What size lift do I have ?
Discussion in '5th Gen 4Runners (2010-2024)' started by Davem95, Oct 24, 2024.
  1. Oct 27, 2024 at 12:00 PM
    #61
    BoiseG
    BoiseG New Member
    2024 ORP
    If you're going to stay with the 285/70 then I would lose the spacers and trim the drivers side fender 1 inch. It's likely that you're also hitting the mud flaps, so check there if you're still getting rubbing after trimming the fender 1". Take a look at this video for a comparison between the 34 and 35 inch tires, it doesn't show you how to make the repairs, but it gives a great idea of what to expect for each tire size.
  2. Oct 27, 2024 at 12:25 PM
    #62
    Davem95
    Davem95 [OP] New Member
    Dave
    Columbus Ohio
    2016 sr5 4runner
    Also would the stock sr5 wheels fit a 34x10.5 or do I need a different wheel
  3. Oct 27, 2024 at 12:29 PM
    #63
    Kezin
    Kezin New Member I guess?
    ‘21 and ‘17 Limiteds
    They’ll fit on the SR5 wheels. Keep in mind there are only two tire options in 34x10.5R17. Open Country and KO3.
  4. Oct 27, 2024 at 12:49 PM
    #64
    Davem95
    Dave
    Columbus Ohio
    2016 sr5 4runner
    That’s fine by me I was looking at those two anyways haha , car has open country’s on it as it sits now, I watched a guy in YouTube who is running 3” lift with bmc and was able to fit 285/75/17 with still an inch of clearance heading back towards the body mount , but if you think 34x10.5 is even safer I’ll run that, I’m assuming I’ll need bmc and uca , if so which uca would you recommend
  5. Oct 27, 2024 at 2:05 PM
    #65
    Kezin
    Every aftermarket UCA I have seen has issues. I clearanced for 33s on stock suspension and plan to clear 34s with as small of a lift as I can get away with to try and keep my stock UCAs.
  6. Oct 27, 2024 at 2:23 PM
    #66
    Davem95
    Dave
    Columbus Ohio
    2016 sr5 4runner
    So your thinking stock uca for me as well? I figured you need them to get the right camber for the wheel
  7. Oct 27, 2024 at 2:33 PM
    #67
    Kezin
    You probably do with the lift you want. I just don’t have a recommendation since I don’t plan to use any
  8. Oct 27, 2024 at 2:56 PM
    #68
    Davem95
    Dave
    Columbus Ohio
    2016 sr5 4runner
    What are you planning on doing exactly to accomplish 34’s
  9. Oct 27, 2024 at 3:02 PM
    #69
    Kezin
    Put them on with no springs and cycle the suspension up and down with steering wheel locked. Cut, bend, and weld whatever is in the way. I anticipate a more aggressive BMC and pinch weld hammering/cutting
  10. Oct 27, 2024 at 3:54 PM
    #70
    Davem95
    Dave
    Columbus Ohio
    2016 sr5 4runner
    Why aren’t you wanting to lift it?
  11. Oct 27, 2024 at 4:19 PM
    #71
    Kezin
    I think 4Runners with huge lifts look dumb without 35s or larger. You also lose down travel for every inch lifted on independent suspension. It’s still going to get lifted, but not by 3”. 1”-2” likely
  12. Oct 27, 2024 at 4:50 PM
    #72
    Davem95
    Dave
    Columbus Ohio
    2016 sr5 4runner
    what’s down travel
  13. Oct 27, 2024 at 5:22 PM
    #73
    BoiseG
    BoiseG New Member
    2024 ORP
    Do yourself a favor and research this stuff before you plunk down thousands of $$$. Start with this video.
