Whistle with TRD intake?
Discussion in 'Performance' started by CollinJ, Jun 8, 2018.
  1. Jun 8, 2018 at 4:05 PM
    CollinJ
    CollinJ [OP] TRD Off-Road
    South NC
    2018 TRD Off-Road Premium
    Bilstein TRD Pro Suspension - TRD skid plate - TRD CAI - AFE Pro Dry Filter - 265/70/17 General Grabber AT2’s - LFD Off-Rod roof bars - Ellis Percision Shift knobs - Canvasback Cargo Liner - Blackout Emblems - Diode Dynamics interior LEDs
    I’m about 99% sure this is normal but wanted to double check.
    Installed a TRD intake on an 18 TRDORP a couple weekends ago, went great sounds awesome. Yesterday I switched the stock paper filter for an AFE Pro Dry and am noticing a slight “whistle” at lower RPMs (basically right when I accelerate.
    I’m pretty confident it’s normal, I did plug the hole in the side and used silicone for the bottom opening.
    Thanks!
  2. Jun 9, 2018 at 3:25 AM
    Bodhi327
    Bodhi327 New Member
    Vic
    2016 sr5
    Check that everything is tight. I don’t get a whistle with mine.
  3. Jun 9, 2018 at 4:19 AM
    CollinJ
    South NC
    I’ll go double check the lid as I just had it off too. Are you using the oem paper filter or a reusable one? I don’t remember hearing it with the paper one
  4. Jun 9, 2018 at 4:23 AM
    Bodhi327
    Bodhi327 New Member
    Vic
    2016 sr5
    I am using the OEM paper for now, the lid is a pain in the butt sometimes to snap on. Overall I really like the set up, I put a borla cat back on also, the combo sounds great.
    KeavyD and CollinJ [OP] like this.
  5. Jun 9, 2018 at 4:25 AM
    CollinJ
    South NC
    I’m going to put the paper one back in, I’m thinking it’s more likely it’s the AFE filter now flowing better. Ya I found it easier to loosen a clamp on the filter top side and the throttle body side to get it off and on easier haha
  6. Jun 9, 2018 at 5:00 AM
    CollinJ
    South NC
    Update.... I added some silicone around the bottom again just to see if that helps but also noticed the little filter checker wasn’t pushed all the way down... that might have been the cause?
  7. Dec 11, 2018 at 9:11 AM
    elnip
    elnip New Member
    Scott
    LC,NM
    2016 4runner Trail P
    I have the same setup as you (w/AFE Pro Dry) and mine doesn't whistle.
  8. Feb 2, 2019 at 8:34 AM
    red 1
    red 1 New Member
    Rob
    Connecticut
    Red 2019 off road premium
    Gibbon Exhaust, TRD Intake
  9. Feb 2, 2019 at 8:35 AM
    red 1
    red 1 New Member
    Rob
    Connecticut
    Just ordered the TRD Intake. It does not come with a TRD high flow filter?
  10. Dec 31, 2020 at 9:34 AM
    clarkyclark87
    clarkyclark87 New Member
    Dallas
    This is an older thread but I just wanted to weigh in and report my TRD Intake does indeed whistle while in second and third gear around 2,000 RPM or so. Don't get me wrong, it is very irritating, especially for a perfectionist like myself. However my passengers never notice it. I am the only person who notices it and honestly now I am used to it and I only hear it when I really concentrate and listen for it. The whistle sound is not overly loud and again it is a very short range i.e 2,000-2,500 RPM in second, third, and maybe fourth gear too.
  11. Jan 20, 2022 at 12:58 PM
    Dangboi
    Dangboi New Member
    2016 4 runner limited
    I had the same whistle noise after installing the TRD intake. Dealt with it for a couple of months until I decided to get the afe throttle body spacer 46-38008, Not for performance reasons. My thought that if it’s breaking the air it should eliminate the high pitch whistle. Turns out that it worked for me and I no longer hear the whistle anymore.
  12. Jun 23, 2022 at 2:47 PM
    Jrunr
    Jrunr 2021 TRD Pro
    Jason
    2021 Magnetic Grey Metallic TRD Pro
    Did you notice anything different, performance wise, with the throttle body spacer?
  13. Jun 23, 2022 at 4:03 PM
    hallcs
    hallcs New Member
    Craig
    Indianapolis IN
    2021 4Runner Venture SE
    Dobinsons IMS 2.5/1.5" Lift, Toyota Raptor Steps, Sprint Booster, Michelin Defenders LTX M/S 255/75/17,. Victory 4X4 Full roof rack and ladder.
    I had a borla cat back on 2019 Silverado, with it being a V8 it purred very nice. Low rumble on start up and when you hit the gas hard, nothing annoying about it and many complements. I was considering a Borla for my 2021 4runner. How would you describe the sound with it being a six cylinder? Did you get the touring muffler?
