What is going on with my hard brake line
Discussion in 'General 4Runner Talk' started by Trekker, Mar 12, 2025.
  1. Mar 12, 2025 at 5:46 PM
    Trekker
    Trekker [OP] Regular Member
    1997 3rz 5spd
    I did some extended braking and the Toyota brake hoses I installed 3 months ago appeared to have started leaking for some reason/ There is a coating o them that appears to have started leaking. What should I should I do?
    [​IMG][​IMG][​IMG]
  2. Mar 15, 2025 at 8:45 AM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    I think I see tool marks on the nut. Seems this has been apart-'maybe careless handling dinged/bent the "flare" end and incorrect torque to reattach?
  3. Mar 15, 2025 at 9:17 AM
    Photon_Chaser 64,721 smiles and counting…
    West Coast to the Sierra Mountains
    Considering the amount of visible contamination (fine dirt/sand particles) on those fittings I would take a fine wire brush and clean out the threads on the compression nut. Clear out the internal threads using a Q-tip. Any fibers left is an indication of thread damage which could lead to incorrect/insufficient torque when re-establishing connection between the fittings.
    It is extremely important to keep every aspect of hydraulic fittings exceptionally clean when assembling.
