Water pump???
Discussion in '3rd Gen 4Runners (1996-2002)' started by Junebug, Dec 15, 2017.
  1. Dec 15, 2017 at 4:58 PM
    Junebug
    Junebug [OP] New Member
    2000 4runner limited 4x4
    Hello all, I truly hope I'm explaining this correctly...my power steering and alternator belts broke and well the pulley the fan is connected doesn't turn, my bf says "the water pump is bad" I refuse to believe that, is a new pump with maybe 30,000 miles on it and 700.00 to fix it. So, my question is is it really the water pump? Which I thought the timing belt drive the water pump, at least I think that's what I recall from changing my timing belt bout 40,000 miles ago?...
    Any tips or info, I'm really not wanting to do the water pump. Also, if I do should I really Change the timing belt again as well?
    Thank you and I hope all of this makes sense to everyone.
  2. Dec 19, 2017 at 8:07 AM
    Texoma
    Texoma IG: @triplecchopshop
    ChrisTopher
    Lago Vista, TX
    13 T4R
    Just bought dat bish
    If you have the 3.4L, then yes, timing belt turns the water pump. You'll know if the water pump is bad because it will leak through the weep hole, and at that point you'll need to replace it along with the timing belt.
  3. Dec 19, 2017 at 8:08 AM
    Texoma
    ChrisTopher
    Lago Vista, TX
    13 T4R
    Sounds like you just need a new fan pulley.
  4. Dec 19, 2017 at 10:48 AM
    Roman
    Roman New Member Vendor
    Roman
  5. Jan 14, 2018 at 11:34 AM
    markrwals
    markrwals New Member
    1998 4runner SR5
    I agree with the other comments. I am a diesel mechanic by trade and I just recently replaced the timing belt myself. The fan pulley provides one of rotation points for the belts and the only thing they power steering and alternator belts have in common, aside from the crank. The water pump is driven by the timing belt and does not drive the fan belts
  6. Dec 7, 2022 at 9:08 PM
    Yolo.Dennis
    Yolo.Dennis New Member
    Dennis
    1998 Toyota 4Runner sr5 4x4
    What does a bad Fan clutch pulley or bracket sound like? I have this awful sound that I can’t find. Changed the fan clutch and it’s still there and it’s in the fan clutch area and I was thinking it’s the pulley for it, just don’t know what it sounds like. I can post a video of my 4Runner. If anyone can help that would be so helpful!!!
