TIRE Size Comparison - what do they REALLY look like Side-by-side?
Discussion in 'General 4Runner Talk' started by GigemAgz95, May 13, 2019.
  1. May 13, 2019 at 5:33 PM
    GigemAgz95
    GigemAgz95 [OP] New Member
    Brad
    Houston, TX
    2007 v6 SR5 2wd. 51K mi
    KPMF stealth Tundra vinyl wrap. Interior Led mod. Fog light mod. Jensen deck, Polk DB plus doors. Blackout of chrome - Emblem Delete.
    So - I have used this page a number of times, for numerous vehicles.
    This does SORT OF Give an idea on fitment, but not necessarily to OUR Vehicle, just Overall - in a comparison.
    You plug in OE on the Left - and new size on the right, and you get both views, and ton a data to stare at..
    And even some Alternatives that may work as well, with a Speedo Comparison.
    Hope this helps some out there. (oh yeah, change Units as needed. US vs. everyone else.)
  2. May 14, 2019 at 5:29 AM
    Agent_Outside
    Built 2011 T4R Limited
    That’s a pretty nice one but they are inherently inaccurate. For example a Copper S/T Maxx tire in a 255/80/17 has a 32.8” diameter, but a Nitto Ridge Grappler in that same 255/80/17 has a 33.3” diameter (based on the manufacturer’s specifications. Same size tire with 1/2” variance in diameter. It’s hard to make a calculated based off generic measurements, they really need to allow you put in the actual size instead of the stated size (that goes for tire size calculators as well). I know K02s for example run notoriously small for their size.
  3. May 14, 2019 at 3:44 PM
    GigemAgz95
    Brad
    Houston, TX
    Interesting - and yes, I agree that they can be generic.
    I wonder if original tread depth would factor into this? or what makes them vary by that much if the same "specs"?
    Interesting. thanks!
