What engine oil weight/Brand do you run
Discussion in '5th Gen 4Runners (2010-2024)' started by tblt44, Dec 28, 2022.
  1. Jan 20, 2025 at 7:07 AM
    #61
    Taylor21554
    Taylor21554 New Member
    Naples Florida
    24 SR5 4x4
    Valvoline EP 0w-20, previous oil was 5w-30 I alternate each oci 5k, sometimes earlier because I get bored on sundays.
    Actually changed mine yesterday… dealer definitely torque the aluminum drain cover on tight… and the oil filter housing. That being said, I have to get a new one because I don’t like the fact that the 3/8 drive socket is now stripped.
    I should be able to get the little drain plug cover? Or do I need to buy the whole deal? Want to stick with the plastic housing
    Guppy1301 likes this.
  2. Jan 20, 2025 at 7:14 AM
    #62
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    The drain cover at the bottom of the filter can be bought separately. I broke mine the very 1st oil change I did because some clown over-tightened it. I keep a spare now, too. Torque value is only 9ft. lbs. for that cover.
  3. Jan 20, 2025 at 7:38 AM
    #63
    2016Pro
    I always use one brand..... the cheapest synthetic i can find and change every 10k miles. The engine will go at least 700k miles if you do this.
    RUNNER4DAN likes this.
  4. Jan 20, 2025 at 9:52 AM
    #64
    RUNNER4DAN
    Daniel
    Doesn't need any
  5. Jan 26, 2025 at 1:26 PM
    #65
    DesertSurfer
    BS67 likes this.
  6. Jan 27, 2025 at 8:21 AM
    #66
    Sioux
    Sioux New Member
    Wisconsin
    2020 TRD Off Road
    SuperTech 0w-20 from Walmart and OEM Toyota filter. I switched to the SuperTech in my Tacoma after having run Mobil 1 and doing a Blackstone oil analysis of the two. If you change every 5k, there's no reason to spend more on a different brand of full synthetic. It won't make a difference.
  7. Jan 27, 2025 at 9:02 PM
    #67
    Greg D
    Greg D TJ312
    TJ312
    2013 4runner
    Mobil 1 5w30 high mileage and Toyota filter every 10k. Or 15k. It is 20k oil now. It stays so clean and engine is dry at 230k still. Keeps engine clean. Dirtier the oil, cleaner it is inside and no sludge, no oil use at all. The higher the mileage, the better the engine runs. Mine has finally started to free up more and is more responsive and usually 1/2 + mpg every 80-100k of mileage.
