What have you done with your 4runner today....
Discussion in '5th Gen 4Runners (2010-2024)' started by jwest, Mar 16, 2021.
  1. Jul 20, 2025 at 11:54 AM
    #61
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    drove the 4r with the fam to the hardware store for kids bedroom paint, they have a big mural out front!
    mom’s driving our oldest son (4 yrs) in “the big truck” to a preschool friends birthday party, which is sure to be awkward and painful lol.
  2. Jul 20, 2025 at 12:54 PM
    #62
    Nice outing!!!!
    So, what do you have here, yellow arrows pointing?
    excuse the poooor arrows!
    djwantke[QUOTED] likes this.
  3. Jul 20, 2025 at 12:57 PM
    #63
    Thanks bud, it was fun, sometimes that’s not the case cuz the kiddos turn on me!
    What are those fender flares you ask?
    Allow me to shamelessly plug my own thread.
    I also sanded down the inner fender white paint, and painted the them black along with their fender liner fasteners.
    scottiezilla and Saker[QUOTED] like this.
  4. Jul 20, 2025 at 4:35 PM
    #64
    Gman2530
    Gman2530 New Member
    2018 SR5 4wd 4Runner
    Watched sunrise over desert, took a siesta in mtns & found a giant rock rabbit or dog or?IMG_5612.jpg IMG_5635.jpg
  5. Jul 21, 2025 at 12:30 PM
    #65
    94hokie
    94hokie New Member
    23 TRD ORP Lunar Rock
    Drove it to Discount Tire (yet again) to try and get these Wildpeaks balanced. 3oz on front drivers, 1.5oz on passenger front. But did park by my truck's twin.
  6. Jul 21, 2025 at 2:04 PM
    #66
    Interesting.
    Goodluck with the Wildpeak balancing!
    I’m interested in at4w’s next, but, I may have to stick with Mickey Thompson cuz I don’t think I’ve seen a single person report steering wheel shake and balancing probs with MT.
  7. Jul 21, 2025 at 2:25 PM
    #67
    94hokie
    94hokie New Member
    So I didn't have steering wheel shake, it was more like a seizure. You get up to 60 or so and you could actually see the steering wheel go crazy, you had to have a firm grip to keep it in a straight line. Honestly I think its pretty ridiculous as this is the 3rd or maybe 4th time they've balanced the wheels (stock ORP wheels, not aftermarket) yet they keep doing this. These will probably be leaving me here soon, even though there's only maybe 8k on them.
  8. Jul 21, 2025 at 3:55 PM
    #68
    speedevil
    speedevil New Member
    Dale
    2015 4runner SR5
    Installed a Viofo A329 dash cam on my 2015 SR5P. The front camera slides off to the right, so I mounted it on the right side of the mirror mount. I remembered to check that the lens was in the windshield area that is swept by the wiper. Next is to mount the rear camera, and for now I'll tape the cable to the headliner. Once it's been installed for a week or so with no issues, I'll hide the cable and install the hardwire kit. While the A pillar trim piece is off, I'll also install the grab handle bracket and then the driver's side grab handle.
  9. Jul 21, 2025 at 4:24 PM
    #69
    dang that’s intense, and surely quite frustrating after dropping good money.
    I’ve read a few threads regarding balancing issues where a member has seemingly gotten to the bottom of the source of the issue, and or determined the true correct course of action for these problems… And it’s not just a road force balance being done. I don’t remember the exact fix, but some people here have finally achieved success with the crazy steering wheel shake
  10. Jul 21, 2025 at 7:48 PM
    #70
    1963 Volkswagen Beetle steering wheel damper and subassembly helps.
    jk, :mudding:
  11. Jul 23, 2025 at 7:07 AM
    #71
    w4terwiings
    w4terwiings New Member
    2023 Lunar Rock 4Runner ORP
    The seat warmer for the pizza got a laugh out of me. Why didn't I think of that :bowdown:
    icebear, djwantke[QUOTED] and Saker like this.
  12. Jul 25, 2025 at 8:25 PM
    #72
    ZillaPrime
    ZillaPrime New Member
    Austin, TX
    Guppy1301, JET4, Imdav2u and 2 others like this.
  13. Jul 25, 2025 at 8:29 PM
    #73
    Good looking T4R!
    ZillaPrime[QUOTED] and Gman2530 like this.
  14. Jul 25, 2025 at 9:25 PM
    #74
    Imdav2u
    23 TRD PRO
    Nice truck, welcome to the club.
    ZillaPrime[QUOTED] and Saker like this.
  15. Jul 28, 2025 at 6:15 AM
    #75
    Wife and I drove the 2011 to the gym.
  16. Jul 29, 2025 at 6:27 PM
    #76
    Imdav2u
    23 TRD PRO
    Took my daughter's stuff to be hauled to Tucson so she can abandon us next week to go get her stupid PhD.
  17. Jul 29, 2025 at 6:37 PM
    #77
    You sound like a proud, papa!
  18. Jul 29, 2025 at 6:42 PM
    #78
    Imdav2u
    23 TRD PRO
    She graduated in May with majors in Bio Chemistry and Math with a minor in Spanish and zero debt Now off to U of A for her PhD in Chemistry. Luckily she gets her intelligence from mom and not dad.
  19. Jul 30, 2025 at 3:49 AM
    #79
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    Enjoy the road trip! My girl is going to be a G.A. at Austin Peay State University and working on her Masters in Health and Human Performance: Performance Enhancement and Coaching. Like yours, no College debt and smarts from Mom.
    Imdav2u[QUOTED] likes this.
  20. Jul 30, 2025 at 4:31 AM
    #80
    Beachguy
    2024 TRP ORP
    This is nearly the exact setup I used when my daughter went to OU for her PhD. My ‘21 4Runner was white and I rented a U-Haul from Conroe, Texas to Norman, OK. The only 2 differences were mine was an SR5P, and the U-Haul was a single axle and I had a blowout somewhere in the middle of nowhere OK. Made it to the shoulder safely and U-Haul’s roadside assistance was very quick. We were back on the road in less than 45 minutes. Like your daughter, mine had zero debt, and today she has “Research Scientist” in her job title. Way to go dad! I know exactly how you feel!
  21. Jul 30, 2025 at 6:31 AM
    #81
    Imdav2u
    23 TRD PRO
    It's easy when you have kids who are driven. Gotta be proud.
    Saker likes this.
  22. Jul 31, 2025 at 10:05 AM
    #82
    Drove the 2011 to fill up with Ethanol Free gas.
    Imdav2u likes this.
  23. Aug 8, 2025 at 3:47 PM
    #83
    Drove the 2011 to Kohl's to buy school clothes for the Grandkids.
  24. Aug 8, 2025 at 10:31 PM
    #84
    You don,t have to come to this thread if it bothers you.
  25. Aug 8, 2025 at 11:29 PM
    #85
    Brilliant idea! Now on my ignore list, doesn't even show up in the 5th gen list now. Thanks for the idea! Buh bye.
  26. Aug 23, 2025 at 12:59 PM
    #86
    4r transported new hockey net home from a lady down the road via fb marketplace.
    it didn’t fit on the roof basket but I said f*** it
  27. Aug 23, 2025 at 1:20 PM
    #87
    R1200Jedi
    R1200Jedi New Member
    2022 4Runner ORP
    How are the dog claws on the floor of the X Mid? As tempting as those UL tents are, I always camp with my pup, and I'm worried about the floors with anything other than a Hilleberg. lol
  28. Aug 23, 2025 at 2:32 PM
    #88
    94hokie
    94hokie New Member
    Drove it to Harbor Freight last weekend for their sidewalk sale, picked up a new floor jack and jack stands.
    djwantke likes this.
  29. Aug 24, 2025 at 7:27 AM
    #89
    HuskyMike
    HuskyMike New Member
    I was worried about it too when I first started backpacking with the dogs, but we've had no issues so far. Been in quite a few tents. We've camped in a Copper Spur UL2, UL3, Tarptent Notch Li, Tarptent Stratospire Li and now the XMid.
    The Notch and Strat had dyneema floors. After reading something Dan (Durston) said about dyneema floors being less durable, I got the XMid with the woven (silnylon) floor.
    From hiking, the husky's nails are not sharp, so there's not too much risk poking through the floor (v.s. sharp sticks etc). That being said, I bring a z-fold pad for their side of the tent. They do "dig" every now and then inside the tent before laying down. I have to stop that quickly because that would surely destroy the floor material- regardless of the type.
    Dog's IG if you're interested in seeing more pics of them where we've backpacked: https://www.instagram.com/max._.and._.mika/
    If you have the money to spend, the UL tents can be a great option. If for nothing else, they don't absorb water during rain, heavy condensation etc. While I like the freestanding aspect of our Copper Spurs, you can't shake the moisture off of them like you can the dyneema tents.
    R1200Jedi[QUOTED] likes this.
  30. Aug 24, 2025 at 11:19 AM
    #90
    R1200Jedi
    2022 4Runner ORP
    I appreciate the feedback. It's good to know that those lighter materials can still hold up OK. It puts them back in the running for me. Mu currently backpacking tent is the Hilleberg Enan, which is quite light, but I'm really not a fan of non-freestanding shelters, and I've thought of replacing it. I had a Copper Spur many years ago, and it was a good tent, but I would be worried about its longevity as well.
    PS- great photos of the pups! Looks like they've had quite the adventures. :D
    HuskyMike[QUOTED] likes this.
