Where can I find a switched power connection?
Discussion in '5th Gen 4Runners (2010-2024)' started by Desert4Runner, Jan 23, 2016.
  1. Jan 23, 2016 at 1:16 PM
    Desert4Runner
    Desert4Runner [OP] New Member
    2015 Silver and Black Trail W\KDSS
    Fuel 18's, Nitto Terra Graps, LED bar behind grill
    I installed a nice LED light bar, used a relay, but for the life of me cannot find a switched 12 volt power connection for the switch side of the relay. Anyone have any guidance?
  2. Jan 23, 2016 at 2:59 PM
    wnelax04sr5
    wnelax04sr5 New Member
    Ethan
    CT
    2004 SR5 4X4 Galactic Gray
    hows the bar powered? i tapped a 12v accessory and spliced a wire in and it works perfectly for my two duallys
  3. Jan 24, 2016 at 5:45 AM
    Desert4Runner
    The bar is powered directly from the battery on the light side of the relay with an inline fuse...I need some easily accessed power for the switch side. Not too excited about digging in under the dash, it is a jungle in there, and nothing is as simple as power and ground.
  4. Feb 7, 2016 at 11:03 AM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    You want switched power from inside the cab, yes?
    Just use an add-a-circuit fuse tap to the fusebox; I believe all the interior fuses are switched acc power. I have an add-a-circuit powering my CB and map light. The relay trigger would draw milliamps so there's no concerns with excessive draw on the wiring.
    Even though we use those stupid super mini ATO fuses the regular mini ATO fuse add-a-circuits work, they are just a bit longer.
