Under hood lighting
Discussion in '5th Gen 4Runners (2010-2024)' started by Imnrgman, Aug 28, 2019.
  1. Aug 28, 2019 at 6:05 AM
    Imnrgman
    Imnrgman [OP] New Member
    2018 4runner limited
    3 inch lift
    Any recommendations for lighting for the engine bay. I cant believe that Toyota didn't put lighting under the hood.
    Recommended lights? Wire? Switches?
    Install notes.
    Thanks in advance.
  2. Jan 18, 2024 at 9:31 PM
    bronzestar1
    bronzestar1 New Member
    2023 Limited magnetic gray with redwood interior
    275/55-20s, Airaid CAI, Summit muffler, oil catch can
    Resurrecting an old thread, but I just ordered this LED light strip kit from Amazon, should have it in a few days. I'll post up more info once it's installed. There are two things I like about this kit: one, the fuse is on the power side; and two, it has a manual switch, so you don't have install the plunger switch.
    Amazon.com: Under Hood Light Under Hood Led Light Kit for Car Engine Bay Led Light kit Car Hood Work Lights Inspection Lights with Automatic On/Off, Universal Fits Any Vehicle 12V 1Set : Automotive
  3. Jan 18, 2024 at 10:05 PM
    I use a flashlight or a headlamp to admire my engine at night. ;)
    Actually a magnet attached work light would be a simple solution that you can position where it’s needed.
    icebear and LCJ77 like this.
  4. Jan 19, 2024 at 8:57 AM
    Rox4R
    Rox4R New Member
    JT
    2023 4Runner ORP
  5. Jan 19, 2024 at 9:04 AM
    Rox4R
    Rox4R New Member
    JT
    2023 4Runner ORP
    Fu3lC3ll, Firesq14 and Borracho Loco like this.
  6. Jan 19, 2024 at 9:18 AM
    Rox4R
    Rox4R New Member
    JT
    2023 4Runner ORP
    My guess is if you don’t want to use the magnets to activate/deactivate the light you can just get a a simple hood switch from Amazon and hook it up that way also.
  7. Jan 19, 2024 at 9:31 AM
    coryanderson
    coryanderson New Member
    Cory
    2018 SR5 4x4 - black and tan
    I just bought some of those KC Cyclones for the exact same purpose and to check out the lights. I wired up one to check it out last weekend and I need to tap the second one. I'll take some pictures this weekend. It's really nice. I almost want to add 2 more just because!
  8. Jan 19, 2024 at 10:18 AM
    Rox4R
    Rox4R New Member
    JT
    2023 4Runner ORP
    Not sure if new kits are magnetic attachment or is that just Aiden’s kit.
  9. Jan 19, 2024 at 10:24 AM
    coryanderson
    Cory
    It's an optional kit:
    https://www.kchilites.com/cyclone-v2-led-light-magnetic-mount-2pc-1372.html
    I was able to install mine using longer plastic push pin thingys. I think I'm going to add some rivet nut inserts and make it a little more permanent and off-road proof.
    https://www.amazon.com/gp/product/B09C5PKBXL?ie=UTF8
  10. Jan 19, 2024 at 11:14 AM
    Rox4R
    Rox4R New Member
    JT
    2023 4Runner ORP
    Nice, yeah rivnuts would make it pretty solid especially if doing some hard wheeling. I’ll probably use the magnet set up as my driving is a bit more tame.
  11. Jan 19, 2024 at 11:57 AM
    Emmantik
    Emmantik New Member
    Coquitlam, British Columbia
    2015 Magnetic Grey SR5P
    KC Hilites;
    coryanderson likes this.
  12. Jan 19, 2024 at 12:22 PM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
  13. Jan 19, 2024 at 12:24 PM
    Rox4R
    Rox4R New Member
    JT
    2023 4Runner ORP
    Nice set up emmantik.
    Emmantik likes this.
  14. Jan 19, 2024 at 12:29 PM
    Emmantik
    Emmantik New Member
    Thanks! I like hidden wires for a clean setup. More pics of the backside;
  15. Jan 19, 2024 at 12:31 PM
    coryanderson
    Cory
    Interesting. You mounted it straight to the fabric/insulation. I didn't think of that.
    djwantke likes this.
  16. Jan 19, 2024 at 1:01 PM
    Emmantik
    Emmantik New Member
    Ya didn't want to drill any holes
  17. Jan 19, 2024 at 1:19 PM
    coryanderson
    Cory
    Yea, I get that. I used one of these out of this kit and it worked OK. I pulled on the light pretty hard and it didn't get yanked out, but I still want to add some rivetnuts and a bolt to hold it securely. I have this image in my head of the light falling and getting caught in my fan shroud area.
    https://www.amazon.com/dp/B01MEHSLZT
  18. Jan 19, 2024 at 2:10 PM
    Rox4R
    Rox4R New Member
    JT
    2023 4Runner ORP
    That’s all good info as I didn’t think mounting it there would actually work.
  19. Jan 21, 2024 at 1:29 PM
    coryanderson
    Cory
    I added my second light and intended to add the rivet nuts but learned my tool doesn’t have the adapter for the #5 rivet nut fits. So I bought this and it comes tomorrow.
    AIUITIO 8" Rivet Nut Tool, Rivnut Tool Kit with 9 Metric and SAE Mandrels, Nutsert Rivet Tool Set with 90Pcs Rivnuts, Sturdy Case Packed, Designed for Tight Space https://www.amazon.com/dp/B09W216HZS
    I also used different retainers when I put the skirt back up. I used “skirt blind rivets” instead of the factory retainers to make it easier to pop down.
    I have 2 more of these KC HiLites coming too. I want to see how 4 lights does. I’m hoping it illuminates the ground area in front of the 4Runner.
    I also ran the wires to the same switch as my compressor. I figured this was an easy way to save a switch and likely using both at the same time anyways. The compressor only takes 2 seconds to shut off if you’re not using it.
  20. Jan 21, 2024 at 1:49 PM
    Rox4R
    Rox4R New Member
    JT
    2023 4Runner ORP
    Nice,
    Was it easy to pop the clips of the hood insulator? I just don’t want to start prying on them and have them break as I’ve done that before.
  21. Jan 21, 2024 at 2:08 PM
    coryanderson
    Cory
    Most of mine broke but I intended to replace them with something different anyways. The ones I put in are the same ones you find all over the fan shroud area, just smaller diameter.
  22. Jan 21, 2024 at 6:56 PM
    Engine Compartment Light Mod
    This was so easy, efficient and wasn't expensive!
    No drilling, pulling down hood insulator...... just run some wires and install a led strip. po8HbjR6j_0ba20d49112515e9a24b7f088a873e5a8fc4df55.jpg
  23. Jan 21, 2024 at 7:30 PM
    bronzestar1
    That's what I'm planning on doing. The LED strips that I have on order have the fuse in the power wire, instead of the negative wire, so those will get spliced together and run to battery positive. I'm thinking of not using the plunger switch, and splicing the ground wires together and go thru a regular on/off switch, then to ground. I'll mount the switch in an obvious spot under the hood, so it'll be easy to find even when it's dark.
    Saker[QUOTED] likes this.
  24. Jan 22, 2024 at 7:50 PM
    coryanderson
    Cory
    Rivet nut tool came and I went a little crazy with it.
  25. Jan 23, 2024 at 1:03 AM
    Startrek
    Startrek New Member
    What exactly we are fixing in an emergency at night out in an open? Just asking trying to figure out do I need this mod or not.
  26. Jan 23, 2024 at 5:07 AM
    jdm-v35
    jdm-v35 New Member
    CO
    2018 4runner TRDORP, 2019 Audi RS5
    Magnuson Supercharger etc.
    If you don't go far out into the pitch black nowhere or use an underhood compressor its probably not worth doing. I have a compressor under there and also had a breakdown in the middle of nowhere at night while in double digit negative weather so I am installing some lights as it will be a lot easier to work on it if that happens again.
  27. Jan 23, 2024 at 6:38 AM
    flight
    flight New Member
    I've had the kc lights with the plastic push pin things for a few years no, heavy off-road with no issues. Rivnuts are a bit much here :muscleflexing:
    Superuseful when you need them. My biggest problem is finding a switch that will survive in dust in the engine bay
  28. Jan 23, 2024 at 7:12 AM
    coryanderson
    Cory
    Definitely don’t need it, but this forum isn’t for needs. It’s for wants. Haha.
  29. Jan 23, 2024 at 7:13 AM
    coryanderson
    Cory
    100% overkill. Took me 10 minutes once I had the tool in my hands though.
    flight[QUOTED] likes this.
  30. Jan 23, 2024 at 10:11 AM
    bronzestar1
    Like the old saying goes: "it's better to have it and not need it, than to need it and not have it". Seems that engine bay lighting has gone the way of ash trays, and with modern LED lighting, they draw hardly any voltage for their light output. I'm sure most of us carry a flashlight or something similar in our vehicles, but having hands-free lighting in the engine compartment is an added plus.
    Borracho Loco, icebear and Saker like this.
