Went to get oil change and transmission fluid was drained.
Discussion in '5th Gen 4Runners (2010-2024)' started by amazzuca, Feb 8, 2021.
  1. Feb 12, 2021 at 6:30 AM
    Agent_Outside
    Built 2011 T4R Limited
    You’re half right, however, that’s not practical on a lot of today’s vehicles. The 4Runner has a dipstick they should check it, but there’s vehicle with drawn out oil check processes, for example full operating temp then 2 minutes of idle time then turn it off and pull the dipstick and allow it drain down for exactly 5 minutes then check the level - that’s your process for an accurate reading. A lot of cars have gone away from dipsticks in general and use sensors with an MMI display. Check the oil is part of doing the job correctly, but it doesn’t fit the quick lube business model.
  2. Feb 12, 2021 at 6:35 AM
    Red_5
    Red_5 New Member
    How did the crank case take 12 quarts? Wouldn't it have been overflowing well before then?
  3. Feb 12, 2021 at 10:10 AM
    DGP1961
    DGP1961 New Member
    2018 SR5 Premium
    Well obviously it needs to.
  4. Feb 12, 2021 at 10:23 AM
    Agent_Outside
    Clearly they don’t need to, you just want them too. Its cost/benefit, the time saved rushing through it and throwing in a specific capacity is apparently worth the occasional screw up. They are in it for money, not customer service.
