Which bump stops? (so many options)
Discussion in '5th Gen 4Runners (2010-2024)' started by SLIVER, Jan 31, 2024.
  1. Feb 8, 2024 at 6:15 PM
    #61
    Regarding number 1. I don’t think there would be an issue with bilsteins that requires you to to get new extended length bumpstops. The bump stops are meant to either limit the the compressed (up-travel of the suspension (when tophat spacers create the need to limit up-travel). Or you could get bump stops if you are constantly bottoming out your suspension due to “full send” style driving over rough terrain.
    Regarding 2: Are you saying you lifted your FJ by putting on taller bump stops? They’re not supposed to lift anything. And if bumpstops lifted your fj, it means your suspension was so sagged out that it was basically collapsed (or maybe you had a broken coil spring or something.
    I don’t know, maybe I’m the one that doesn’t understand something, but as far as I can figure out, getting new taller bump stops is so you can limit your up-travel because you have to (for one reason or another), or because you want to cushion hard suspension hits because your off-roading is hard and fast and you bottom out hard against the bump stops too often.
  2. Feb 8, 2024 at 6:20 PM
    #62
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    All these fancy new bump stops work alot different from the traditional stops. Just a FYI. They are taller, but compress an stop at the same spot as the oem stops. Pretty much it absorbs the impact.
    I'm running the wheeler super bumps in the front. Its a night n day difference. From daily driver to beating it on the trails huge improvement
  3. Feb 8, 2024 at 6:26 PM
    #63
    So, if you need to limit up-travel, does that mean it’s better to put some type of hard spacer on the bump stop to make sure you don’t overcompress (for example, if you have tall tophat spacers on your shocks?).
    Also, do you mean that you can tell a difference in daily driving? If so, that means they being used like they were helper springs right? Do they touch the LCA when the vehicle is standing still? Genuinely curious.
  4. Feb 8, 2024 at 6:48 PM
    #64
    4R Florida
    4R Florida New Member
    Northeast Florida
    2024 4R Off Road
    No. I didn't even know what a bump stop was until yesterday. I did a search and found this thread. My 2WD base model "on road" FJ got its lift by installing the 4WD offroad FJ springs from another FJ. The 4WD offroad springs, and having no front differential weight to compress them, provided the desired lift and level with more lift in the front than in the rear. Of course, I have no idea what has been going on under there for 13 years. I now feel compelled to look under there tomorrow to see. Nothing has broken, but with the exception of a few hard hits over the years, the suspension has not been put to its maximum use either. The hardest of all hits came when my driver side front wheel fell into a hole that 1) I thought I could get around, and 2) Was much deeper than I thought. That is the one that I am almost certain bent my wheel, which is now retired to be the spare.
  5. Feb 8, 2024 at 6:49 PM
    #65
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Yes, they sell bump stop spacers. But I wouldn't recommend anything over .5" top hat spacers
    There's a .5" gap between my lca and the bump stop. (Stock trd pro fox suspension).
  6. Feb 8, 2024 at 6:54 PM
    #66
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Thanks buddy
    Wow your 1/2" away form bump stops at flat ride height
    I understand what you mean that they are squishier and compress more and they're different material and naturally they sit closer to the LCA and make contact often then I'm assuming
    My LCA is collecting dust right now
    McSpazatron likes this.
  7. Feb 8, 2024 at 7:00 PM
    #67
    4R Florida
    Northeast Florida
    2024 4R Off Road
    Mine too. I'm still wondering how we tell if/when we need to change to a different stop or stop distance to avoid damaging something, which is my only concern. Apparently jacking or driving one wheel up a ramp isn't going to tell us the whole truth because it's not a dynamic hit.
  8. Feb 8, 2024 at 7:16 PM
    #68
    Hah
    You're right
    It's possible I'm less close to answer now than to begin with :D
  9. Feb 8, 2024 at 7:22 PM
    #69
    4R Florida
    Northeast Florida
    2024 4R Off Road
    It's a learning process for sure. This is why I want to crawl under my FJ tomorrow to see what has been going on under there. It's a real-world example that has taken some hits over the 13 years. I'm sure that I used a front bump stop when I fell in that hole I mentioned. The wheel went down, hit the bottom of the hole, and then the truck fell down onto that wheel. Slam! I was sure I had broken something.
    Anybody want to mention sway bar bushings? Energy Suspension urethane sway bar bushings was one of the best upgrades I did to the FJ and dirt cheap too. Much better on-road handling with those little guys in there instead of the mushy Toyota factory bushings. Not sure if I'll want something like that in the new 4Runner or not. Off-topic, sort-of, but as long as we are talking about suspension and travel, and handling and everything else, why not toss the sway bar into the mix too? :D
  10. Feb 8, 2024 at 7:38 PM
    #70
    For sure man
    I'm eager to hear what you find
    I know for a fact I need new bushings in at least one location. Add it to the list I can't afford yet
    Extended links are there too
  11. Feb 8, 2024 at 7:38 PM
    #71
    4R Florida
    Northeast Florida
    2024 4R Off Road
    And then there was the time I was in the mountains and parked in a tiny gravel pull-off to stop for pictures. The front of the pull-off was made of stacked railroad ties with a significant drop on the other side. Somehow I overshot the railroad ties trying to get all the way off the road, and WHAM! Down went the front with a bang. I probably hit bottom then too. So, yeah, this could be an issue for me. There probably have been other times I don't remember and I don't want to have to be careful and delicate about it. A bump stop is not an expensive thing and it's easy to modify. I barely got off those railroad ties with the 2WD. It took a while. I will have 4WD this time.
  12. Feb 8, 2024 at 7:48 PM
    #72
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    I have noticed that the lift hurt my flex. But I haven't done anything about it. I am just glad I improved my clearance and angles.
    Before lift, 265/70/R17s
    After lift, 285/75/R17s
  13. Feb 8, 2024 at 7:55 PM
    #73
    Yotaholic
    Olympia, WA
    @Thatbassguy This is another lifted KDSS guy
  14. Feb 8, 2024 at 8:34 PM
    #74
    4R Florida
    Northeast Florida
    2024 4R Off Road
    For anyone who lives in a flat land area (like Florida) and no access to steel ramps, and you want to do a static flex test, an old-style highway overpass may work. Some of them have quite steep concrete slopes underneath. If you approach at the proper angle, you can get quite a test. Just don't roll over. Also be sure to deactivate your side curtain airbags. I assume the 4Runner has the RSCA switch like the FJ Cruiser. Observe:
    https://www.youtube.com/watch?v=UjlJDI4bsDg
    It's a very misunderstood feature with people sometimes saying that deactivating airbags is illegal. No, there is a switch for it in my truck.
    RSCA = Roll Sensing Curtain Airbags
  15. Feb 8, 2024 at 8:44 PM
    #75
    Have you ever looked at your where bump stops contact with LCA's when stuffed there like your drivers side?
    My question is, is our uptravel fully stuffed right there, do suspension lifts bottom out in the shocks before factory bump stops engage
  16. Feb 8, 2024 at 8:45 PM
    #76
    Yotaholic
    Olympia, WA
    They don't fully stuff. I will check things and get back
    djwantke[QUOTED] likes this.
  17. Feb 8, 2024 at 8:47 PM
    #77
    And subsequently on the passenger side there where your tire is floating and fully drooped; in that scenario is our shock fully extended max down travel and "holding up the wheel" like is there stress on your shocks there?
    *technical question, just wondering from an engineering standpoint, iunno how suspension works
  18. Feb 8, 2024 at 8:48 PM
    #78
    Yotaholic
    Olympia, WA
    That's the problem, the passenger side doesn't drop fully, KDSS is the culprit. The shop told me
  19. Feb 8, 2024 at 8:49 PM
    #79
    I see I see, so the shock isn't fully extended out.
    And the KDSS solid link is the prob.
    Ok that case is there stress on the KDSS like what's supporting the weight when "fully drooped" just wondering
    Yotaholic[QUOTED] likes this.
  20. Feb 8, 2024 at 8:57 PM
    #80
    Yotaholic
    Olympia, WA
    At the end of the day, more clearance, more rubber and better angles are more important than an extra inch of flex. I am not worried about it, I still have plenty of flex
  21. Feb 8, 2024 at 9:25 PM
    #81
    I'm more interested in the mechanics & physics behind it all right now. I want to stop making boo boos with this stuff
    Yotaholic likes this.
  22. Feb 8, 2024 at 9:27 PM
    #82
    Yotaholic
    Olympia, WA
    Remove both swaybars and report, we can learn from your experience :)
  23. Feb 12, 2024 at 9:19 PM
    #83
  24. Feb 15, 2024 at 2:36 PM
    #84
    SLIVER
    SLIVER [OP] New Member
    Well after reading all your posts and recommendations and watching a ton of videos I decided to go with Wheeler fronts and Duro extended rears. Should be pretty good for my application I think.
    Thanks for all the tips guys!
    djwantke likes this.
  25. Feb 15, 2024 at 9:36 PM
    #85
    zhpleb
    zhpleb New Member
    2022 ORP, Super White, KDSS
    I just ordered the Perry Parts set, will report back once they show up
    hossler1788 likes this.
  26. Feb 17, 2024 at 8:51 AM
    #86
    Ksny15
    Ksny15 New Member
    Mesa, AZ
    23 TRD Off-Road
    Agree with what you said but it does suck when rock crawling as that extra inch of flex could possibly keep that passenger tire on the ground. Not an issue with a front locker though ;)
