Transfer case grind/electric noise on a 4th gen
Discussion in '4th Gen 4Runners (2003-2009)' started by warriorkenth, Feb 25, 2020.
  1. Feb 25, 2020 at 8:28 AM
    warriorkenth
    warriorkenth [OP] New Member
    Hi fellas,
    I bought a 2004 V8 SR5 this weekend with 185k miles. It was pretty cheap, only $3500, but it needs some love before I can fully trust it.
    The engine and transmission seem pretty strong. I put it 4lo and it seems to work fine. However, I found 2 issues. First one, when I try to lock the transfer case for 50/50 power, I hear a pretty loud grinding noise combined with an electrical-motor-like noise. And of course, I don't get a light on the dash showing the locked Tcase. It doesn't even flash.
    Like I said, this car needs a lot of love, so I don't even know if the light on the dash is working, but I'm more worried about diagnosing the noise first. Has anyone heard that or can give me any clues?
    The second issue is the hill descent button. When I press it, I get a flashing icon on the dash, but I didn't see any difference in the way the car drives and I don't know if the light should be still instead of flashing.
    Thanks for all the info you can provide!
  2. Mar 4, 2020 at 7:58 AM
    MP21
    MP21 New Member
    1998 T4R 4x4 V-6 & 2008 T4R 4x4 V-8 & 2004 T4R 4x4 V-8 & 11 Sequoia Platinum
    98 T4R 2" lift 235/85r16 Hankook Dynapro M/T 07 T4R 3" ToyTech Lift with Bilstein 5100 front and rear 255/70R18 BFG A/T Ko2 JBA uppers 04 T4R 4x4 V-8 Currently stock
    AS FAR AS HILL ASSIST IF TE LIGHT COMES ON ITS FUNCTIONING. IT IS DESIGNED TO BE USED ON LONG DOWNHILL RUNS.
  3. Mar 4, 2020 at 8:01 AM
    warriorkenth
    Thanks for the answer!
    Right, but does the light flashing mean something? or does it always flash?
  4. Mar 4, 2020 at 8:04 AM
    MP21
    MP21 New Member
    IF THE BUTTON IS PUSHED IT WILL FLASH. IF THE BUTTON IS NOT PUSHED THE LIGHT WLL NOT BE ON
  5. Mar 4, 2020 at 8:06 AM
    warriorkenth
    Alright! Thanks for the info :)
