Toe out alignment
Discussion in '5th Gen 4Runners (2010-2024)' started by Pavementprincess24, Apr 15, 2024.
  1. Apr 15, 2024 at 6:34 PM
    Pavementprincess24
    Pavementprincess24 [OP] New Member
    2024 White 4Runner TRD OR premium
    I’m fairly new to owning a 4Runner but I have a question regarding the alignment of the front wheels. When looking at the 4Runner from the front, the toe out is very pronounced. After driving my 4Runner for a month I’ve noticed it’s pretty damn squirrelly on the highway. Is this normal or should I see if I need an alignment?
  2. Apr 15, 2024 at 7:21 PM
    You need an alignment.
  3. Apr 17, 2024 at 7:55 AM
    Greg D
    Greg D New Member
    Greg
    2013 4runner
    More positive caster will make it less squirrelly. Supposed to be around 3-3.5° I believe. I have seen some steering rack bushings that go bad sooner on the newer 4runners. I think quality of materials is declining.
  4. Apr 17, 2024 at 9:00 AM
    jgalt
    jgalt New Member
    You don't want toe-out on a 4R for proper handling. Straight ahead to slight toe-in is the goal. Your inner tread will wear quickly w/ toe-out too.
  5. Apr 17, 2024 at 11:11 AM
    Pavementprincess24
    I took it to the dealer yesterday and they did an alignment, although it still looks toe out to me. I looked at several other 4Runners and Tacomas, none looked as severe as mine.
  6. Apr 17, 2024 at 11:28 AM
    You can easily check the toe in/out with a tape measure and a bit of patience.
  7. Apr 17, 2024 at 12:16 PM
    Oakboro, N.C
    I hope the rack bushings don't fail that quick on a 2024. If so this would be a major issue coming down the line.
  8. Apr 18, 2024 at 8:50 AM
    RUNNER4DAN
    Daniel
    Doesn't need any
    I can't think of any vehicle that neds toe out.
    A certain amount of toe in is needed to keep the tires from scrubbing on turns. The outside tire will actually be running at a smaller radius than the inside.
