Transmission drain and fill
Discussion in '5th Gen 4Runners (2010-2024)' started by dan777, Apr 11, 2025.
  1. Apr 11, 2025 at 1:51 PM
    dan777
    dan777 [OP] New Member
    Dan
    South Jersey
    19 ORP
    I’m getting ready to do my first drain and fill and I’m curious if everyone is just draining the pan or dropping the pan and replacing the gasket and filter?
    CygnusX-4 likes this.
  2. Apr 11, 2025 at 2:10 PM
    cbrake
    cbrake New Member
    Cliff
    2019 Silver 4Runner
    eurowner likes this.
  3. Apr 12, 2025 at 4:45 AM
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    Never doing it, unless it does it itself at some point, but not worried.
  4. Apr 12, 2025 at 6:57 AM
    CygnusX-4
    CygnusX-4 Member
    CO
    21 TRD OR
    Drain and refill should be fine the first couple times that you do it. Make sure that you pay attention to the fluid temperature when adjusting the level.
    dan777[QUOTED][OP] likes this.
  5. Apr 12, 2025 at 7:00 AM
    104-113 target temp
    dan777[OP] likes this.
  6. Apr 12, 2025 at 8:07 AM
    CarlP
    CarlP New Member
    Carl
    Phoenix, AZ
    2018 Off Road with KDSS
    Why not measure and just put in exactly what you removed. Or...can you read fluid temperature with an OBD reader?
  7. Apr 12, 2025 at 8:17 AM
    I’m planning to not open it up, maybe way down the road but I don’t think I’ll do more than throw new fluid at it.
  8. Apr 12, 2025 at 8:27 AM
    Taylor21554
    Taylor21554 New Member
    Naples Florida
    24 SR5 4x4
    Best to do the drain and fill when cold, crack open fill plug 24mm, drain plug, and get about 3.5 quarts out ~
    Fill back up with what came out + extra half quart or so. Fire it up, let it idle, shift through the gears. It will take awhile for cold idle trans temp to get to checking temp.
    once it reaches the temperature range, you have a few mins to go down and remove check plug. Let it drain excess until slow trickle, almost like an oil change. Once it dribbles or slower stream comes out, plug the check back up.
    if nothing comes out of check during the temperature process, add more to the fill until it does.
    I just did this yesterday and hope I didn’t mess anything up lol. 29k miles
  9. Apr 12, 2025 at 8:32 AM
    dan777
    Dan
    South Jersey
    19 ORP
    Damn 29k. Why so early?
  10. Apr 12, 2025 at 8:45 AM
    trans fluids can expand a different temps. Thats why it a good idea to overfill bu 1/2 quart or so when your doing the level drain port + running temp range. Barely a trickle should come out when its the right level. If your OBD reader has temp 1 and temp 2 trans fluid readings that will work
  11. Apr 12, 2025 at 9:12 AM
    4Daughters
    4Daughters It’s how I know God has a sense of humor
    Ken
    Powder Springs, Ga
    2022 TRD ORP; Silver; too many port options...Ah well...
    TBD
  12. Apr 12, 2025 at 10:19 AM
    dan777
    Dan
    South Jersey
    19 ORP
    I actually watched that video as well as a few others today. Only a couple videos actually drop the pan and replace the filter. I think I’ll just go with a drain and fill and let the pan be for now
  13. Apr 12, 2025 at 10:40 AM
    Taylor21554
    Naples Florida
    24 SR5 4x4
    Well basically I’m at 30k, and I was doing an oil change. Honestly, mostly boredom lol. My buddy had a few quarts of WS left over he gave me to so decided to crack them open and just get it done. Will do another spill and fill at 50/60k
