Westcott or Eibach springs
Discussion in 'Suspension' started by hutch993, Feb 25, 2022.
  1. Sep 5, 2023 at 1:38 PM
    Juan2022
    Juan2022 New Member
    Juan
    RGV
    2022 4 Runner TRD Pro
    None
    Would the springs and a 1/2” Cornfed spacer be a good setup?
  2. Sep 5, 2023 at 2:50 PM
    TCW1184
    TCW1184 New Member
    23’ 4R TRD Pro
    Seems like you'd be getting 2" from that in addition to the stock bump. So 3" total? Might be fine, but i'd just stick to the springs personally.
  3. Sep 5, 2023 at 4:25 PM
    agreed, use springs to lift and not spacers.
  4. Sep 6, 2023 at 10:56 AM
    Juan2022
    Juan2022 New Member
    Juan
    RGV
    None
    Was saying because Westcott spacer lift gives you 2” in addition to your already 1” pro stock suspension, with a total of 3” lift since we’re comparing both kits.
  5. Dec 1, 2023 at 6:12 PM
    Bentwrench
    Bentwrench New Member
    Western Washington
    After having installed both the Westcott collar/spacer kit, and the Eibach Pro Lift coils on a '23 TRD PRO, I would personally only use the Eibach's.
    Options were limited for the '21-23 model years, due to the pigtail configuration of the factory springs that fit the Fox struts, but after installing the Westcott kit, I noted contact points on the coils of both driver and passenger sides while cycling the suspension to full droop. While not a particularly hard contact in the garage on jackstands, in a real world scenario with a heavy tire and wheel mounted, and a sudden drop-out situation, I suspect some damage would be possible to the coils and/or the upper ball joint/UCA. Additionally, the top hat spacer requires that shorter nuts and red loctite be used on the upper strut studs, resulting in fewer threads being engaged, which also made me a little uneasy.
    I think the contact problem could be mitigated by "clocking" the springs slightly off from the factory orientation, but if you were to take your truck in for alignment or suspension service, it's likely that the techs would rotate them back to factory position, possibly without telling you. I will also say that I called Westcott directly to see if they had any suggestions for a remedy of the problem I mentioned, but they never returned my calls.
    I had no fitment issues with the Eibach lift coils, and they have performed phenomenally.
    Here are some pics of the Westcott kit installed;
    kolter45 likes this.
  6. Mar 23, 2025 at 11:48 AM
    michow87
    michow87 New Member
    2024 TRD Pro Underground
    Overland Outfitters did another awesome video comparing mid-budget shocks. They did one on the low budget and high budget shocks already. Looks like the Fox TRD Pro OEM shocks out performed the Elka 2.0 IFP, Bilstein 6112/5160, Dobinsons MRR, and Ironman Foam Cell Pro!
    https://youtu.be/ElT8NALDllE?si=dFaopEmrX6u_uSKm
    They also did an in depth review of the Fox TRP Pro OEM shocks and mentioned how the Westcott kits changed how the shocks performed in a negative way.
    https://youtu.be/COiX4NIpnkg?si=Y7ojl4g2Rokmylfw
    Seems like Eibach is the way. This thread has been going for a while. Appreciate everyone who has given their input. My decision is made on Eibach!
    TxTRD, nimby and Bentwrench like this.
