Triax Build
Discussion in '4th Gen 4Runners (2003-2009)' started by TriaxT4R, May 28, 2019.
  1. May 28, 2019 at 6:37 PM
    TriaxT4R
    TriaxT4R [OP] New Member
    San Diego, CA
    2008 Sport 4x4
    Bilstein 6112/5160 (3/2), Icon 2” rear springs, Fuel Anza, Ridge Grappler 285/70-17
    My New 2008 Sport 4x4
    Ripped out the XREAS this past Saturday and replaced with Bilstein 6112s and 5160s
    only took 10.5hrs hahaha :confused:
    Removed some Nitto Crosstek tires with some Cooper Discoverer STT Pros
    Now just waiting on Shrockworks sliders........??? I love build to order
    Got tired and forgot to take pictures of the 6112s installed
    Ill get some pictures of the set up when Im in Big Sur next week
    Only took a picture of the Before set up with Xreas
    Leveled the front and kept the stock rear springs for now
    Hwnrunner and Prezioso70 like this.
  2. May 29, 2019 at 11:36 PM
    Hwnrunner
    Hwnrunner New Member
    Hawaii
    2019 4Runner SRS Prem 2wd
    TRD Pro Struts/ Coils, Toytec 1" spacer, Dobinsons C59-505 Springs,TRD Pro Sema Wheels, TRD Pro Lower Valances, Ceramic Tint
    looks good, stock size tires?
  3. May 30, 2019 at 8:56 AM
    TriaxT4R
    San Diego, CA
    2008 Sport 4x4
    Thanks, no 265/70/17...there about 32”
    I compared them to KO2 275/70/17 at Discount tire, almost can’t tell size difference.
    A lot of good reviews on the STT Pros.
    Removed the mud flaps before I put them on, Still rubbed a little With Xreas.
    Good clearance with Bilstein set up
  4. Jun 13, 2019 at 6:12 PM
    TriaxT4R
    San Diego, CA
    2008 Sport 4x4
    Just installed Black Spidertrax all around, had some rubbing on fwd wheel well plastic, easy fix!
    Drove it on the freeway for the first time today, didn’t have any shaking at 80mph.
    Read several ppl having shaking issues at lower speeds, ended up just cleaning disks with wire brush, attached all nuts hand tight, then torqued at 50 ft all around in star pattern, then moved to 90 ft in star pattern and then a full circle at 90 again...the reason I did it that way is because it’s a similar procedure on aircraft props (I’m an aircraft mechanic). Too easy to get things out of balance, especially going from hand tight to 90 ft lbs. right off.15E7A9F5-CAEC-46AE-A201-7D56AECE0319.jpg
    I’ll get before and after pictures up asap
  5. Jun 13, 2019 at 6:23 PM
    TriaxT4R
    San Diego, CA
    2008 Sport 4x4
    Did our first road trip up to Big Sur...got the 4R leveled for the most part, not 100% but Very close.
    Pictures are from Coast drive (or Old Coast Drive) 10 miles from start to finish through Big Sur, CA
    835729C4-F67C-4B4B-B2FE-05D655AF2737.jpg 16C00B89-07D4-4E5A-8716-2857FB422C51.jpg 5E364CB7-1417-44C6-AE95-45F6AF9660E7.jpg
    nimby and SlvrSlug like this.
  6. May 5, 2020 at 12:19 PM
    Lumberjack_T4R
    Lumberjack_T4R New Member
    Cole
    I know this is an old post, but what did you set the 6112’s at to get close to level?
  7. May 5, 2020 at 5:41 PM
    TriaxT4R
    San Diego, CA
    2008 Sport 4x4
    If your going for the fenders level look then 6L/4R or 5/3 will both be close...I did 5/4 and it had driver side lean, follow the directions Bilstein gives. This is with stock rear springs.
    (FRAME LEVEL)
    I change it and bought 2" Icons for the rear and put both front clips on 6 with a 1/4 shim on driver....pretty level. Also a 1/4 Shim driver rear.
  8. May 5, 2020 at 5:48 PM
    Lumberjack_T4R
    Cole
    Awesome, thank you!
    TriaxT4R[QUOTED][OP] likes this.
