Towing with a 2018 4runner SR5
Discussion in '5th Gen 4Runners (2010-2024)' started by Maisie, Jan 30, 2021.
  1. Jan 30, 2021 at 4:38 PM
    Maisie
    Maisie [OP] New Member
    2018 Grey 4Runner
    Hello, before i bought my 20184runner i had searched these threads on how the members did with towing with their vehicles. I found that towing 5000lbs is well within the limits of this vehicle. I have a epro camper 3275lbs empty. It seems that the epro forum members think a 4runner is a bad choice for towing? I dont understand this thinking. What is your opinion on this?
  2. Jan 30, 2021 at 5:02 PM
  3. Jan 30, 2021 at 5:15 PM
    Mtbpsych
    Mtbpsych New Member
    Short wheelbase vehicles aren’t ideal for towing heavy loads. I’m sure the 4runner can handle it just fine as long as you take it slow. I’ve seen some members on here or other forums towing some serious weight. With that said, I’ve never towed anything with mine and am not expert, so that’s just my opinion:hattip:
  4. Jan 30, 2021 at 5:56 PM
    Maisie
    2018 Grey 4Runner
    thanks
  5. Jan 30, 2021 at 6:45 PM
    GrantA
    North Carolina
    Fully locked 2020 SR5 Premium
    I use to tow a pop up camper that weighed about 4K pounds fully loaded. I live in Arizona and it was 110+ outside and we made a trip up to northern Arizona. Let’s just say it was several thousand feet in elevation change. The 4Runner did awesome. Granted I could maintain 70 mph with my foot on the floor with a steep climb. However, I did that to test the capability but I would recommend taking it slow, don’t push the RPM’s. Plan on staying in the right lane with the truckers hauling a heavy load. Also make sure to enjoy the ride. Most trailer tires are rated for a speed limit of 55mph (not that everyone in Arizona obeys that). I hope this helps. I then loaded up water and stuff when I got to camp to save on the weight.
    mrmike7189 likes this.
  6. Jan 30, 2021 at 7:32 PM
    SmurFJ
    SmurFJ New Member
    Bryan
    2021 Lunar Rock Pro
    I've towed right up to the 5k limit on my FJ (23 foot Apex camper with a slide out) without issue. I'm assuming the 4Runner will handle it just as well. I'd try to keep it no faster than 65mph and it seemed happy
    ESCT4R likes this.
  7. Feb 2, 2021 at 7:04 PM
    Justinmpd
    Justinmpd New Member
    2020 TRD Off-Road Premium
    It will be fine towing. You just really need to keep your speed below 70 and brake early. You don’t have much wiggle room when braking with the extra weight.
    ESCT4R likes this.
  8. Feb 2, 2021 at 10:20 PM
    ESCT4R
    ESCT4R New Member
    2022 TRD ORP
    Hey!
    I tow a travel trailer that is 3950lbs dry weight. You can tow with the runner, but you gotta take it SLOW (put in S4). Before you even tow that weight, get a brake controller. Don’t even think about towing without that, please. Also, you’ll want to get a weight distribution hitch with anti-sway bars. This will help reduce swaying. A few things you may also want to add is an extra trans cooler and some Air bag helper springs. Lmk if you have questions!
  9. Mar 24, 2021 at 10:01 AM
    Maisie
    2018 Grey 4Runner
    I would like to put some helper springs on the back end of my 2018 4runner. I have looked around this site and am confused. Can anyone recommend what would work with my car? i.e. brand names to look for. Have you installed them yourself? are they easy to install? Thanks in advance
