What PSI are you guys running?
Discussion in 'Wheels & Tires' started by Stoney Ranger, Apr 21, 2021.
  1. Dec 23, 2022 at 5:53 PM
    Fortuner
    Fortuner New Member
    CA
    2021 4Runner TRD Off Road Premium w/KDSS
    There’s a calculator for this online (tire size.com), here are the results for my specific example (285/70 Load C’s)
  2. Dec 23, 2022 at 6:45 PM
    This calculator is the reason I asked the question. There is no way I'm running 26psi per that calculator.upload_2022-12-23_19-44-25.jpg
  3. Dec 23, 2022 at 6:58 PM
    Lt tires are designed to run at higher pressure. I can't elaborate, though. It's way above my pay grade. :D
    Definitely! Please post pictures of the tread after 40K miles at that pressure. ;)
    Why not? Bigger footprint= increased load carrying capacity. I would try it out, and adjust if it feels too mushy.
    Toy4X4 likes this.
  4. Dec 23, 2022 at 7:00 PM
    Yes, I recommend it to everyone! :cool:
    Toy4X4 and Singleminded like this.
  5. Dec 23, 2022 at 7:03 PM
    Will be annoying to see the TPMS warning all the time and would not notice if there is really a puncture and tire is at low air pressure. so running at regular psi.
  6. Dec 23, 2022 at 7:24 PM
    I ignore the low pressure sign on the dash half of the year, so it wouldn't bug me. But, I'd probably end up at 30-32 anyway. My 285's are LT, so 38 is recommended. I usually run a pinch lower, though.
    kmeeg[QUOTED] likes this.
  7. Dec 24, 2022 at 2:13 AM
    We run Cooper LT's in 275-70-17. In the summer we run 38psi., in the winter we run 36psi. On a trail in the summer we run 26-28-30psi. These pressures are from the experimenting technique, although I used the 'online calculator' for a baseline. Good luck.
  8. Dec 24, 2022 at 9:42 AM
    LT 285/70/17 (C-rated)
    32psi.
    So much more comfortable on the road.
    Recommended psi be damned!
  9. Dec 24, 2022 at 10:16 AM
    Singleminded
    Singleminded New Member
    2020 4Runner Limited
    OEM LED foglights
    I like running a tad on the low side. Basically I set it to the 32 psi cold as recommended on the placard inside the door (I run OEM tire size) but don’t bother when the actual psi drops a little from colder weather or normal leakage. Today I drove off in 11 degree temps and the computer said my tires were at 29/30. Within several miles they were 32. All good. Better than too high in wintry conditions. Plus I think low pressures may reduce steering wheel shimmy. Mine is intermittent anyway, but on the highway today at 32 psi it was smooth as butter.
    mrmike7189 and nimby[QUOTED] like this.
  10. Jan 2, 2023 at 9:08 AM
    itsmerf
    itsmerf lol
    Ryan
    2020 OR
    BP-51 CaliRaised Sliders Prinsu Rack Ugly Method 701's
    285 KO2's running 32-34 cold...no problem going a couple lbs less
    Stoney Ranger[OP] and nimby like this.
