UCA recommendations
Discussion in 'Suspension' started by 4RunnerGuy916, May 1, 2023.
  1. May 1, 2023 at 7:12 PM
    4RunnerGuy916
    4RunnerGuy916 [OP] New Member
    Looking to buy a UCA for the 4Runner with my new lift set up. My new lift will be bilstein 6112/5160 about 2.5/2 inch lift. I was looking at JBA UCA but heard it will rub the UCA with 285 my rims offset are 0 I’m trying to avoid spacers.
  2. May 1, 2023 at 7:27 PM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    I run element hard parts billet UCA’s. Not cheap, but worth it.
    4RunnerGuy916[OP] likes this.
  3. May 1, 2023 at 10:58 PM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    I have icon bullet. Do not go with icon billet.
    Edit: to add some color here. For some of the adjustability you need to remove the UCA, guess, reinstall and check. Then possibly have to remove and adjust and guess again. That's absurd, time consuming and expensive.
    DBow14 and 4RunnerGuy916[OP] like this.
  4. May 2, 2023 at 4:47 AM
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    Very happy with my Old Man Emu UCA's.
  5. May 2, 2023 at 5:50 AM
    totmacher
    totmacher New Member
    Daniel
    West TN
    2018 SR5 Nautical Blue
    done some stuff to it
    I have Dirt King UCA but will likely be putting stock uca back on. Stock was good enough with my 2.5/2 lift. Not happy with DK uca long term.
  6. May 2, 2023 at 5:55 AM
    4RunnerGuy916
    Thanks for your input was so close to pulling the trigger on some Dirt King also
    Nchaps21 likes this.
  7. May 2, 2023 at 6:05 AM
    Commited
    Commited New Member
    Oscar
    So Cal
    2019 Silver Metallic TRD ORP
    Tinted fronts, blacked out overlays.
    I have JBA’s with 0 offset wheels and running 285/70/17 tires. They do not rub. I did delete the front mud flaps and pushed in the plastic in front inner wall.plastic tho.
  8. May 2, 2023 at 6:14 AM
    4RunnerGuy916
    Nice. Did it rub the body mount?
  9. May 2, 2023 at 6:16 AM
    Commited
    Commited New Member
    Oscar
    So Cal
    No BMC required.
  10. May 2, 2023 at 6:18 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    I also have jba uca but with -12 offset and there's a ton of room to the uca.
    As for the rubbing on the body mount. I know alot of people will say their running 285s with out chopping the body mount. Since I'm running a small lift(1.5") I just chopped it. That way I dont have to worry about it. But since your running 0 offset wheels it SHOULD clear.
  11. May 2, 2023 at 6:46 AM
    jdm-v35
    jdm-v35 New Member
    CO
    2018 4runner TRDORP, 2019 Audi RS5
    Magnuson Supercharger etc.
    I have had the dirt king tubular arms for about 15k now and so far they have been great. at 3" lift I was able to get 4* caster. When I had a 2" lift I had them at 5*. They still look and function like they were brand new out of the box, but I also greased them well at install and at my last 10k oil change.
    hossler1788 likes this.
  12. May 2, 2023 at 9:39 AM
    totmacher
    Daniel
    West TN
    I have a bit over 25k on my Dirt Kings. They had been good for a while but the bushing don't seem to hold grease anymore or something. I get about 2k after grease and retorquing the bolt before the bushings are knocking again at every bump. Grease visibly coming out various places over time around the bushings. Other than the annoying knocking bushings, they are fine i guess.
  13. May 2, 2023 at 9:53 AM
    Anything but Icon unless you want constant squealing.
  14. May 2, 2023 at 9:56 AM
    4RunnerGuy916
    Is there any problem if I torque the upper control arm/ ball joint while still on Jack? Or should I do it with the vehicle weight on the ground? Sorry first time swapping out Control arms
  15. May 2, 2023 at 10:35 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    I torqued mine when its on the ground under its own weight.
    5six likes this.
  16. May 2, 2023 at 1:01 PM
    OverRunner
    OverRunner rebmeM weN
    Jared
    Denton, TX
    ‘21 ORP w/KDSS
    I appreciate all the individual feedback on the different options.
    I too have been considering the options (leaning BDS or Accutune), and didn’t realize there were so many out there. It’s not exhaustive, but here’s the spreadsheet I’ve been using to keep all my notes.
    AccuTune Offroad and 2Toys like this.
  17. May 2, 2023 at 1:07 PM
    4RunnerGuy916
    Wow nice I appreciate you for sharing will look into it some more with your spreadsheet
    Cis915 likes this.
  18. May 2, 2023 at 1:16 PM
    Supposed to do it on the ground.
  19. May 3, 2023 at 5:56 AM
    throwback
    throwback New Member
    Just know that the UCAs with more built in caster achieve this by pulling the top of the spindle toward the rear of the truck. This gains caster but pulls your tire toward the rear, getting closer to the body mount.
    I suggest watching all of Tinkerer's Adventure videos on Toyota IFS to really understand how it all works.
    Tinkerer's Adventure - YouTube
  20. May 3, 2023 at 6:43 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    If I was buying another set of uca. Id probably go with dobinson uca. They really have some great stuff.
    Accelerator and Crikeymike like this.
  21. May 3, 2023 at 7:04 AM
    Per this video Dobinson uca seems to have easy replaceable ball joint, oem like bushing and few more advantages.
    https://youtu.be/6WDyscFarpA
    Klinsman55 and Crikeymike like this.
  22. May 3, 2023 at 7:18 AM
    Mr. Snuffleupagus
    Brandt
    2022 TRD Pro
    I second the Dobinson's UCA. They are maintenance free and use the same OEM ball joint that is readily available at all auto parts store. They are beefy and I achieved 3+ caster with them no problem.
    Klinsman55 and Accelerator like this.
  23. May 3, 2023 at 7:21 AM
    Chris In Milwaukee
    Chris In Milwaukee New Member
    Chris
    I have had the Dobinson UCAs for about 50,000 miles now. Good as gold!
    raimieb and Crikeymike like this.
  24. May 3, 2023 at 7:24 AM
    5six
    5six New Member
    55_4Runner
    GTA, Ontario, Canada
    2022 Black TRD ORP
    Based on his videos and a few of the local 4Runner owners I went with Ironman4x4 UCAs.
    TrueTexas likes this.
  25. May 3, 2023 at 7:35 AM
    4RunnerGuy916
    Would it be worth it to spend the extra 200$ for Dobinson. I’m planning on JBA as of now. Don’t really do much off-road maybe once every month or so
  26. May 3, 2023 at 8:07 AM
    OverRunner
    Jared
    Denton, TX
    ‘21 ORP w/KDSS
    Besides price, their biggest difference is the bushings, urethane (JBA) vs rubber (Dobinsons).
    The rubber will be quieter, less maintenance and a little more forgiving of the road. The urethane will require greasing regularly, and will probably squeak from time to time, but they’ll provide a more responsive feel (you’ll feel more of the road and steering) and be slightly less sloppy.
    Crikeymike likes this.
  27. May 3, 2023 at 9:16 AM
    Crikeymike
    Crikeymike Exit Offroad, Dobinsons Specialist Vendor
    Jax Beach, FL
    2014 4Runner w/Dobinsons MRA Suspension, Shrockworks bumper/sliders
    Exactly right.
    I've never had to sell replacement bushings for the Dobinsons UCA's, they last so long.
    QwickC, Dhbldr, Brookieguy and 3 others like this.
  28. May 3, 2023 at 9:30 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Even with greasing the bushings every 5k miles my jba arms clunk every so often.
    But yes if I was you I'd pay the extra and get dobs.
  29. May 3, 2023 at 9:33 AM
    Crikeymike
    Jax Beach, FL
    You should check if they're making contact with the coilovers. I've seen that with JBA's before as they offer a lot of droop travel, but the inside profile is as big as stock, so it can hit the coils at full droop.
    Photo attached from this post: 20190507_105048.jpg
    OverRunner likes this.
  30. May 3, 2023 at 9:39 AM
    4RunnerGuy916
    Thanks everyone dobinson was my second choice also
