Toytech 3" lift with TRD PROS 275 tires, will they fit?
Discussion in '5th Gen 4Runners (2010-2024)' started by GreyRunner808, Feb 21, 2018.
  1. Feb 21, 2018 at 9:15 AM
    GreyRunner808
    GreyRunner808 [OP] In the process of build
    Big Island, Hawaii
    Whats up guys, new to the forum and need some suggestions. I have a 2018 Sr5 and am planning on buying the 3” toytech ultimate, and for my wheels i wanna go with the 17” TRD pros on 275/70/17 bfg ko2’s. My question is will there be rubbing with the 275’s or should i go with 265’s? Also my lift takes 3 weeks to come in and rims n tires i can get next week. Will the 275 tires and 17” rims fit at stock height if i put the wheels on first before my lift? Or should i just wait the 3wreks for the lift to come in????
    szuyung3000 and Toytec Lifts like this.
  2. Feb 21, 2018 at 9:51 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, Crawlorado
    Good morning!!!
    We have seen great success with that kit, tire size, and wheel fitment. We have, however, seen most people run the 1.25'' wheel spacers to insure proper clearance on the UCA and cab mount.
    We do recommend doing test fitting with your local tire shop to insure proper size fitting the first time without any issues.
    Let us know if there are any other questions!
    T-Rex266 likes this.
  3. Feb 21, 2018 at 10:15 AM
    GreyRunner808
    Big Island, Hawaii
    Would you recomend putting on lift first before putting on the 17” rims and tires?
  4. Feb 21, 2018 at 10:23 AM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    The wheels and tires should fit with minimal / possibly no rubbing as is. Add in the lift and they will fit fine. I disagree with Toytec's suggestion of adding 1.25" spacers to the wheels, not necessary on the TRD Pro wheels.
  5. Feb 21, 2018 at 10:31 AM
    GreyRunner808
    Big Island, Hawaii
    Really? Thanks for the info, didnt want to add spacers, so thank you
  6. Feb 21, 2018 at 10:34 AM
    Toytec Lifts
    Denver, Crawlorado
    You should be fine, just be careful on rubbing.
  7. Feb 21, 2018 at 10:46 AM
    GreyRunner808
    Big Island, Hawaii
    Thank for the info
  8. Feb 21, 2018 at 11:20 AM
    Gramps
    Gramps New Member
    Some Old Guy that knows nothing
    2018 SR5 Premium
    Just some stuff to make mall crawling easier.
    IMO honestly I would wait for the lift to get installed since the front end geometry will change a bit. It would suck to get the tires and wheels mounted up only to have slight rubbing issues that will drive you crazy for 2.5 weeks until your lift arrives. Or you trim some fender to remove the rubbing issue and then find out post lift you never had to trim in the first place.
    As far as needing spacers, definitely wait until it lifted and do your test fitting before you consider spacers. Another IMO here but spacers are NOT the "end of the world" as the interwebz make it out to be. Quality hub-centric spacers work just fine for what they are designed for. My 2nd gen Tacoma has run both 1.25" spacers and currently sits on .75" spacers going on 11yrs now. Zero issues, no per-mature wheel bearing wear and so on. So if you find yourself needing spacers look into 1) Spidertrax, or 2) BORA. Both build hub-centric spacers for Toyota's.
    BigSky1 and Backslider like this.
  9. Feb 21, 2018 at 11:29 AM
    Gramps
    Gramps New Member
    2018 SR5 Premium
    Also I should note that our 2018 4r has 275/70R17 tires on it with a 1.5" lift coil spring on the front only to level it out while running 17x8.5" ICON Alpha wheels. Even with the front brought up 1.5"s I was rubbing on the front of the fender.
  10. Feb 21, 2018 at 11:52 AM
    GreyRunner808
    Big Island, Hawaii
    What kind of 275 tires do you have?
  11. Feb 21, 2018 at 11:56 AM
    Gramps
    Gramps New Member
    2018 SR5 Premium
    Cooper ST Maxx
    SLoTH_XVX, CO_SKI and Backslider like this.
  12. Feb 21, 2018 at 2:16 PM
    GreyRunner808
    Big Island, Hawaii
    Yea their 7” width
  13. Feb 21, 2018 at 7:19 PM
    jdm197
    jdm197 New Member
    2016 sr5
    toytec 3" lift and ko2 285's.. installed the toytec lift 35k miles ago and just recently put the 285's on. no rubbing at all
    Gramps likes this.
  14. Feb 21, 2018 at 8:41 PM
    GreyRunner808
    Big Island, Hawaii
    Any pictures what your setup looks like?
  15. Apr 18, 2018 at 12:12 PM
    JosephMehta
    JosephMehta New Member
    Zombocalypse
    Shrockworks Front Bumper, CBI Rear Swing Away with dual Jerry Cans and full size spare, Full Shrockworks Armor, Warn 9.5 Synthetic, PIAA Lighting on roof rack and front bumper, Rear lighting wired to vehicle's reverse gear, Dobisons dual slide out rear bay storage with sliding top and refrigerator tie-downs, Limb Risers, Gobi Rack w/mounted Powertank, Fire Extinguisher, Jack, Axe, and Shovel, 33" Nitto Grapplers (295/70/17), Body Mount Chop, Icon Stage 7 Billet w/S2 Stage 3 Secondary adjustable front suspension, 3.5 inch Icon Stage 7 Billet with Billet Upper and Lower Links, Icon Bump Stop, 3.0 inch Icon Overland Rear Coils, ARB Front and Rear Air Locker with ARB Differential Breather (relocated to engine bay), ARB Twin Compressor mounted in engine bay, 360 degree, 4-camera system with DVR with monitor mounted on the dash, Dual Rear Headrest Monitors w/DVD and gaming capability Future mods in 2019: Magnusson Supercharger w/Catback system and possibly an roof mounted, solar heated shower and water storage
    I did the exact thing you are doing (or already did), so here is your answer:
    I have 275/70/17 K02s. When I bought the truck it had 2 inch spacers (not a suspension lift). The front tires rubbed with this configuration.
    On a stock 4runner with no lift, size 275/70/17, of course the BFG K02s will rub.
    With the 2 inch spacers I mentioned above, which were on my truck initially, the front tire will rub when turned inward; the rubbing will be the edge of the K02s tread pattern on the truck's inner wheel well. Nothing major but quite loud.
    I changed the kit for a 3 inch Toytec Lift (mine is the Toytec Boss w/Superflex Heavy Duty Rear Coils); with this lift there is no rubbing with the KO2 275s.
    The above is fact, the following is conjecture:
    With the 3 inch lift I have, it is possible to go to 285s with no rubbing, given that 285s add only .4 inches to wheel height. Again, this is conjecture, but the lift gives a lot of clearance with respect to the current 275 tire size.
    For future potential size answers (that is: can one go to 295s, 305s on a 3 inch Toytec lift?), I will be able to give a littler more insight, as I'm installing the Shrockworks front bumper which may open up some space over the front tires after the lower part of the front bumper is removed. At the same time that the front bumper is installed, I'm adding 1.25 inch Spidertrax spacers. My hunch is that I might be able to get to 295s with no rubbing, however, that is for the front, and, again, is just conjecture and not yet verified. Even if it doesn't rub at this tire height, there is always the rear to think about, too. That still may need a body mount chop.
    newlife and raetuck90 like this.
  16. Apr 18, 2018 at 1:35 PM
    GreyRunner808
    Big Island, Hawaii
    I put on the Toytech 3” suspension Bilstein lift and went with stock size 265/70/17 Cooper Discoverer STT because Cooper had no 275’s in that tire, no rubbing at all. Here is a pic
    SLoTH_XVX and loneknight5 like this.
  17. Jun 19, 2018 at 8:45 AM
    PCRIDE4RUNNER
    PCRIDE4RUNNER New Member
    SUPER DUPER
    Did they end up rubbing at all with stock size while waiting for your lift?
  18. Aug 4, 2018 at 8:36 AM
    raetuck90
    raetuck90 New Member
    How much does 285/75r17 add to the wheel height? I installed 3" Toytec boss lift on my 2014 T4R thats only 2WD. It sits about 1-1.5" higher than a 4WD rig with that same lift. I am wondering if I can go up to 34" tires without having to do any body mount chop?
  19. Aug 4, 2018 at 10:29 AM
    szuyung3000
    szuyung3000 New Member
    SYH
    2016 4runner SR5 4x4
    yes it will CERTAINLY fit for sure w/o any rubbing. I have a gray 2016 SR5 Premium 4x4 w/ 17x7" TRD wheel and had just installed a 3" leveling/lift kit from Rough Country. the 285/70R17 may or may not rub even w/ a 3" lift but a 275/70R17 definitely WON'T for sure
  20. Aug 4, 2018 at 10:31 AM
    szuyung3000
    SYH
    try to find 275/70R17 in other brands. BFGoodrich KO2 is the most popular among 4runner owners
  21. Aug 6, 2018 at 6:39 AM
    JosephMehta
    Zombocalypse
    THIS IS AN EDIT TO MY ORIGINAL RESPONSE:
    ...I originally calculated wheel height change using 275 vs. 285/70/17. The poster wanted the change in height from 265/70/17 vs. 285/75/17 and not the one I did. Here is the correct calculation:
    ...when going from a 265/70/17 to a 285/75/17 you will gain ~2.22 inches of height.
    ...I am going to keep my original post with original calculations (below) given that many tend to have a similar question, but using 275/70s
    On BFG K02s, going from 275/70/17 to 285 gives another ~0.57 inches of height. The 3-inch lift helps with 275s, getting rid of rubbing (remove the mud flaps, too), but you may see some inside rubbing with any tire that's larger than that. That information comes from a 2017 TRD Pro.
    I'd suspect a 34-inch tire will have a high probability of causing rub. I'm taking my truck in (today as a matter of fact) to switch my Toytec 3" lift for the Icon Stage 7 with secondary shocks. Icon advertises that this lift (it's a 3.5-inch lift) will be good enough for 33-inch tires (note that they didn't say 34-inch). With my tires I'm going from my BFG 275s to Nitto 295s, which is ~33.26 inches; my 4x4 shop advised me not to go to the 295s, and wanted me to stay with 285s. However, I will still install the 295s, and am okay doing a body mount chop if need be. Once I have the truck back in a week (remind me if I forget) I will let you know if I get rubbing, without a body mount chop. To be fair, however, so that you know we are not necessarily comparing apples to apples here, I have the Shrockworks front bumper, which removes a lot of stock bumper space from the front end. If I have rubbing it will be the back of the wheel well; again, I will let you know.
    SlvrSlug likes this.
  22. Aug 6, 2018 at 9:17 AM
    szuyung3000
    SYH
    with 285/75R17 you will VERY likely need a BMC. Same with 295 tires. Those are 33"+ tire size. To avoid a BMC w/ or w/o a lift is best to go no larger than 32.2" tires aka 275/70R17
    JosephMehta likes this.
  23. Aug 6, 2018 at 9:37 AM
    JosephMehta
    Zombocalypse
    Spot on: with 275/70/17 tires on my truck I had no rub with a 3-inch/Toytec lift (stock front end).
  24. Aug 6, 2018 at 10:10 PM
    szuyung3000
    SYH
    What do you mean by 3" lift and then stock front end??
  25. Aug 7, 2018 at 5:07 AM
    JosephMehta
    Zombocalypse
    On my truck I now have the Shrockworks front bumper, which required a lot of cutting away of the stock, front bumper. (This gives the front tires more space, and less opportunity for rubbing.)
    When I say “stock front end” I’m referring to the time when the front bumper was not yet cut away.
    Hope this helps.
