Toyota roof rack weight limit
Discussion in '5th Gen 4Runners (2010-2024)' started by Zoochad, Apr 26, 2018.
  1. Apr 26, 2018 at 7:01 PM
    Zoochad
    Zoochad [OP] New Member
    2016 silver 4Runner trail premium
    None yet
    I am a noob to the forum but I want a rooftop tent. Can the stock rack support the weight or should I get an after market rack?? Any help would be appreciated
    Strandskov likes this.
  2. Apr 26, 2018 at 7:24 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    The only number I could locate was for the cross bars at "165lbs evenly distributed". I can't find anything on the rack itself.
    Thatbassguy and Strandskov like this.
  3. Apr 26, 2018 at 7:32 PM
    4X4Runner
    The left coast
    I’ve seen people remove the cross bars and mount the tent to the rails that run the length of the 4Runner. Another option is either yakima or Thule cross bars.
    For Yakima it’s the timberline towers and the bars that go across. Not sure on the Thule names or part’s.
    I know one 4R member on tacomaworld has her RTT mounted to Thule bars and the factory rails (not cross bars)
    KSJ08, scottalot and Strandskov like this.
  4. Apr 26, 2018 at 7:44 PM
    Zoochad
    None yet
    Cheers thanks
  5. Apr 27, 2018 at 8:50 AM
    tangjkd
    tangjkd New Member
    tangtang
    Sacramento
  6. Apr 27, 2018 at 9:42 AM
    Zoochad
    None yet
    Thanks I will check it out.
  7. Feb 27, 2019 at 5:00 PM
    Shabo13
    Shabo13 New Member
    s
    2019 TRD Off-road premium
    None
    I had watched something on this, on YouTube. The guy was saying that the weight limit is a dynamic weight limit. (Meaning, driving around) He went on to say that the static weight limit is actually much more.
    Totally makes sense, I thought... I was also thinking about a roof top tent, even before any suspension. I know, not really much information. Lol
  8. Feb 28, 2019 at 11:39 AM
    SKT_07, Toffees and ManBeast like this.
  9. Feb 28, 2019 at 9:45 PM
    4runningMan
    4runningMan New Member
    New Mexico
    Oldtoyotaguy likes this.
  10. Feb 28, 2019 at 10:09 PM
    mynameistory
    mynameistory New Member
    Tory
    The same 4Runner everyone has
    You should hear a roof rack with stuff on it. Then a bare rack will seem quiet.
  11. Feb 28, 2019 at 10:33 PM
    4runningMan
    New Mexico
    I guess I didn't mean wind noise, in general. More of a howl or resonance sound. Apparently it goes away if you add some load. But not good for those that generally travel as an unloaded daily driver.
  12. Mar 1, 2019 at 9:08 AM
    If you loop a bungee cord around the 1st crossbar in a circular pattern from one side rail to the other, you will substantially reduce the wind noise. This goes for other racks that make a lot of noise as well.
    You can also just take them off when you don't have your RTT up there. I don't think they take that much time to take off/re-install.
  13. May 14, 2019 at 4:49 PM
    BYKmatty
    BYKmatty New Member
    Hawaii
    5th gen 2018 4runner SR5
    Ceramic Coated TRD grey rims 80% tint all around Lighting: Red LED interior lighting Atack LED SUPER Brite white constant yellow front turn sigs LED super bright reverse lights Body Mods: Tyger rear step Bumper Tyger Front Nerf Bumper GREENLANE OFFROAD Roof Rack and Real ladder (Awesome) and no need to replace the rear hatch hydraulic arms. I cannot say enough about these guys especially because their shipping was completely reasonable. Custom interior: custom rear window power button and unlock button (found here in forums) Pedal Commander (this really does give your vehicle more get up and go) RAGO Mollie side trunk panels (Awesome but pricy) Victory center roof Mollie Panel (Ham radio mount) DIY rear sleeping platform (for camping)
    ok so I saw other posts on the LFD cross bars, but if you are using the OEM rails I don't think you can put a tend up on it. from what I read the OEM rails are only weighted for 175Lbs no matter what cross bars you put on. Or am I incorrect on what I have read? I mean think of it 1-2 people a tent and a piece of ply if your doing a DYI roof tent is more than 300LBS.
    Even I would like more clarification on this because this is what I am working up to doing with my 4runner.
  14. May 15, 2019 at 11:19 AM
    Toffees
    Toffees Stuff and things
    Micah
    LA
    16 LE
  15. May 15, 2019 at 11:29 PM
    4runningMan
    New Mexico
  16. May 16, 2019 at 6:15 AM
    Toffees
    Micah
    LA
    16 LE
  17. May 16, 2019 at 8:22 AM
    4runningMan
    New Mexico
    Interesting. I wonder if it would fit the LFD crossbars.
  18. May 16, 2019 at 8:27 AM
    Toffees
    Micah
    LA
    16 LE
    there are lots of fairings from different vendors. I don't know how all of these fit, but surely you can find one that has/can attach to the LFD bars
    Rago has similar bars and although I'm not familiar with LFD, I think both of these have lots of attachment options
  19. May 16, 2019 at 9:30 AM
    BYKmatty
    BYKmatty New Member
    Hawaii
    LFD bars are square not oval like what is shone in the image
  20. Feb 13, 2020 at 6:44 PM
    Prime2357
    Prime2357 New Member
    2020 4Runner SR5 Premium
    None yet, my first!
    I came here with pretty much the same questions. I just bought a new 2020 with dealer installed roof rack and crossbars. the manual says 120# limit! I’m transferring rooftop luggage carrier from 2007 Highlander which will be fine, but wanted to add rooftop tent instead. But can’t get any clear guidelines on what the roof will actually hold!
    I get the dynamic vs static weight argument but that still doesn’t tell me how to calculate the static weight.
    thoughts? Suggestions? Real world examples?
  21. Feb 13, 2020 at 6:55 PM
    HarveyElmore
    HarveyElmore New Member
    Harvey
    Offroad TRD 17'
    When you have four bars
  22. Feb 13, 2020 at 7:10 PM
    mynameistory
    Tory
    Start adding weight to your roof rack. When the roof begins to buckle, subtract 10 pounds.
    KSJ08, nimby and Prime2357[QUOTED] like this.
  23. Apr 20, 2020 at 4:36 PM
    travistheone
    travistheone New Member
    Hank Stamper
    stock 16 sr5
    i use a RTT on factory roof rack and rails. no problems. nothing crazy wheeling wise, but 30 mile and hour rough fire roads. no issue. I did replace the thumb screws with machine head hex screws.
  24. Apr 21, 2020 at 7:17 AM
    Oldtoyotaguy
    Oldtoyotaguy Paid cash for it
    2018 Toyota 4 Runner Offroad
    Artec makes some nice rails that work on the stock rack https://www.artecindustries.com/ty4r5g-crossrails that I have considered. All roof racks add wind noise, some more than others. The better ones include wind fairings in their design that probably help. The trouble with the stock rack is that its not exactly strong. The low profile racks offered by the after market are eminently preferable, and look better, IMHO. Some of the good ones are Victory 4X4, Front Runner, Baja. Prinsu is usually included, but I've seen some negative reviews on here about their quality. Front Runner, in particular is strong, and well made and comes with solid expedition cred. Of course, its expensive, especially all the accessories, which are cool.
    Big B and Chris In Milwaukee like this.
