Vibration at 60+ when veering right
Discussion in '4th Gen 4Runners (2003-2009)' started by Skoglunc, Sep 18, 2018.
  1. Sep 18, 2018 at 1:39 PM
    Skoglunc
    Skoglunc [OP] New Member
    Chris
    2004 4runner daily driver
    Have had a humming/vibration in the steering wheel and I can hear it when I hit 60 and it continues up through around 73. I have replaced the left hub bearing, both axle joints, and had tires/wheels rebalanced and rotated and it's still there. If I am going completely straight or left it's smooth as can be; it's only when I and going right at all.
  2. Sep 19, 2018 at 8:57 AM
    Plastics Guy
    Plastics Guy New Member Vendor
    anything that falls off...
    Its sounds to me like the only other component that could be a culprit that has not been replaced is the inner or outer tire rod ends. I would think its highly unlikely but you've already replaced the most likely issues like the wheel bearing, tire rotation.
    grab your tire at 9 o'clock and 3 O'clock Position and rock the wheel back and forth and see if you can detect any movement in those Tie rods.
  3. Oct 2, 2018 at 3:24 PM
    Skoglunc
    Chris
    tie rods are fine. The weird thing is when I get the tires rotated/re-balanced, it gets slightly better but it continually gets worse over time...which would make me think tire or wheel...but I have had them rotated several times and even cross rotated and it's still always when I'm turning right at highways speeds and I can feel it in the steering wheel.
  4. Oct 8, 2018 at 5:31 AM
    RonT4R
    RonT4R New Member
    Ron
    Virginia Beach
    2007 4runner SR5 4WD
    Wheel bearing?:notsure:
    SlvrSlug likes this.
  5. Oct 9, 2018 at 9:31 AM
    Skoglunc
    Chris
    Have already replaced the left front hub bearing, the whole unit. That’s the side the vibration is coming from.
  6. Oct 9, 2018 at 10:35 AM
    RonT4R
    RonT4R New Member
    Ron
    Virginia Beach
    Possibly a bad replacement??? I would jack up that side and see if there is any play in that hub and spin the tire and listen.
