Useable Highbeam light output? (2020+ High + Low beam LED 4Runners )
Discussion in '5th Gen 4Runners (2010-2024)' started by kmeeg, May 24, 2021.
  1. May 24, 2021 at 10:08 AM
    kmeeg [OP] New Member
    I was just wondering if there's a way to get a proper / useable high beam output for 2020+ Limited & Pro 4Runners?
    Thinking if there's a way to use the DRL location for a proper highbeam upgrade? May be add separate 9005 wire harness and add a relay with a switch on dash? So I can run a good LED bulb for a proper high beam light output? (I'm thinking GTR Ultra 2 LEDs. I love them from my TRD ORP)
    Ideas please?
    Why I'm thinking to change it?
    I feel like pre-2020 4Runner with stock halogen high beam is much brighter than this LED high beam. I personally think the LED high beam lacks in useable light output.
    Why I don't want to change to an after market headlight housing?
    I like the stock look and to me spending $1000 ish for a headlight housing is not worth. I would use it for auxiliary lighting.
    How about adding a stealth Lightbar?
    I looked at DRZ Offroad hidden light bar and I love the looks. Also seem to have a better light output than Diode dynamics dual SS6 or Headlight Revolution Vision X XPL. But It require to drill holes and remove the center bumper support bracket (near the hood latch). Any requires drilling and cutting is a no no for me.
  2. May 24, 2021 at 7:49 PM
    Vito Corleone
    Vito Corleone New Member
    Georgia
    2022 4Runner ORP
    Current Mods: 3/2 Lift Kit w/Billstein 5100’s SPC Front Upper Control Arms 285/70/17 Michelin Defender LTX TRD Pro Wheels TRD Pro Grill 20% Tint on Windows & Sunroof Pedal Commander Cold Air Kit LED Front Turn Signals Brite-Box Anytime Foglight Kit “Tail as Turn” Rear Turn Signal Kit LED Reverse Lights LED Tag Lights LED Puddle Light Pods Sequential Turn Signals N-Fab 3” Step Bars Future Mods: In-Car Camera System Rear Molle Panel Storage System Magnuson Supercharger (when available)
    I installed the Brite Box on my 4Runner last week which allows me to run the low beams, high beams, and fog lights all at the same time. That pretty much solved my problem.
    kmeeg[OP] likes this.
  3. May 24, 2021 at 8:31 PM
    That's the pretty good system I should check.
    I also want something that throws light at distance.
  4. May 24, 2021 at 8:48 PM
    Weird. I'm pretty sure my low beams and fogs stay on when I hit the brights. Was this something that got changed for 2020?
    FWIW, I am running Osram Nightbreaker Unlimited bulbs in my high beans and pretty satisfied. When I'm really in the boonies, I sometimes use the bumper light bar as my high beams.
  5. May 24, 2021 at 9:51 PM
    When you hit brights the fogs will turn off as stock. On Tacoma's there's a relay mod you can keep the fogs on with brights. For 4runners it's quite a process and that brightbox seems to be a solution for that.
    I really wish on 2020+ Pro and Limited I can use Nightbreaker or something good. Sadly they they seem to use the same low beam bulb as high beam. I don't know how exactly they work but I guess they have an additional light chip for highbeam or some mechanical thing to release the cutoff line. It's really BAD even facing a wall. I was pretty disappointed driving on a rural road.
    I wish I could use the bulb in the reflector as highbeam. Just like other trims or all of pre 2020 4runners. Right now that bulb is only used as DRL. To me personally that's pretty dumb and a big waste of that reflector.
    If I could find a high beam wire I could easily tap that and add a highbeam bulb in that and probably use the current drl wire for some kind of "raptor light" or something for drls.
  6. May 24, 2021 at 11:14 PM
    4runningMan
    4runningMan New Member
    New Mexico
    Really disappointed in the OEM led situation from the reviews I’m seeing here on the forum. Seems they just kinda tossed in a mediocre solution that might initially seem like an upgrade for the last two years of the 5th gen run.
    The one thing that’s always bothered me about factory led’s is you just don’t have any other options if they suck. You’re kinda stuck with them.
  7. May 24, 2021 at 11:16 PM
    4runningMan
    New Mexico
    OP does your daytime running light bulb remain lit when you have high beams on? What is the bulb size? (9005? H11?)
  8. May 25, 2021 at 6:28 AM
    I just double checked (even though I have pics on post #1), Nope, daytime running light bulb turns off when headlights are on.
    I did not remove the bulb and compare, but I think its a 9005 bulb just as other trims.
  9. May 25, 2021 at 8:59 AM
    4runningMan
    New Mexico
    Interesting. I wonder if the reflector is the same as in other previous housings. It’d be cool if it was as simple as an inline resistor or something to get you 65 watts like previous years.
    kmeeg[QUOTED][OP] likes this.
  10. May 25, 2021 at 12:06 PM
    Visually it looks same as pre-2020 4Runner headlight housing.
  11. May 25, 2021 at 3:07 PM
    4runningMan
    New Mexico
    Gotta be potential there for an upgrade. But I’m an idiot when it comes to electrical.
  12. May 26, 2021 at 12:38 PM
    So far I found few things;
    1. DRL on 2020 + TRD Pro (I bet its same for Limited) is same 9005 as other models (including pre 2020)
    3eP0wFU3pCgjr_kc6z-QBQJUKR3aGI3L0Fq1PF6j_b2233f6c88e088d5fe8f817225f5426285091215.jpg
    2. When one of the DRL Bulb is removed the other DRL stopped works. (I guess the wiring is in series). I might have to use something else to power DRL option (I'm thinking of grill mounted raptor lights or something like that.)
    3. I found an old HID wiring controller which I would use for DRL to High beam conversion.
    This would be a slow project and I would share my finding and progress as I get time.
    4runningMan likes this.
  13. May 26, 2021 at 2:07 PM
    memario1214
    memario1214 Hotshot Offroad Staff Member Vendor
    Colton
    Missoula, MT
    There's a couple of options out there that just launched from Diode Dynamics. Maybe one of these options will help you out :notsure:. Both will certainly be an improvement over what you currently have, and provide some real down-road performance.
    I'll actually be having a sale on them beginning tomorrow (I'm new to 4R but I am all over on TW).
    Manu links:
    https://www.diodedynamics.com/stage...ightbar-kit-for-2014-2021-toyota-4runner.html
    https://www.diodedynamics.com/stealth-lightbar-kit-for-2014-2019-toyota-4runner.html
  14. May 26, 2021 at 2:18 PM
    I do like that upper grill kit and wish it had that DRL option like Vision-X ones have. So I could add an additional high beam bulb + 2 upper grill lights bars with DRL function.
  15. May 26, 2021 at 2:20 PM
    memario1214
    Colton
    Missoula, MT
    Could! Excuse my ignorance, but is the new 4Runner setup the exact same housing except that the halogen projector was replaced with an LED unit? Ex - The guts of the old high beam section is still the same as far as reflector angles and such are concerned?
  16. May 26, 2021 at 2:27 PM
    Low beam projector is changed from halogen to support new LED and no more I see opening for low beams. And that same projector is used as low beam and high beam for TRD Pro and Limited 2020+.
    So now that bulb in the reflector is just used as DRL (not functioning as highbeam). So my plan is to utilize that reflector for an additional highbeam and find some other option for DRLs.
  17. May 26, 2021 at 2:29 PM
    memario1214
    Colton
    Missoula, MT
    I was just wondering if the reflector design in the now DRL pocket is shared with the 2014-2019s. In other words, if you DID get a high powered bulb in there would the output coming form that location be the exact same as the high beam from the older trucks? If I am making no sense here just lemme know lol.
  18. May 26, 2021 at 2:35 PM
    The reflector looks same as 2014-2019s and the DRL bulb is same 9005 used in 2014-2019 high beams.
  19. May 26, 2021 at 2:37 PM
    memario1214
    Colton
    Missoula, MT
    Nice! Well in that case... SEND IT. Since you are running a dedicated harness you may as well up the wattage of the bulb that you put in there too.
  20. Nov 8, 2022 at 10:08 PM
    4runningMan
    New Mexico
    Did anyone ever make progress on this DRL “upgrade”?
  21. Nov 9, 2022 at 5:05 AM
    Kezin
    Kezin New Member I guess?
    ‘21 and ‘17 Limiteds
    There’s a few other threads out there diving into the same thing. Couple of notes:
    1. The reflector has changed so it is not legally a high beam reflector anymore. Probably zero people will notice/care so not really a huge deal.
    2. Fuses for the high beams are unchanged (both 10A for earlier models and later models)
    3. 9005 extensions can be had on Amazon for less than $10
    You could tap the high beam wire that goes into the combined high/low beam plug and just run it over to the DRL. Find a new ground for each and should be good to go. I am sure someone will correct me if that’s a bad idea, but I don’t see why it would be since the fuses are the same and therefore the wire gauge should be the same. The shutter on the combined projector probably doesn’t even draw 1A. I would not upgrade the bulb at all with that setup though.
  22. Nov 9, 2022 at 5:40 AM
    HotelMedicis
    HotelMedicis No Commercial Interests
    On my 2023 both the low and high beams are LED and are in one single module. The old high beam location is now exclusively for the DRL. If you want more light, buy the 2023 LED module from Toyota and replace your low beam LED module with it. The 2023 LED high beams are VERY bright.
  23. Nov 9, 2022 at 5:47 AM
    Here's what i have done.
    1) Changed the DRL reflector to 2nd highbeam using a separate switch.
    (What about DRL? Using raptor style 2 grill lights)
    https://youtu.be/vesGHtosIHk
    2) Added 2 Diode dynamic 6 in light bars to the top grill to work on the same 2nd highbeam switch.
    https://youtu.be/NZTH8pdBtVU
    3) (need to post a video) Added 2 spot lights to work with the same switch.
  24. Nov 9, 2022 at 6:45 AM
    LuLu
    LuLu New Member
    Utopia
    2022 TRD Sport
    Off road use ?
  25. Nov 9, 2022 at 11:51 AM
    Kezin
    Those aren’t new. They are the same as the previous years with LED high and low. The older 9005 halogen dedicated high beam is brighter than the high beam from the combo low/high
  26. Nov 9, 2022 at 11:58 AM
    I almost thought 2023 bi-leds are better than 2021 bi-leds. So they are the same? I was about to ask someone in my CO group if I could come to do a quick video of 2023 bi-led highbeam vs 2021 bi-led highbeam.
  27. Nov 9, 2022 at 3:25 PM
    Kezin
    There’s already been three versions of the 2014+ headlights. They aren’t going to redesign the already great LED projector in an aging platform
