Transmission issues
Discussion in '2nd Gen 4Runners (1990-1995)' started by cramos8, Feb 11, 2019.
  1. Feb 11, 2019 at 8:44 PM
    cramos8
    cramos8 [OP] New Member
    Colton
    Red 4runner 4x4
    My Automatic 95 4runner 3.0 4x4 has been having transmission issues. It takes about 2 seconds for it to shift into reverse and tends to rev up high before it shifts, and when it shifts it will sort of kick the car. Anybody else having this problem with this transmission? Also will take any solutions.
  2. Feb 11, 2019 at 8:47 PM
    WallyT4R
    WallyT4R New Member
    Sounds like a rebuild is in order.
  3. Feb 11, 2019 at 8:48 PM
    cramos8
    Colton
    Red 4runner 4x4
    I've looking for new transmissions just in case.
    WallyT4R likes this.
  4. Feb 12, 2019 at 5:17 AM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    2004 SR5 V6 4WD 4Runner
    Drain and flush see if that helps at all?
    2016 Trail Editition likes this.
  5. Mar 18, 2019 at 5:18 PM
    Savage2ndGen
    Savage2ndGen New Member
    Lawrence
    1993 Drk Blue 4Runner 3.0
    i saw a video on youtube, some guys did a tune up on the motor. spark plugs/wires and oil change and that fixed that exact issue they were having.
    cramos8[OP] likes this.
  6. Mar 18, 2019 at 8:28 PM
    Smitty86
    Smitty86 New Member
    Chris
    1992 Toyota 4runner
    I had similar issues and put shutter fix in the transmission and fixed my issues. I bought 2 which cost me $20. I got it from O'Riley's auto parts but I'm sure you can pick it up at any auto parts store. It's probably a sticking solenoid. Worth a shot at least.
  7. Mar 19, 2019 at 9:35 AM
    cramos8
    Colton
    Red 4runner 4x4
    Ill make sure to try these things out. Thanks guys
    Smitty86 likes this.
  8. Mar 19, 2019 at 10:02 AM
    Benny123
    Benny123 Toyota enthusiast
    Southeast Charlotte, NC
    2016 Nautical Blue SR5 Premium
    LEDs all around, otherwise bone stock.
    Make sure you drop your pan and clean the magnets when you drain and flush or youll be worse off.
  9. Mar 19, 2019 at 3:30 PM
    DGP1961
    DGP1961 New Member
    2018 SR5 Premium
    At the end of the day it may be on its way I mean it is 24 years old!! A fluid change is cheap enough just for $hit kicks even if you pay for one.
    cramos8[OP] and Smitty86 like this.
  10. Mar 19, 2019 at 5:49 PM
    Savage2ndGen
    Lawrence
    i been looking everywhere. i keep losing transmission fluid out of a breather valve on top of transfer case. anyone got any ideas on why this is happening?
  11. Mar 19, 2019 at 5:53 PM
    Smitty86
    Smitty86 New Member
    Chris
    1992 Toyota 4runner
    It sounds like you have too much fluid or a vent tube is clogged.
    HoBoDanny likes this.
  12. Mar 19, 2019 at 6:08 PM
    Savage2ndGen
    Lawrence
    okay ill check the vent tubes. the transmission was empty when i towed it. i just bought this sunday. other then that i got it for a great deal.
    thank you
  13. Mar 19, 2019 at 6:15 PM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    Trans was empty when you towed it?
  14. Mar 19, 2019 at 6:28 PM
    Savage2ndGen
    Lawrence
    i went to look and pick it up sunday, the guy said it would go into gear fine and drive then he parked it for couple months and while i was on my way to look at it he said it would not go into gear. so i checked trans dipstick and it was empty. went and got a truck and trailer took it home, i filled it and atf started coming out of the transfer case breather on the top. nowhere else at all.
  15. Mar 19, 2019 at 6:44 PM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    Did you just fill it while cold? If so drain out all of it. Then Add fluid until it is showing on the dipstick in the cool range. Once there start engine shift through all gears while stationary do this until trains is warmed up then Check that the fluid level is in the hot range if not add fluid a little at a time until it is.
  16. Mar 19, 2019 at 7:02 PM
    Savage2ndGen
    Lawrence
    okay ill try that, thank you
  17. Mar 20, 2019 at 9:32 AM
    cramos8
    Colton
    Red 4runner 4x4
    Update: my transmission went out yesterday as i was pulling out of my driveway. Anyone know what kind of transmission is needed in a 1995 toyota 4runner. 3.0 4x4
  18. Mar 20, 2019 at 10:02 AM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    A340H
    SlvrSlug and cramos8[OP] like this.
  19. Mar 21, 2019 at 7:30 PM
    Savage2ndGen
    Lawrence
    HoBodanny update. Transmission filled and running smoothly. I must have incorrectly fulled it the first time. Found previous owner stripped drain bolt though so im goimg to change the filter while im in there.
    Anything else i should do while i have the transmission pan off?
  20. Mar 22, 2019 at 5:05 AM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    Awesome! Nah should be good filter and fluid.
    Savage2ndGen[QUOTED] likes this.
  21. Mar 22, 2019 at 6:21 PM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    Looks like just a hose going to the silencer portion of the intake
