What's a good battery for 1987 4Runner
Discussion in '1st Gen 4Runners (1984-1989)' started by gun papa, Mar 8, 2021.
  1. Mar 8, 2021 at 12:44 PM
    gun papa
    gun papa [OP] New Member
    I live in a cold environment and I am unhappy with my WalMart battery. What is a solid battery for my 1987?
    I don't start the truck all that often as I use another 4x4 for my commute. The battery is routinely low if not started for 10 days. Is it normal drain?
    Once jumped, the battery is being charged at 14 volts from the alternator, so the alternator is working. Maybe I should be starting it more, or there is a drain.
  2. Mar 8, 2021 at 12:47 PM
    canadian.bacon
    Snowland
    ‘22 Tesla Model Y
    Weak battery or drain. How old is the current battery? Start with the easiest one, buy a new battery. Buy a decent brand name and you should be fine.
  3. Mar 8, 2021 at 2:39 PM
    You may need a trickle charger to maintain it, starting the vehicle for 5 or 10 min. Does nothing for your battery, it would need to be driven for 30 min. Or more to make any charge.
    Moon Landing likes this.
  4. Mar 8, 2021 at 3:00 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Normal? Probably so, if it's cold enough. A 'quality' maintainer(not a 20 buck battery cooker) is cheaper than replacing a battery every couple years. In fact, you'll get a noticeably longer life out of a properly maintained battery. If, electricity is nearby? Choices.
  5. Mar 9, 2021 at 10:53 AM
    PhantomTweak
    PhantomTweak New Member
    Patrick
    OREGON
    1999 4Runner, bone stock
    This is exactly why I put Marine terminals on my batteries. I use Optima batteries wherever I can, too. They hold charge like a dream. If I'm not going to start and run the truck within a week or so, I just pop off the negative leads. Unscrew the wing nut and slip the ring terminals on the cables off the post on the marine terminal, put the wing nut back on the post for storage. Until I'm ready to go. Then I can just slap the cables back onto the negative side, and VROOM!
    Away I go.
    From my experience, the Optima gel-cell type batteries do better in cold weather. They seem to maintain more cold cranking amps than "normal" lead-acid batteries.
    Purely anecdotal, but thats my experience.
    Have fun!
    Pat☺
