What do I need to do do fit 33s on a 5th sr5 premium
Discussion in 'Wheels & Tires' started by 124runner, Mar 14, 2023.
  1. Mar 14, 2023 at 11:13 AM
    124runner
    124runner [OP] New Member
    Just bought a 2022 sr5 premium, what do I need to do to fit 33s. Leveling kit?
  2. Mar 14, 2023 at 12:24 PM
    I don't want to be that guy, but do a quick search. 33 (285/70/17) is the most popular size for these, pretty much every day there's a new thread on this very subject.
    There's a few variables depending on what tire and wheel you want to run, and what you want to do with it.
  3. Mar 18, 2023 at 2:30 AM
    5six
    5six New Member
    55_4Runner
    GTA, Ontario, Canada
    2022 Black TRD ORP
    Depends what you mean by 33? Technically most 285/70s are less than 33”, but a 255/80 are 33”. Pizza cutters supposed to be less modifications, better with stock rims, less stress for steering, less mpg impact, maybe risk of stiffer ride due to only E load vs SL or C load being offered for 285s. I’m going through this dilemma now on which way to go.
  4. Mar 19, 2023 at 8:37 PM
    MountainMan
    MountainMan New Member
    Pacific Northwest
    I went the cheapest route possible and bought a Daystar KT09134BK 2.5" lift off of Amazon for $100 or so. I installed it myself and was able to fit Cooper 285/70/17 Evolution MTs on stock rims...
    Then I switched tires to the Goodyear Wrangler UltraTerrain in the exact same size, but they are actually a true 33" tire and on the stock rims, required a little bit of trimming.
    And then when I went to an aftermarket rim that was 9" wide with a -12 offset, it was extreme rubbing...
    But, with stock rims or stock rim width and offset specs, you can run most brands of 285s with a cheap 2.5" spacer lift and retain stock ride quality and not stress anything.
  5. Mar 28, 2023 at 9:39 AM
    Sejin
    Sejin New Member
    2017 Super White SR5
    Fitment for every 4Runner is going to be a little different. Some people will say "no rubbing" some will say they had to make some cuts. Generally, wider tires and/or negative offset will require trimming(trim front bumper/BMC).
  6. Mar 28, 2023 at 9:58 AM
    This SR5 got ReadyLift 3in front & 2in rear kit running BFG KO2 285/70R17 on stock SR5 wheels. No BMC, No plastic trimming, No removal of mud flaps. Had some rubbing on lower part of the front bumper but after couple of trail runs looks like the tires did the trimming on behalf :p
    I had the same lift on my SR5 but I didn't like the rear shocks topout on trails.
  7. Mar 29, 2023 at 11:57 AM
    I just did mine last week. Eibach pro 2 coil overs and Toyo AT3s 33's.
    Accelerator and Trail Runnah like this.
  8. Mar 29, 2023 at 12:12 PM
    Lift doesn't clear tires, unless you never leave pavement.
    33's can be usually cleared with a good alignment and some plastic trimming.
    SlvrSlug likes this.
  9. Apr 2, 2023 at 3:16 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    From experience I'd recommend doing a level of minimum 2" in the front, get the 285/70R17 (don't do the more rare extra wide sizes), 9" or under rim width, most importantly stay away from large negative offset rims those trajectories rub.
    Worst case scenario, everybody is capable of deleting their front mud guards, and getting their hands on a dremel to slightly trim bottom of front fender.
    5six and TrailSpecial22 like this.
  10. Apr 3, 2023 at 4:28 PM
    2” bilstein 5100 or 6112 lift in front will clear it.
  11. Apr 10, 2023 at 9:49 AM
    JosephD
    JosephD New Member
    Joseph
    Austin, Texas
    19' Barcelona SR5
    Eibach stage 2, Cali-Raised sliders
    Do you know if he has aftermarket UCA's? I'm in a similar situation, I just lifted with Eibachs lift kit (3" front/2" rear) on my Sr5 (with SR5 wheels)
    Was he able to get proper alignment on 33's?
  12. Apr 10, 2023 at 9:57 AM
    Stock UCA. Pretty much even at Toyota dealership when this ReadyLift kit is installed stock UCA is used. I don't remember any complains of alignment. This is a low cost lift. Since you have a better lift "Eibach lift kit" with 3in front its def a good thing to have good UCA.
    I will see if he has done any alignment recently and get the sheet.
