading more, perhaps this rule doesn't necessarily pertain to offroad 5100's and higher!
    "Deviations in the spring plate height can lead to problems with the pretension (spring plate too low or too high). During compression, there is a risk of the spring going into block (spring plate too high compared to the series) or of the support bearings being destroyed. When the spring is released, the locking assembly, piston rod, support bearings and vehicle dome can be damaged or destroyed.
    Different criteria apply for groove adjustments In the off-road range (BILSTEIN B8 off-road shock absorbers with the suffix 5100 and higher), which is why the off-road shock absorbers may deviate from the series. BILSTEIN Technical Support will be happy to answer any questions you may have.
    https://workshop.bilstein.com/en/groove-adjustment-on-the-shock-absorber/
    Connor MacLeod likes this.
  25. Mar 20, 2023 at 3:32 PM
    Get a bottle of touch up paint for the rockers, your gonna need it. I don’t have spacers and I’m frequently touching up paint chips on the rockers.
  26. Mar 20, 2023 at 4:04 PM
    What rockers?
  27. Mar 20, 2023 at 9:41 PM
    Rocker panels below the doors.
  28. Mar 20, 2023 at 10:07 PM
    Figured. I got bigger dents and chips going on I haven't noticed much there yet. The valance cap eats some of that rock
