Why is Puerto Rico able to use 15W-40?
Discussion in '5th Gen 4Runners (2010-2024)' started by 1776taco, Mar 12, 2021.
  1. Mar 12, 2021 at 4:22 AM
    1776taco
    1776taco [OP] New Member
    2019 Tacoma SR 4x4
    Why is it that Puerto Rico is able to use up to 15W-40 when it says that if you’re in America you better change that 5W-20 out ASAP? Are they just saying that for epa nonsense?
  2. Mar 12, 2021 at 5:52 AM
    thatchtt2001
    thatchtt2001 New Member
    TTT
    Northwest Ohio
    2016 Trail
    Eibach Stage 1 Shocks with OEM Springs.
    Just guessing without reading it's probably the year round hot weather...
    peter2772000, Toy4X4 and Spare Parts like this.
  3. Mar 12, 2021 at 6:14 AM
    mac1usa
    mac1usa New Member
    Yeah that is weird. I have been to PR many times and I know it is extremely humid there even sometimes in the winter time. However, I would not think the humidity is any worse than southern Florida in the summer. Good question.
    1776taco[OP] likes this.
  4. Mar 12, 2021 at 6:32 AM
    1776taco
    2019 Tacoma SR 4x4
    Well it gets between 85-95 on a consistent basis where I live. So if it’s ok for them to use 5-30 there, then it should be okay for me to use it here
  5. Mar 12, 2021 at 6:35 AM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Reading the chart.
    In the US no matter where you live your truck 'could be' subjected to temperatures below 10 degrees. Not so in Puerto Rico.
    olliechristoper and Toffees like this.
  6. Mar 12, 2021 at 6:36 AM
    1776taco
    2019 Tacoma SR 4x4
    So it’s totally fine to use 5w-30 then, and actually preferred, if you’re in a generally warm climate. But it’s weird that it says take the 5w-20 out ASAP. It’s just not making any clear sense to me.
  7. Mar 12, 2021 at 6:39 AM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    The temperature zones speak for themselves. Go by the one that applies to the temps your truck is likely to be subjected to.
    Edit: '0' weight oil assures adequate lubrication at the lowest of temperatures. If the lowest temp your truck will ever see is above 10 degrees, the 15/40 works.
  8. Mar 12, 2021 at 6:48 AM
    1776taco
    2019 Tacoma SR 4x4
    I understand that. But what I’m not understanding is why it’s says to take the 5-20 asap
  9. Mar 12, 2021 at 6:57 AM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Looking at the chart in the first pic, it clearly denotes the widest temperature range which would require the use of 0/30. Thus the statement. imo
  10. Mar 12, 2021 at 7:01 AM
    It's CAFE stuff. Maximum fuel economy at any cost. It's not like the ambient temperature there is higher than normal operating temperature.
  11. Mar 12, 2021 at 7:31 AM
    importman
    importman The mountains are calling and I must go...
    Danny
    Carolinas
    05 Silver SR5 V6 4X4
    Blacked out, Ironman 3" Nitro Gas Suspension lift, JBA High Caster upper control arms, Differential drop and sway bar relocate, Upgraded to Sport Front Cardone Calipers with Brembo Rotors and Akebono Pads, Added Spoiler, Sony XAV-AX100 with Apple Carplay, USB Jack, Backup Camera, Black TRD Pro Wheels with General Grabber ATX 265/70/17, Rear differential vent extension, Auto Dimming Mirror with Compass and Homelink, Map Light Mod, Tekonsha 90160 Trailer Brake Controller, Recoil SL1708 Sub, Sealight LED Headlamps, K&N drop in air filter, Weathertech floor mats, Homemade rear storage compartment with built in pull out table.
    This^^. Plus, I don't know if it's possible that they actually use different piston rings in PR but in the US newer vehicles have lower tension rings to reduce friction or rotating resistance (For the sake of fuel economy). Because of that you have to use a lighter weight oil. In theory anyway, the rings aren't strong enough to consistently wipe the oil from the cylinder walls and you could have oil consumption problems.
  12. Mar 12, 2021 at 7:47 AM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Slopemaster likes this.
  13. Mar 12, 2021 at 7:59 AM
    importman
    Danny
    Carolinas
    If only we had a poster on here who lives in the tropics down below Florida. I bet he could enlighten us on this. ;)
  14. Mar 12, 2021 at 8:02 AM
    I suppose I hadn't considered the possibility of the piston rings being different. If the were the case, I suppose 0W-20 would really be ideal and one should stick to it.
    However, if it were just different due to political BS, then you should be fine to use the guide based on ambient temperature.
    Toy4X4 and 1776taco[OP] like this.
  15. Mar 12, 2021 at 8:36 AM
    SlvrSlug New Member
    I am an old guy that has gone through many vehicles manuals, and they all state that you should choose your viscosity by the temperature of the area in which you live. The recommended viscosity is really only for milage ratings. This is just my understanding of it though.
  16. Mar 13, 2021 at 1:39 AM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    Car manufacturers have been trying to use the thinnest oil possible for years in order to squeeze out the most MPG.
    Whatever data they submit to the EPA for approval of the official published MPG numbers, the EPA dictates that they must make sure the customer uses that same oil. Hence the listing of the 0W-20 in the owner manual. This apparently doesn’t apply to Puerto Rico, they don’t consider it to be a US state, so they can use viscosities that make sense, according to temperature.
    Here’s a good post in another forum thread. Read the EPA letter.
    Laserred96gt and 1776taco[OP] like this.
  17. Mar 14, 2021 at 8:26 AM
    Laserred96gt
    Laserred96gt New Member
    Florida
    I have a lot of Mobil1 and Castrol Edge 10w40 that I found on sale that is going in the 4Runner without hesitation.
    2ffXBwL5gdLK35tUPnU4GewJ1_5_1MMJaS_Y-3Ih_1a5c4f27c2e67f67318e25dc8bf9392e220d7f4b.jpg
  18. Mar 14, 2021 at 10:46 AM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    Where does it say to get the 0-20 out ASAP? Someone mentioned it’s almost always humid in PR, would the thicker oil be able to absorb some water better than a thinner weight? Other than that, I’d say it’s the constant warmer temps, and it would be a big pain in the ass for yota to list out all the warmer places.
  19. Mar 14, 2021 at 10:48 AM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Bingo.
    Spare Parts[QUOTED] likes this.
  20. Mar 14, 2021 at 11:02 AM
    If ambient temperature was really the reason, people in the US should be able to run 0W-20, 5W-20, and 5W-30 year round as well. And, for the most part, we should be able to run 10W-30 and 15W-40 for most of the year according to the chart.
    So, unless there is an actual mechanical difference between US and Puerto Rico motors, I am still convinced that this is nothing more than Toyota doing their part to eek out an extra .0000001 MPG in the name of US fuel economy regulations.
    glwood54, Toy4X4 and A&P like this.
  21. Mar 14, 2021 at 11:13 AM
    Spare Parts
    Southern Maine
    22 LR ORP
    0-20 seems to cover the biggest range, thus covering more of yota’s ass.
  22. Mar 14, 2021 at 11:14 AM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    There's little doubt that what they print has corporate lawyers and CARB rules duly noted somewhere in the fine print.
    This is a topic that's covered from stem to stern in the motorcycle world. In the end it comes down to where you live and where you may venture to. For instance...I may leave my place at 3AM & 105 degrees temps(not kidding) to find myself in the mountains of Az or Co. where the temps are below freezing. Pick the correct oil viscosity for your use - not a group of lawyers or CARB. just my 2c......keep the change;)
  23. Mar 14, 2021 at 11:18 AM
    As does 5W-20 and 5W-30, so why aren't those viscosities recommended as well?
    Agreed!
  24. Mar 14, 2021 at 11:48 AM
    Spare Parts
    Southern Maine
    22 LR ORP
    Cause 0 is 5 less than 5, so there 4, far superior. Seriously, I really don’t know, other than 0-20 will cover the colder range, and help the EPA ratings. Not to mention oil has come along ways since the need to use heavy weight in the summer and thin just to get through the cold months times. Engines are also built with tighter tolerances than those days as well.
    DUSTYDOGDAN and Moon Landing like this.
  25. Mar 14, 2021 at 11:53 AM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    :thumbsup:
  26. Mar 14, 2021 at 1:25 PM
    Right there in bold.
    It has nothing to do with newer oil or engine tolerances, otherwise the same would apply regardless of what country we're in.
  27. Mar 14, 2021 at 1:26 PM
    Spare Parts
    Southern Maine
    22 LR ORP
    Maybe so, maybe not.
  28. Mar 14, 2021 at 1:31 PM
    Like I said, unless there is something mechanically different between US engines and Puerto Rico engines, the chart should be applicable to all 4runners. The only reason for it to be different is due to US fuel economy regulations.
    2Toys and Toy4X4 like this.
  29. Mar 14, 2021 at 1:42 PM
    Spare Parts
    Southern Maine
    22 LR ORP
    It’s possible.
  30. Mar 14, 2021 at 1:44 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    I agree. There is no difference in 4Runners sold in PR.
    Here’s a good article to read that answers a lot of motor oil questions. It’s by Amsoil, and I know some of you are biased against them because of their self promotion and MLM structure, but take a look. It’s long but worth the read.
    http://ultimatesyntheticoil.com/ford-5w20
    SlvrSlug and Thatbassguy[QUOTED] like this.
