Weird Exhaust Smell?
Discussion in '4th Gen 4Runners (2003-2009)' started by Elmo the Destroyer, May 2, 2018.
  1. May 2, 2018 at 10:38 PM
    Elmo the Destroyer
    Elmo the Destroyer [OP] New Member
    Nathan
    OKC Area
    2007 Black 4Runner (2wd 4L V6)
    Hey all, Elmo the Destroyer is acting up, but I think it could be my fault. I sawed the 90 degree elbow off of the intake and removed the charcoal air filter, but left the normal filter. At normal operation parameters, everything works fine, but there's a weird smell when I floor it. Could this be because of the missing charcoal filter, maybe I'm burning dirty air? My other thought is perhaps I need to change my fluids, because I often shift through the gears manually and this might be wearing out the transmission. Please advise.
  2. May 8, 2018 at 7:47 AM
    wnelax04sr5
    wnelax04sr5 New Member
    Ethan
    CT
    2004 SR5 4X4 Galactic Gray
    this is a typical 4th gen thing, if you google "4runner rotten egg smell" you'll see examples. Its totally normal, if you pay attention you may actually smell it from other cars in front of you. mine did it all the time and never had any issues
  3. May 9, 2018 at 7:19 AM
    Elmo the Destroyer
    Nathan
    OKC Area
    Thank you! I plan on doing a small amount of exhaust work (e.g. dumping that weird bend around the rear axle.)
    I'll update if that does anything to the smell.
  4. May 19, 2018 at 5:57 PM
    themixr
    themixr New Member
    Tony
    06 4Runner
    Rotten egg smell sometimes is bad cats.
  5. May 21, 2018 at 8:08 AM
    easyeatlanta
    easyeatlanta New Member
    2004 v6 4x4 OME Toytec Spidertraks SPC BFG KO2s 285/70/17
    I just rerouted my exhaust and it helps a lot. You smell it more so in the 4r because the exhaust goes straight out the back and wraps up with the wind.
    alittleoff likes this.
  6. Jun 9, 2018 at 7:35 AM
    Whiskeyrunner
    Whiskeyrunner New Member
    Rolf
    2004 Limited V8 - Silver
    Tool storage, external hi-lift jack mount, deciding on lift
    Just joined up but have been on some other forums... Nice work, I plan on the same routing, but contemplating a whole new custom exhaust.
