Toyo Open Country RT Trail
Discussion in 'Wheels & Tires' started by Commited, Sep 26, 2023.
  1. Sep 26, 2023 at 7:06 AM
    Commited
    Commited [OP] New Member
    Oscar
    So Cal
    2019 Silver Metallic TRD ORP
    Tinted fronts, blacked out overlays.
    Anyone running these tires in Load C? If so can you provide a review. Thanks.
  2. Sep 28, 2023 at 6:29 AM
    Commited
    Oscar
    So Cal
    Anyone?
  3. Sep 28, 2023 at 8:07 AM
    I like the tire design, and off road handling. On road is great as well, very low road noise. They also look great, now keep in mind mine are not load C, but I think the characteristics are the same right?
  4. Sep 28, 2023 at 8:18 AM
    Captain Sensible
    Captain Sensible New Member
    I had the AT2's on my Taco and have the AT3's on my 4 Runner with no complaints. Toyo makes a great product.
    YetiMtnBkr and Commited[OP] like this.
  5. Sep 28, 2023 at 8:26 AM
    totmacher
    totmacher New Member
    Daniel
    West TN
    2018 SR5 Nautical Blue
    done some stuff to it
    I have them. 285/70-17, load C.
    Only have about 6,000 miles over a few month worth of use. I like them so far.
    As good or better than KO2 i had for the last 55,000 miles before.
    Have already held balance better than KO2 did. Those were constantly going out of balance and vibrated in the steering at 60mph almost always.
    The RT Trail did take a few hundred miles to break in. Like maybe they got flat spots sitting over night that caused some vibrations at at certain speeds but only for 1st 3 or 4 miles then smoothed out. They don't seem to do that anymore now. All smooth ride.
    Handling is good. There is something that feels different at rear. Not bad, just something is different from before. Hard to describe.
    There is some road noise but i don't notice it if i'm not listening for it. No worse than i had before really.
    Commited[OP] likes this.
  6. Sep 28, 2023 at 8:55 AM
    Commited
    Oscar
    So Cal
    Can you post a pic of yours. Per Toyo’s website E’ & C’ are only 2 pounds in difference. Would like to compare between yours and Silver Slug’s pics.
  7. Sep 28, 2023 at 11:06 AM
    totmacher
    Daniel
    West TN
    Here's mine.
    Commited[QUOTED][OP] likes this.
  8. Sep 28, 2023 at 1:21 PM
    pastoreater
    pastoreater New Member
    2023 sr5 2wd toyo 115T
    @SlvrSlug how is your suspension set up on the rear, are you getting full travel across stock suspension geometry? How is your clearance with 285/75r17 in the rear?
  9. Sep 28, 2023 at 1:59 PM
    Fortuner
    Fortuner New Member
    CA
    2021 4Runner TRD Off Road Premium w/KDSS
    I recently installed a set in Load C. I’ve only put on about 900miles so far, but here are my initial thoughts, coming out of a set of KO2’s in the same load range:
    • Daily driving duties and light rain they’re as good. I feel the KO2’s would grip a tiny bit better with “spirited” driving, but it’s hard to tell and I rarely drive the truck like a sports car.
    • Ride comfort is improved. I thought it was a placebo effect at first, but it was confirmed by my wife as well. They don’t translate certain vibrations into the cabin whereas the KO2 would allow you to feel everything on the road. Might be due to sidewall stiffness?
    • Above 50mph they’re a bit louder than the KO2, but you have to listen for it and I personally don’t find it obtrusive. My KO2’s got fairly loud nearly 10k miles of use.
    • They balanced with fewer weights and have held balance since install. This is something I could never say about my KO2’s and the primary reason I switched out before they fully wore out.
    • They look fantastic!!
    I’m about to put them through their first off-road trip in the coming week, and can report back on trail impressions.
    Trail Runnah and Commited[OP] like this.
  10. Sep 28, 2023 at 2:21 PM
    Commited
    Oscar
    So Cal
    Cool, I’d like to hear feedback on how they do offroad.
  11. Sep 28, 2023 at 4:01 PM
    totmacher
    Daniel
    West TN
    They are great on dirt and gravel. I haven't done more than that offroad yet with mine.
    They kick up far fewer rocks than the M/T tires on my other truck.
  12. Sep 28, 2023 at 4:18 PM
    I don’t believe we have much trouble in the rear, usually the fronts are the trouble area, but with a little trimming all is well.
    pastoreater[QUOTED] likes this.
  13. Nov 9, 2023 at 7:27 PM
    Commited
    Oscar
    So Cal
    So the other day I drove the 4runner and noticed my TPMS light was on got off the truck got some soapy water solution and sprayed all the tires and found a large screw on my front right tire. Went to America’s Tire and asked them to make a repair and also give me an estimate for some Load C Toyo Open Country RT Trails. Well since my KO2’s already had 2 repairs on my rear tires and worn and now 1 in front I ended up buying the Toyo’s. Have to say I am really liking them, they are smoother on the highway than the KO2’s and I swear not as loud. Can’t wait to do some wheeling with them. The Tech at America’s Tire said they were easy to balance. IMG_6808.jpg
    TrailSpecial22 and hossler1788 like this.
  14. Nov 9, 2023 at 7:53 PM
    Mr. Snuffleupagus
    Brandt
    2022 TRD Pro
    Elka 2.5 DC, Sherpa Crestone, C4 Lo Pro, Baja Designs S8, Morimoto 4bangers, Switch Pro 9100, Westcott Designs sliders, Toyo Open Country RT Trail 285 75/R17
    Im also running the RT trails in 285 75/R17 load E with a 3/2" lift. Ive had no issues with articulation when off-roading. I would agree with others that these run smooth and surprisingly quiet on road. Traction off road is impressive and have run most marginally difficult trails even in 4H. I have had minor rubbing in the front but it was an easy fix with a minor fender trim. I ma coming from KO2's and IMHO these are a better tire on and off-road.
  15. Jan 29, 2024 at 5:10 PM
    Fortuner
    Fortuner New Member
    CA
    Still loving these RT Trails! Finally put them through light mud and I feel they did great!
  16. Jan 29, 2024 at 6:59 PM
    Commited
    Oscar
    So Cal
    Ive been very satisfied with mine, on & offroad, haven’t driven them in snowy conditions just yet.
    YetiMtnBkr and Fortuner like this.
  17. Jan 30, 2024 at 1:56 AM
    Jareds Toyota
    Jareds Toyota New Member
    Jared
    2019 TRD Offroad
    I’m running C rated 285/70/17. I’ve had them for nearly 5k miles. They handle well on the road, but they are a little louder than my K02s were. MPGs went down a little as well.
    They did surprisingly well on both ice and snow on the way up the pass (even though they don’t have the 3 peak rating).
    Balancing has been a little bit of challenge for me. I have a slight shimmy at 60 mph, and have taken it back to discount tire once because of it (who knows though, the tech also beat up my wheels when I brought them to be rebalanced).
    All in all, I’m happy with them.
  18. Jan 30, 2024 at 9:08 AM
    Fortuner
    Fortuner New Member
    CA
    Truck looks great!! Glad to hear they handle snow well, I'll be up in the mountains soon.
    The 4Runners sensitivity to tire balancing has to be the worst part of 4R ownership, IMHO. Hope you get this resolved.
  19. Jan 30, 2024 at 12:27 PM
    Commited
    Oscar
    So Cal
    I came from KO2’s for that same issue took me 3 tries to get them balanced correctly. Found a tire shop that I guess knew what they were doing. I’ve run the RT Trails up to 75 mph and they are smooth and maybe just a tad louder than the KO2’s but in a good way. I’m very happy with them, I’ll be up in Utah end of March hope I get to put some snow under them.
    Jareds Toyota[QUOTED] likes this.
  20. Jan 30, 2024 at 11:35 PM
    Jareds Toyota
    Jared
    2019 TRD Offroad
    I 100% agree. I have had this issue before with my KO2s, and on my previous Toyota. I usually try to do 65 or 55 just to avoid feeling it.
    Fortuner[QUOTED] likes this.
  21. Feb 24, 2024 at 10:26 AM
    Curt73
    Curt73 New Member
    Curt
    Ohio
    2008 Titanium 4Runner SRS Sport Edition 4x4
    Rough Country 2.5 lift Front Springs and N3 Struts, Rough Country N3 Rear Shocks, Dobinson 1.5 lift Rear Springs, TRD Style 17x8 Matte Black Wheels, Toyo Open Country RT Trail 275/70R17, Black Headlight Assembly
    I'm running them 275/70R17 though. I love them. A little road noise but that's expected since they lean toward the MT tire.
    Trail Runnah likes this.
  22. Feb 24, 2024 at 11:30 AM
    How do you like the e loads? Do you find the ride harsh, or harsher than other load range tires that you run in the past?
    I'm thinking of running either these or the AT3 in a 255 80 17 on mine, and multiple people have told me that I don't want an E for a daily driver.
    I don't hit off-road as much as I want to, though I'm hoping a remedy that this year, but I do 60 mi of highway a day commuting. Pokémon and miles I put on, I'm not looking to put a huge heavy tire that's going to destroy my mileage. I think the RT in the 255 is about 52 lbs, the AT3 is 50 lb. That's as heavy as I want to go.
    Thanks!
  23. Mar 17, 2024 at 7:04 PM
    Tooly
    Tooly New Member
    Okanagan, BC Canada
    2021 4Runner ORP
    Those of you that have been running these over the fall and winter, how is the wet weather traction? I'm not concerned with snow traction as I have dedicated winter tires.
    Curt73 likes this.
  24. Mar 17, 2024 at 8:56 PM
    Commited
    Oscar
    So Cal
    I’ll chime in on this. So Cal has had above average rainfall this year, I’ve driven thru some heavy downpours on the highway and street and I’ve had zero complaints, mine are a Load C tho. I came from KO2’s and those felt sometimes like I was floating on the highway especially particularly in heavy downpours, that’s been my experience.
    Curt73 likes this.
  25. Mar 18, 2024 at 5:30 AM
    Curt73
    Curt73 New Member
    Curt
    Ohio
    Same here out east here we had a lot of rain and I have yet felt anything like it was hydro planing on the highway. I think they do very well on wet roads for a aggressive RT tire
  26. Mar 18, 2024 at 7:40 AM
    Commited
    Oscar
    So Cal
    Add to that I love the RT Trails, for the offroad stuff I do they can’t be beat. They are a little louder than KO2’s but I always have something on, Music or Podcasts so the noise gets drowned out.
    Curt73 likes this.
  27. Mar 26, 2024 at 10:20 AM
    MGM_Marcus
    MGM_Marcus New Member
    Those look great. What size are you running? Also, how do they handle in wet conditions? I'm still running the Goodyear Wranglers mine had when I bought it and they're a bit squirrely in the rain.
  28. Mar 27, 2024 at 1:50 PM
    Fortuner
    Fortuner New Member
    CA
    Thanks. They are a 285/70r17. So far they've been great at handling everything I've thrown at them. Significantly better in wet conditions than my KO2's.
  29. Mar 27, 2024 at 3:36 PM
    brodeyo
    brodeyo New Member
    Cincinnati, Ohio
    2024 Black TRD Pro
    RCI Skids Sliders, Wescott Designs Lift
    45k mile warranty, right? Assuming in my case 95% road 5% off-road (if that), AT3 would be best...?
  30. Mar 27, 2024 at 4:12 PM
    YetiMtnBkr
    YetiMtnBkr New Member
    Frederick, MD
    2021 LR Pro
    None
    My Toyo Open Country AT3's in stock size came with a 60,000 mile warranty. Very pleased with the tires thus far (4 months and 5,000 miles)! They have been great in the rain. No snow to speak of in MD this winter. Yet to go off road.
