Tucked position of 4 Runner trailer harness
Discussion in '5th Gen 4Runners (2010-2024)' started by rmiked, Apr 15, 2023.
  1. Apr 15, 2023 at 10:54 AM
    rmiked
    rmiked [OP] New Member
    Fort Mill, SC
    I hooked up my 5x10 utility trailer and the wiring harness is too short when making a right turn in 4 Runner. I found a 48 inch extension (male on one end, female on other). Seems to me when you are turning left (least tension) because the receptacle is on the left side of center the wires may drag the road. Has anyone experienced this? Is there a small spring you can attach to the wiring and trailer tongue that will keep the wires pulled up for left turns but allow elongation for the right turns?
  2. Apr 15, 2023 at 10:59 AM
    4scooter19
    4scooter19 New Member
    Oregon
    98 and 86 4Runners
    I don't have a newer 4runner but have made my fair share of trailer plug extensions and adapters. I'm assuming your using a flat 4 plug, you could make an extension the length you need. I usually leave enough slack that I can use the pin for the coupler to secure the wiring so it doesn't drag.
    jth likes this.
  3. Apr 15, 2023 at 11:06 AM
    rmiked
    Fort Mill, SC
    Yes, I’m using flat 4. I think I can get the 48” extension , but only need about 24”. I’ll just make a hoop and use tie wraps to keep the loop formed. If I put the vehicle in the extreme right turn configuration, I can make it long enough to accommodate that length. Then I’ll turn extreme left and see if it drags. If it does, I’ll just have to use a piece of elastic or something , tie to trailer tongue. I didn’t have this problem with Tacoma as it was integrated into the number adjacent to the license plate, more centered.
  4. Apr 15, 2023 at 11:20 AM
    You may want to Google repositioning the entire 7/4 way connector if that is something you may be interested in. I recall seeing several threads brought up on other forums but, do dot have direct links to them.
    I do not really understand why it was "placed" in the position it is now. Would be better suited closer to the receiver.
    Thatbassguy and rmiked[OP] like this.
  5. Apr 15, 2023 at 12:20 PM
    mac1usa
    mac1usa New Member
    What about something like this? You may need another adapter for the rounded end?
    Thatbassguy, jth and 2Toys like this.
  6. Apr 15, 2023 at 12:32 PM
    rmiked
    Fort Mill, SC
    Looks good. I need to see what the round end does. Looks like it converts 7 pin to 4 pin
  7. Apr 15, 2023 at 12:38 PM
    2019 TRDP w/Kangs brah!
    It was like that on the Tacoma and it was broken off often times when people would offroad with myself included.
  8. Apr 15, 2023 at 12:38 PM
    mac1usa
    mac1usa New Member
    You could plug the round end into the 4R and then I would think the 4 flat should go into your utility trailer.
    I got one of these as a temporary for my boat but then had a trailer shop make me up a custom length extension. That was less than $10 if you have a shop around you.
  9. Apr 15, 2023 at 12:49 PM
    08TXRunner
    08TXRunner New Member
    '20 SR5P
  10. Apr 15, 2023 at 12:49 PM
    rmiked
    Fort Mill, SC
    I think I’ll look for a local shop
  11. Apr 15, 2023 at 1:13 PM
    wdsteven
    wdsteven New Member
    Yes I found that to be a common issue due to the location of the plugs tucked way up under the driver's side and since I tow multiple types of trailers I really hate kneeling in the mud and gravel So for my permanent fix I purchased one of each type of extensions and just mounted them at a better more accessible location near the Hitch point, Since doing that I have not had any issues because most trailer wiring is made to connect within a few inches of the hitch point.
  12. Apr 15, 2023 at 1:43 PM
    rmiked
    Fort Mill, SC
    Agreed. If you mount it at hitch point it won’t pull regardless of which way you turn.
  13. Apr 15, 2023 at 2:20 PM
    mac1usa
    mac1usa New Member
    Someone else posted this idea a year or two and took screen shots. Have not done myself but looks like good idea like a normal truck setup (no kneeling)
    wdsteven and Ricphoto like this.
  14. Apr 15, 2023 at 3:48 PM
    rmiked
    Fort Mill, SC
    Was it hard to remove clips from frame? Clips? Screws? No additional cable was needed? It’s not obvious how to unplug the wiring harness on truck side to the receptacle held on the bracket?
  15. Apr 15, 2023 at 4:18 PM
    wdsteven
    wdsteven New Member
    No don't put yourself in for that bunch of work just get the short extensions and mount frame that holds both sizes plug it into the existing OEM plugs and just mount the new ends about 6 inches or so from the hitch point easy and clean.
  16. Apr 16, 2023 at 7:08 AM
    Any photos of said setup? Great idea BTW.
  17. Apr 16, 2023 at 12:55 PM
    wdsteven
    wdsteven New Member
    The Idea is not original from me however here is the idea..
  18. Apr 16, 2023 at 3:12 PM
    wdsteven
    wdsteven New Member
    Here is another Picture, Not the best but I'm not at home to just go take a picture of it right now but I have this picture of the boat so I zoomed in on it.
  19. Apr 18, 2023 at 3:46 PM
    OC4X4
    OC4X4 New Member
    Souther California
    Great Set-up!!!
    wdsteven likes this.
  20. Apr 19, 2023 at 6:41 AM
    I’d be very interested in details of your setup if you’re up to it. I hate where they put that oem plug…
  21. Apr 19, 2023 at 7:23 AM
    RSG sliders, Yakima Megawarrior basket, Black Rhino wheels, SOS Streamline bumper and skids, Warn VR EVO10S winch, OME MT64, Bilstein rear lift coils, Rigid Dually SS ditch lights, SR light bar, and Diode Dynamics SS3 fogs.
    I've just been looping the extension through the chain loop at the receiver. I have considered using a zip tie instead to keep the wires away from the chain hook, but so far I haven't had any issues. It's easy and doesn't require buying anything.
    I do agree that the plug location is terrible. I've been considering a relocation ever since I found the plugs filled with mud after having a little fun one weekend.
  22. Apr 19, 2023 at 5:48 PM
    wdsteven
    wdsteven New Member
    It is a simple thing to do I did not relocate the original OEM plugs I just purchased the extensions and the mount brackets, I filled the OEM plugs with dielectric grease plugged it into the OEM outlets and then underneath the bumper where it is easy to access I mounted the brackets. Just make sure that the extensions are not too long or Mud and snow may weight down to much and possible damage.
  23. Apr 19, 2023 at 6:09 PM
    Do you have a link for this?
  24. Apr 19, 2023 at 6:22 PM
    Sounds simple enough. But, if I relocate mine, I'm going to want to get rid of the original plug.
  25. Apr 19, 2023 at 6:53 PM
    wdsteven
    wdsteven New Member
    I just went to a local trailer Supply store ( https://www.statetrailer.com/ ) and found everything
    Saker[QUOTED] likes this.
  26. Apr 19, 2023 at 7:16 PM
  27. May 22, 2025 at 2:59 AM
    TheSponge
    TheSponge New Member
    I assume this relocation works with the Limiteds as well?
  28. May 22, 2025 at 5:27 AM
    That looks a LOT like mine. ;^)
    Somewhere around here, there's a writeup I did on that project.
  29. May 22, 2025 at 6:49 AM
    If you did the writeup, as part of another thread, you would be able to find it easier...I did not find a separate thread writeup under your user name.
  30. May 22, 2025 at 8:41 AM
    It was in another thread... I'm searching for it now.
