What is the part?
Discussion in '4th Gen 4Runners (2003-2009)' started by jpennington43, Jan 26, 2021.
  1. Jan 26, 2021 at 1:24 PM
    jpennington43
    jpennington43 [OP] New Member
    2004 4Runner Limited V8
    Any help identifying this part on the lower suspension? It's loose and rattling pretty bad. Easy to replace for an average garage mechanic / above average Youtuber? lol
    Newbie here, go easy. Thanks!!
  2. Jan 26, 2021 at 1:42 PM
    oceanslide
    oceanslide New Member
    Oceanside
    2021 4Runner
    Looks like a bump stop
  3. Jan 26, 2021 at 2:07 PM
    doublewide
    doublewide New Member
    TRD OR PREM
    Bump stop.
  4. Jan 28, 2021 at 10:26 AM
    y=mx+b
    y=mx+b New Member
    2005 SR5 v6 4wd
    Yep its the front bump stop. The thin metal part above the actual stop itself is nut shaped, so you should be able to tighten it up. If not and it just keeps spinning, then the weld nut in the frame is broken and you'll need to weld a new one in or use a rivnut to make new threads
  5. Jan 28, 2021 at 11:31 AM
    kbp810
    kbp810 rebmem wen
    Hopefully you can just tighten it up... put some big channel locks on it and turn till tight. Though as said above, it's also highly plausible that the nut up top has broken loose... it's a somewhat common occurrence (even happened to me on my '19). There's also not a ton of room to work with for welding that little nut back into place... and that's assuming it's not rusted/seized to the bolt. personally, I'd just sawzall the whole bumpstop off, and replace with new, and just throw a flange serrated nut on the inside for it (that is if the nut is indeed broken off).
    y=mx+b likes this.
  6. Jan 28, 2021 at 11:46 AM
    Todi
    Todi New Member
    Maryland
    2018 4Runner TRD Off-road
    M.O.R.E. aluminum skid set; Artec aluminum gas tank skid and LCA skids; C4Fab rear diff skid; HeftyFab Banshee front bumper; RezFab flat sliders; SSO rack; 285/70-17 E Falken AT3W; Ironman 4x4 Foam Cell Pro Stage 3
    Also, looks like you are hitting this bump stop a lot (no dust on the LCA) so you may need new front suspension
  7. Jan 28, 2021 at 11:55 AM
    kmeeg LionRunner
    What do you guys run? I'm thinking of these to protect my shocks. But looks like they have a big lead time.
    Some times my kids play come out when I see a bump on trails.
  8. Jan 28, 2021 at 12:24 PM
    y=mx+b
    y=mx+b New Member
    2005 SR5 v6 4wd
    Yeah the nut on the back with a wrench is actually probably the best, I don't know how I didn't think about that lol! Yeah not that I think about it welding a nut in that area would be trick, and I not remember I did see someone drill a hole in the bump mount and weld the nut in that way. I'd say OP go for the nut on the back side if it broke off
  9. Jan 31, 2021 at 8:06 AM
    jpennington43
    Thanks all ... yep the nut on top has broken loose. I'll do as KBP mentions and just cut it off and use a flange serrated nut on the top. Yep Todi, time for some new suspension.
    Where can i get an aftermarket bump stop the same size?
    Thanks guys!
