Toyota Funner build
Discussion in '5th Gen Builds (2010-2024)' started by Irikumi, Dec 19, 2018.
  1. Dec 19, 2018 at 4:09 PM
    Irikumi
    Irikumi [OP] New Member
    Adrian
    2017 SR5 4x4
    ARB Locker, rear.
    I bought my 4Runner new in May 2017. Mods so far as of December 2018...
    Bilstein 5100's front and rear. Front set at max height, with Wheelers Off-road 1/4 inch spacer in front, and Daystar 1 1/2 inch spacer in rear. Lift gave approximately 2 7/8 inch lift in front, and 1 1/2 inch in rear. I did buy a diff drop kit, but did not install as they seem to be mostly useless on 5th Gens. Stock UCA's. Toyota aligned front end, and was able to get it just slightly out on Camber and Caster with Toe in specs.
    ARB Rear Locker RD193, ARB on-board air CKMA12. Used "Air On-Board" OEM style switches to give it a factory look in the cab.
    TRD Off-road Wheels 17x7.5 with BFG KO2 AT LT285/70R17 Load range E "DT". Had to trim a little off front and push forward the fender liner. Did not have to remove mud flaps.
    Raised rear axle vent to top of gas filler neck.
    Yellow Fog light bulbs.
    brad, ManBeast, Kyblack76 and 2 others like this.
  2. Dec 19, 2018 at 4:09 PM
    Irikumi
    Adrian
    2017 SR5 4x4
    ARB Locker, rear.
    ARB RD19320180706_191904.jpg Switches from Air Onboard20181220_123851.jpg The compressor mounted to a bracket from Slee Off-road. 15453347704936411175616205138262.jpg
    WallyT4R and rkwfxd like this.
  3. Dec 20, 2018 at 7:44 AM
    rkwfxd
    rkwfxd New Member
    Rich
    Whittier - So Cal
    Looks like a great build. We need more photos - OBA mounting location? OBA Switches? Different angles?
    Irikumi[OP] likes this.
  4. Dec 20, 2018 at 10:44 AM
    looks good
  5. Dec 20, 2018 at 11:44 AM
    Irikumi
    Adrian
    2017 SR5 4x4
    ARB Locker, rear.
    10-4. Added more photos. Thanks guys.
  6. Dec 20, 2018 at 11:55 AM
    Irikumi
    Adrian
    2017 SR5 4x4
    ARB Locker, rear.
    The only work I didn't do myself was setting up the 3rd member. I have done Detroit lockers and others before, but this is my first ARB and I let a guy who knows then do the work. I did R&R it myself though...
  7. Dec 20, 2018 at 12:29 PM
    rkwfxd
    rkwfxd New Member
    Rich
    Whittier - So Cal
    :bowdown: Nicely done. Clean, simple, cost effective and functional.
