Turn signal issues
Discussion in '4th Gen 4Runners (2003-2009)' started by Daves, Nov 29, 2020.
  1. Nov 29, 2020 at 5:58 AM
    Daves
    Daves [OP] New Member
    Dave
    06 4runner sr5
    none
    But first, the left rear turn signal has been out for over a year. The left front signal works but flashes quickly. I did all of the obvious, replaced the left rear lense and sent it back. Changed the bulb, and swapped the left socket & bulb over to the right side and it works fine. The working right socket & bulb doesnt work on the left. Has anyone had this problem with their 4th Gen and found the resolution?
  2. Nov 29, 2020 at 6:31 AM
    Welcome to the forum. I'm certain that suggestions will follow. Good luck!
    Daves[OP] likes this.
  3. Nov 29, 2020 at 6:36 AM
    Welcome.
  4. Nov 29, 2020 at 1:22 PM
    Pure4Runner
    Pure4Runner Pure4Runner.com
    2004 4Runner, 2008 FJ Cruiser, 2010 Tundra
    Pure Branded Sliders, Icon Suspension, ARB OUtback Console, Baja Designs Lights, BajaRack Ladder, Baja Rack Spy Light System, Banks IQ Man-Machine Interface, Body Mount Chop, Bushwacker Flares, Cabin FIlter, Carbon Fiber Door Handles, CB Radio, Cowl Light Bracket, Custom Light Brackets, DBC Grille, EBC Brakes & Rotors, Edge CTS, Expedition One Front Bumper, skinny Toyo Open Country MTs, Fenix LED Hood Light, Fourtreks Mounts, Halo Headlights, Hood Decal, KC LZR LED, Locking Billet Gas Cap, MBRP Exhaust, Method Race Wheels, Overland Springs, Power Stop Brakes, Putco LED Headlights, Spring Booster, RCI SKid Plates, Rear Window Screen, Rhino Rack Awnings, Roll Top Console, Sound Proofing, Spare Tire Spacer, SPOD, Stereo Instal, Badges, Blackout Kits, Wheel Bearings and Spacers....etc..
    Welcome to the Forum.
  5. Nov 29, 2020 at 4:31 PM
    mousemeat
    mousemeat New Member
    Memphis, TN.
    1997 4 runner limited
    welcome to the forum...check your manual (s)
  6. Nov 29, 2020 at 7:29 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    There’a an open connection somewhere in the left rear turn signal circuit. You’re gonna need to check continuity all along the path according to a wiring diagram. Usually the socket end is most vulnerable to damage and corrosion.
  7. Nov 29, 2020 at 9:40 PM
    flyinhoot
    flyinhoot When in doubt, Throttle out.
    Nor Cal
    2020 TRD Pro 4Runner "Trudy"
    Monochrome everything. LED reverse lights.
    If the left front works but flashes quickly try changing the fuse for that circuit. I’ve found this can be a typical problem. Even if it looks ok.
