TSB T-TT-0636-20 for squeaking brake pads and hardware
Discussion in '5th Gen 4Runners (2010-2024)' started by MontanaEric, Feb 24, 2021.
  1. Feb 24, 2021 at 5:46 AM
    MontanaEric
    MontanaEric [OP] New Member
    2020 4Runner TRD Pro
    Took the runner in for the 5k service. I told the rep about this squeaking/clunking sound coming from brakes. She said there is a service bulletin for bad pads and hardware. Here in Montana, just about everything has to be ordered, so the parts should arrive by Friday. Good to know we don't have to live with those sounds anymore.
    Moon Landing likes this.
  2. Feb 24, 2021 at 5:51 AM
    Red_5
    Red_5 New Member
    Please get a TSB# from him if you can. Thank you.
  3. Feb 24, 2021 at 5:56 AM
    Mohoman
    Mohoman New Member
    Sean
    99 Limited
    Queen of Battle
    I second this, mine squeak so bad especially in lower temps. Curious to see if I would be affected.
  4. Feb 27, 2021 at 6:13 AM
    MontanaEric
    Service bulletin was T-TT-0636-20.
    The dealer resurfaced the rotors and replaced the pads and all associated hardware. Now we have no squeaks and clunking sounds. All covered under warranty/TSB.
  5. Feb 27, 2021 at 6:33 PM
    wolfman
    wolfman New Member
    Thanks for sharing this information. Under what applications did you have clunking?
  6. Feb 27, 2021 at 7:20 PM
    Big_jarv
    Big_jarv New Member
    2020 TRD Pro
    Interesting haven’t noticed this on my Pro.
  7. Feb 28, 2021 at 6:50 AM
    MontanaEric
    It always squeaked but the clunking was on bumpy roads with low speeds.
    wolfman[QUOTED] likes this.
  8. Mar 4, 2021 at 10:09 AM
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
  9. Mar 4, 2021 at 3:58 PM
    a47chuck
    a47chuck New Member
    Central Oregon
    '19 Limited Nightshade, Midnight Black Metallic, front leveling kit, 265/60-20 KO2's and Magnuson Supercharger.
    Watching
  10. May 7, 2021 at 3:43 PM
    gordonf
    gordonf New Member
    Update for 2021 Toyota. It still happens for this year as well :(.
    Toyota does not have TSB released for 2021 model so owners should wait.
    Attached my dealer visit conclusion. Take a look at highlighted part:
  11. May 7, 2021 at 4:32 PM
    Tradbow
    Tradbow New Member
    Phil
    NW
    2023 MGM SR5
    I noticed my brakes squeaking every morning shortly after buying my 21 ORP. I took it in to the dealer. This was before the above mentioned service bulletin. I also recorded the brake squeaking on my phone and shared this with the service manager. They couldn’t replicate it the day I took it in and since I shared the video they asked to keep it overnight and the next morning he did observe the excessive brake squeaking. They tuned the rotors and replaced the pads and problem solved.
    gordonf likes this.
  12. May 7, 2021 at 4:34 PM
    gordonf
    gordonf New Member
    Do you mind share similar document as mine (if you have one) so I'll be able to point dealer into it and actually solve my issue? Thanks!
  13. May 7, 2021 at 4:57 PM
    Tradbow
    Tradbow New Member
    Phil
    NW
    2023 MGM SR5
    i don’t have any documentation other than the video I shared with the service manager. When I called in to schedule an appointment I explained what I was experiencing and since I hadn’t driven through water and the weather wasn’t a factor I knew it was probably faulty pads. I also checked to make sure I didn’t have a rock between the rotor and the Pad. Having the audio from the video was key to having them take it seriously I believe. Hope this helps.
    gordonf[QUOTED] likes this.
  14. May 7, 2021 at 5:17 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Watching for updates. I haven't noticed this on my 21' yet. I haven't taken a wheel of on the front yet but if these have calipers like the Tacoma's those you added a second retaining spring to help the clunk that happened after you reversed and then applied brakes on the first stop.
  15. May 12, 2021 at 3:32 PM
    Alloutdrs1
    Reporting back, I'm at about 1k miles now and my wife told me today that everyday here brakes are making noise. So I will monitor and see if it keeps doing it or getting worse. She said it does it excessively first thing in the morning and her first couple stops when leaving from work.
  16. Jun 2, 2021 at 1:57 PM
    wolfman
    wolfman New Member
    Anyone know the timeframe in which the dealer will address this under warranty? Aren't brakes a shorter warranty period than other components? I have the squeaks over bumpy roads as well.
  17. Nov 4, 2021 at 5:56 PM
    Alloutdrs1
    Has anyone had any luck on a TSB for the 21' models yet? Mine are squealing pretty bad now that its cooler out after it sits for a little while or when i first start out after being parked when its raining.
