Towing a 3600lb travel trailer
Discussion in 'Towing' started by Diverman62, Sep 10, 2023.
  1. Sep 10, 2023 at 5:53 PM
    Diverman62
    Diverman62 [OP] New Member
    2018 4runner blue
    Looking at purchasing a travel trailer
    About 3600 lbs any suggestions for making a safer and enjoyable experience
  2. Sep 10, 2023 at 6:11 PM
    Welcome to the forum!
    Is that dry?
    That's probably going to have a heavy tongue weight, so I'd try not to load a lot of weight in the cargo area.
    Tow in S4, and keep your speed around 65 MPH or less. Take your time and increase your following distance.
    Also, get a good brake controller.
  3. Sep 10, 2023 at 6:13 PM
    steelevo
    Utah
  4. Sep 10, 2023 at 7:20 PM
    Dabigono
    Dabigono Just Joined
    2020 4Runner
    Welcome from SoCal
    Diverman62[OP] likes this.
  5. Sep 11, 2023 at 2:04 AM
    Welcome from Wisconsin! What Thatbassguy said will keep you out of trouble.
  6. Sep 11, 2023 at 4:23 AM
    JET4 New Member
    welcome
  7. Sep 11, 2023 at 5:17 AM
    Ironguy New Member
  8. Sep 11, 2023 at 5:59 AM
    BgBmBoo
    BgBmBoo New Member
    Kansas
    I'd look into a good weight distribution hitch with sway control as well. Otherwise Thatbassguy pretty much summed it up.
  9. Sep 11, 2023 at 8:06 AM
    Georgetown, TX
  10. Sep 11, 2023 at 8:22 AM
    MoreOutdoors
    MoreOutdoors New Member
    2020 Off Road Premium
    Confirm the listed tongue weight of the trailer. For our trailer it is 450 lbs which is more than the 10-15% of trailer weight rule of thumb a lot of people use. I second the brake controller and weight distribution hitch comments.
    I’ll add that we added airbags a few months after we first got our trailer and the increase in stability and ride comfort was noticeable.
  11. Sep 11, 2023 at 8:36 AM
    Nubes
    Nubes Toyota Addict
    So far everything that has been said has been spot on. Don't get in a rush. Tow in S4 and your MAX speed is going to be 65MPH and down to about 40MPH on steep grades and probably about 60MPH most of the time. I installed a RedArc trailer brake controller since the install looks factory and I won't hit my knee on it every time I get in/out. I also run an Andersen weight distribution/sway control hitch. I chose it for a few reasons: 1. You can backup with it connected unlike some other WDH's out there. 2. It doesn't squeak and make a racket when driving through the campground. 3. It is more compact and lighter than most other WDH's. I also installed an additional transmission cooler to keep the trans temp in check as it got too hot for my liking on my first short trip with it. Not sure if I need them and I keep forgetting to check my height when loaded, but I am also contemplating some Timbren bump stops. I prefer the idea of the Timbrens over air bags due to the simplicity and not having to air up or down.
  12. Sep 11, 2023 at 10:01 PM
    DesertSurfer
    DesertSurfer New Member
    Ditto what Thatbassguy said, I always shop for food near my destination, 1/4 tank of water for drive then fill up at campground and go through trailer and take out unneeded stuff the wife has loaded (don’t tell). Welcome to the forum!
  13. Sep 12, 2023 at 12:28 PM
    kolter45
    Denver
    Inferno Pro & BRM Sport
  14. Sep 12, 2023 at 1:51 PM
    Oakboro, N.C
  15. Sep 12, 2023 at 2:44 PM
    Nubes
    Nubes Toyota Addict
    This is one of the videos I watched to get an idea on the install:
    https://youtu.be/7P_nsUpisoE?si=6lgoLI9GguE_BEX8
    kolter45 likes this.
