TRD Shift knob
Discussion in '5th Gen 4Runner Parts Marketplace (2010-2024)' started by mikegronholz, Feb 4, 2019.
  1. Feb 4, 2019 at 9:41 AM
    mikegronholz
    mikegronholz [OP] New Member
    Coming out of TRD Off Road ... 1000 miles on the rig. Is what it is. $65 to your door in the lower 48.
  2. Feb 4, 2019 at 11:06 AM
    Bob
    Bob Member Staff Member
    Bob
    Pic
  3. Feb 4, 2019 at 12:17 PM
    mikegronholz
    Thought I had one saved ... nope. I’ll get one as soon as I leave the office.
    Bob[QUOTED] likes this.
  4. Feb 4, 2019 at 2:43 PM
    mikegronholz
    Pic attached
  5. Feb 4, 2019 at 5:58 PM
    Tstrang
    Tstrang New Member
    Tommy
    2018 4Runner
  6. Feb 4, 2019 at 6:35 PM
    mikegronholz
    $60 is the lowest it’s going. It’s brand new
  7. Feb 4, 2019 at 6:47 PM
    Tstrang
    Tstrang New Member
    Tommy
    2018 4Runner
    K easy install?
  8. Feb 4, 2019 at 7:09 PM
    mikegronholz
    Twist off, twist on.
  9. Feb 4, 2019 at 7:13 PM
    2016Pro
    Hiw many hp does it add? As much as a cai?
  10. Feb 4, 2019 at 7:26 PM
    Tstrang
    Tstrang New Member
    Tommy
    2018 4Runner
    Ok I’ll take it
  11. Feb 4, 2019 at 11:34 PM
    4runningMan
    4runningMan New Member
    New Mexico
    For future lurkers- I got one of these knobs on Amazon. I installed it and it was tight but there was a little bit of "play" in it. There is a threaded plastic insert in the knob that is attached by a Philips head screw. If you have any play in your knob, you'll need to insert an extra long Philips screw driver and tighten the threaded insert. Then reinstall and the "play" will be gone.
    siblue likes this.
  12. Feb 5, 2019 at 4:19 AM
    DGP1961
    DGP1961 New Member
    2018 SR5 Premium
    Hmmm thanks I'll need to look at mine when it's lined up there's not enough room for another full turn it'll stop half way to tight. So there's something to adjust this? I'll need to unscrew it and look. Does it like set the depth or something?
  13. Feb 5, 2019 at 5:59 AM
    mikegronholz
    I’ve heard rumors of double ... but nothing confirmed on a dyno
    2016Pro[QUOTED] likes this.
  14. Feb 5, 2019 at 9:39 AM
    4runningMan
    New Mexico
    Nope it doesn't set anything. It's a threaded insert. The insert's inner diameter is threaded. It's what allows the knob to be screwed onto the stick.
    If the insert is loose inside the knob, the knob will be wobbly on the stick. The insert can still be screwed on to the stick very tightly, but the knob will be wobbly. Make sense?
  15. Feb 5, 2019 at 5:23 PM
    DGP1961
    DGP1961 New Member
    2018 SR5 Premium
    Think so I'll need to more closely look at it which I haven't yet. When I screw it tight it "stops" (is tight) half a turn BEYOND being lined up. instead of being obviously lined up it would "point" to the passenger so I leave it loose to look correct. Hmmm are they engineered to actually stop and tighten exactly perfect??
  16. Feb 5, 2019 at 5:30 PM
    DGP1961
    DGP1961 New Member
    2018 SR5 Premium
    Ok...So I got curious and just went and looked. There's no insert it's just threaded inside but it isn't as off as I made it sound. At fully "tight" it stops maybe pointing to about 1 o:clock guess I thought it was worse. No biggie won't lose any sleep over it I just keep it backed off to be straight.
    4runningMan likes this.
  17. Feb 5, 2019 at 10:23 PM
    4runningMan
    New Mexico
    If you shine a light inside, you'll see the white plastic coupler and Philips head screw (I think). But if you screw it all the way tight (1 o'clock in your case) and there's no "play" in it, then there's no need to tighten the screw.
  18. Mar 31, 2019 at 5:52 PM
    Kolisko802
    Kolisko802 New Member
    Cape Cod, MA
    2018 Black 4Runner
    still available?
  19. Apr 1, 2019 at 4:57 AM
    Tstrang
    Tstrang New Member
    Tommy
    2018 4Runner
    Sold... it’s on my bad boy!
