Water inside rear hatch 2016 4Runner Ltd worried
Discussion in '5th Gen 4Runners (2010+)' started by Fertman7, Jul 6, 2018.
  1. Jul 6, 2018 at 3:15 PM
    Fertman7
    Fertman7 [OP] New Member
    Rich
    2016 Forerunner Limited
    Been loving my Forerunner but the other day after a heavy rain I lifted up my rear hatch and heard a swishing noise inside it. Was devastated and wondered how the heck did water get inside the hatch and will my electrical system now be eternally affected ? I drained the water out by pulling the inner hatch hand space out a little. The next day I took it to my dealer and they verified the passenger side drain opening was clogged. After a heavy rain today there was no swishing or obvious water inside the hatch. Still concerned though as how could Toyota engineer a hatch that would take on water internally especially with electric components inside the hatch. Dealer told me they tested it and it was fine but my concerns continue. Please advise. TY
  2. Jul 8, 2018 at 10:55 AM
    4X4Runner
    The left coast
    That happens. My old neighbor had a Neon that had the drain holes plugged with debri and he had about 3 gallons of water in there when he finally drained it.
    All doors and hatches will take on water and naturally drain provided the holes aren’t plugged or clogged, they can’t completely seal around the window. If you pulled the plastic off the door you’d see that there is a plastic sheet glued to the metal that separates the metal from the plastic trim on the hatch and the electrical is all weather proofed.
    If you open every door and look towards the bottom of them you’ll see a few holes that appear dirty, that’s the drain holes.
    rsimi72 likes this.
  3. Jul 23, 2018 at 6:16 AM
    Ethanol Red
    Ethanol Red New Member
    When you change the air filter, poke the holes with a small stick-like tool. I used to incorporate this into my routine maintenance on an old Mustang that was notorious for it. Had an old Plymouth that had plugged drains for cowl. That was a mess.
