Why a front locker?
Discussion in '5th Gen 4Runners (2010-2024)' started by like2lean, Aug 26, 2023.
  1. Mar 20, 2024 at 8:10 PM
    #61
    You're doing this in 4hi right? Can't work harden the grain structure on the surface of the gear teeth if you aren't putting torque through it (whole purpose of gear break-in).
    runnerjimmy likes this.
  2. Mar 20, 2024 at 8:11 PM
    #62
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    In 2WD
  3. Mar 20, 2024 at 8:12 PM
    #63
    ^Beware 2WD won't break-in the front diff gears properly. Hell, the ring and pinion aren't even turning thanks to ADD :laugh:
  4. Mar 21, 2024 at 6:41 AM
    #64
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    @Yotaholic This thread has me jealous.
    Currently trying to talk myself out of 35's and a regear :mudding:
    Yotaholic likes this.
  5. Mar 21, 2024 at 9:21 AM
    #65
    Yotaholic
    Olympia, WA
    Do the 4.88 first even with stock tires lol.
  6. Mar 21, 2024 at 9:22 AM
    #66
    Yotaholic
    Olympia, WA
    Did like 3 miles in 4Hi, dead straight on dry pavement
  7. Mar 21, 2024 at 10:56 AM
    #67
    ^There's some backlash in the Eaton locker from what I read. Also the voltage has to be steady. A voltage drop can weaken the Eaton locker engagement and skip teeth, but that's in higher loaded applications (like 40" tires on a Dana 60).
    Yotaholic[QUOTED] likes this.
  8. Mar 21, 2024 at 11:00 AM
    #68
    You need to do 500 miles in 4hi to break in the front diff. If that's impractical, you can remove the rear driveshaft and putt around in FWD for 500 miles.
    djwantke likes this.
  9. Mar 21, 2024 at 11:14 AM
    #69
    Yotaholic
    Olympia, WA
    You're being a little too much bro lol
  10. Mar 21, 2024 at 11:19 AM
    #70
    Yotaholic
    Olympia, WA
    This is my setup for now.
  11. Mar 21, 2024 at 11:31 AM
    #71
    Yotaholic
    Olympia, WA
    The guy says use 85W140. Thats crazy
  12. Mar 21, 2024 at 11:33 AM
    #72
    2021venture
    2021venture New Member
    Todd
    2021 Venture
    I think that's the recommended weight most re gears. At least for ECGS.
    djwantke and Yotaholic[QUOTED] like this.
  13. Mar 21, 2024 at 11:34 AM
    #73
    Yotaholic
    Olympia, WA
    I am unable to find it.
  14. Mar 21, 2024 at 11:35 AM
    #74
    2021venture
    Todd
    2021 Venture
  15. Mar 21, 2024 at 11:36 AM
    #75
    Yotaholic
    Olympia, WA
  16. Mar 21, 2024 at 11:38 AM
    #76
    2021venture
    Todd
    2021 Venture
    The dino surprised me also. I have always run synthetic.
    Scientifically it has been proven that when measuring diff temps, the actual “metal objects” stay cooler using a quality dino oil with an additive package over synthetic oils. However it has been proven that synthetic “oils” can stay cooler then dino oil. So it depends on what temperature you measure the “metal” or the “oil” hence why both can claim they are better.
  17. Mar 21, 2024 at 11:43 AM
    #77
    Yotaholic
    Olympia, WA
    This is what ai found
  18. Mar 21, 2024 at 11:50 AM
    #78
    2021venture
    Todd
    2021 Venture
    Pumping that thick gear oil is not going to be any fun.
  19. Mar 21, 2024 at 12:24 PM
    #79
    Schlappesepple
    Schlappesepple New Member
    2020 ORP
    The first number is close to the standard diff oil (75/80 whatever), so it shouldn't feel that different in the bottle. It's the second number, how it acts at high temperature where it's thicker.
    So it's not that it's thicker, per se, but it doesn't fall apart at temp. I've used it in a pinch in other gear oil applications, didn't really notice a difference in handling it.
    djwantke and Yotaholic like this.
  20. Mar 22, 2024 at 10:27 AM
    #80
    Yotaholic
    Olympia, WA
    21 MPG driving at 50 miles an hour
    1SilverRunner likes this.
  21. Mar 22, 2024 at 10:44 AM
    #81
    1SilverRunner
    Tejas
    ^Thanks Yotaholic! This is what I've been waiting for!
    RPM and Fuel consumption at 50, 60, 70, 80. Hell 90 if you can swing it!
  22. Mar 22, 2024 at 10:44 AM
    #82
    Yotaholic
    Olympia, WA
  23. Mar 22, 2024 at 10:45 AM
    #83
    Yotaholic
    Olympia, WA
    90 only when I go to Montana ;)
  24. Mar 22, 2024 at 11:49 AM
    #84
    MEski4x4
    MEski4x4 New Member
    2024 TRD Pro
    Did I miss you recalibrating your speedo/cluster for the tire size - without that your dash is useless. You need to manually calculate mileage, and use a calculator to figure out your actual speed.
  25. Mar 22, 2024 at 1:24 PM
    #85
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    I think that's what he does already.
    As to why he sends a photo of the dash when the numbers he manually calculated are different? No idea
  26. Mar 22, 2024 at 1:32 PM
    #86
    Yotaholic
    Olympia, WA
  27. Mar 22, 2024 at 1:46 PM
    #87
    Yotaholic
    Olympia, WA
    That's why I said 21, not 19 that the speedometer says. Larger tires have slowed down my speedometer.
  28. Mar 22, 2024 at 1:56 PM
    #88
    So differential gears generally don’t get some sort of surface-hardening treatment?
  29. Mar 22, 2024 at 2:03 PM
    #89
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    :eek: I'm sure it's not, but that sounds terrifying on my 60k truck lol
  30. Mar 22, 2024 at 2:06 PM
    #90
    Interesting!
