Wiil These Work
Discussion in '4th Gen 4Runners (2003-2009)' started by grumpy 02, Feb 21, 2024.
  1. Feb 21, 2024 at 1:09 PM
    grumpy 02
    grumpy 02 [OP] New Member
    Stan
    Colorado Springs, CO
    2007 White 4Runner SR5
    None Yet
    P1020370.jpg P1020374.jpg Wiil these coilovers level my 2007 4Runner, SR5? Will I need to do anything to the rear suspension? If so, will these fit my rig?
  2. Feb 21, 2024 at 4:51 PM
    BassAckwards
    BassAckwards New Member
    2006 4Runner V6 SR5 2wd
    The fronts will work and it may be a little nose high if you’re 2wd. Here’s mine, I just used the same blue 3rd gen Tacoma hitachi front shocks. They will bolt right in no modifications needed
  3. Feb 21, 2024 at 5:08 PM
    grumpy 02
    Stan
    None Yet
    Thanks. Do you know if the rears will fit? The guy is selling both.
  4. Feb 21, 2024 at 6:15 PM
    BassAckwards
    Rears will not fit, lower eyelet is different from what I understand
  5. Feb 21, 2024 at 6:26 PM
    grumpy 02
    Stan
    None Yet
    Thanks.
  6. Feb 22, 2024 at 11:23 AM
    Mymutt2
    Mymutt2 New Member
    Rob
    2003 4runner Limited 4x4 V8
    A Couple
    It is just the lower bushings that need to be swapped on the rear shocks. They will work.
  7. Feb 22, 2024 at 11:29 AM
    grumpy 02
    Stan
    None Yet
    Do you have part # or link to the bushings I would need?
  8. Feb 22, 2024 at 11:40 AM
    Mymutt2
    Mymutt2 New Member
    Rob
    A Couple
  9. Feb 22, 2024 at 11:48 AM
    grumpy 02
    Stan
    None Yet
    Thank you sir.
