What can cause the acceleration to jump/sputter a bit?
Discussion in '3rd Gen 4Runners (1996-2002)' started by djrines023, Jun 15, 2015.
  1. Jun 15, 2015 at 11:51 AM
    djrines023
    djrines023 [OP] New Member
    David
    1999 Green 4Runner Limited
    My 99 4runner just hit 200,000 miles and it has a slight sputter when you are accelerating currently. I am using some fuel cleaner to see if something is going on in the fuel lines and I feel like it has got better, but its still happening. Thoughts from anyone? Spark plugs or fuel filter issue???
  2. Jun 19, 2015 at 12:09 AM
    Utah
    Utah Misanthrope
    Land of Fake Beer
    The Gray Bastard
    3RZ, OME, 5.29s, 4.7, locked/locked
    Hard to say over the internet. Fuel, spark plug, coil pack, bad compression, could be a lot of things. If there's no codes and no clues in the way it idles, maybe pull the spark plugs and see what they tell you. While they're all out, do a compression test.. If one or two are different than the others, that can be a sign. If they're all good and the compression numbers check out, that makes a fuel delivery issue more likely, maybe?
  3. Jun 24, 2015 at 7:33 PM
    RideFast
    RideFast New Member
    Jesse
    ABQ NM
    1999 4Runner 4x4
    B&M tranny cooler, 5'' deck plate, Airaid MIT
    Replace your spark plugs, wires and PCV with oem and give the TB a good cleaning.
    My Truck had the same spudder/hesitition. The wires were the last thing I swapped out and low and behold the wires were the culprit.
  4. May 3, 2016 at 7:44 PM
    willie2323
    willie2323 New Member
    willie
    1999 Black Runner
    Every now n again I need to clean my MAF sensor, especially when I return from Moab. I realize this is a late reply but it could be that simple.
